Old Aug 30, 2005, 09:27 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Are flaperons possible with a 4 channel receiver?
Hey fellas,
I'm building my first park jet and this is my first experience with FLAPERONS.
I have a Futaba 7CAP computer radio and a GWS R4P 4-channel receiver, and 3 GWS pico servos; one for each aileron/flap and one for elevator. I tried to set up the second aileron servo on channel 4 since there is no rudder on this model, but the FLAPERON mix only allows channels 5, 6, or 7 to be selected. Does it make since to slave rudder to channel 6 (default) 100% and use 0% D/R on the rudder so that left stick has no control authority? That way the channel 6 output controlled by the FLAPERON mix is passed to channel 4 bypassing the left stick. Whew, I hope that made sense. Please say there is a simpler way. I haven't tried it yet, but I suspect that setting the RUDDER D/R to 0% will nullify the movement prompted by channel 6 (FLAPERON)
Thanks in advance.
J
JayJay76 is offline Find More Posts by JayJay76
Old Aug 30, 2005, 10:15 AM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
I'm going through the same thing with my Futaba T6XAs radio. I ordered 3 GWS 4ch
receivers a week ago and I should have got a couple 6 channel ones as well. That would
solve your problem. I've been tinkering with my radio for the last hour and for the life of
me I can't make flaperons work by going through Ch 4.
Hawker is offline Find More Posts by Hawker
Old Aug 30, 2005, 10:39 AM
JayJay76 is offline
JayJay76's Avatar
Did you try the CUSTOM MIX and slave channel 4 to channel 6 (default output for FLAPERON mix) then set the rudder D/R to 0%? let me know if this works for you, I suspect it might, since the custom mix should override the D/R setting for rudder. I learned about custom mix one day when I went to fly my pitts special only to discover before takeoff that I had a broken servo wire on my receiver (its complicated) on the elevator channel. I thought the day was ruined until I thought to plug the elevator servo into the rudder channel and slave rudder 100% to elevator, effectively passing the elevator stick input to the rudder output, nullifying the rudder channel since the model could be flown on elevator and ailerons only. I cant wait to get home to try this out but I was wondering if there is a more simple approach.
J
Old Aug 30, 2005, 11:11 AM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Update! That did it! I forgot to turn ON mixing with the elev d/r switch. Now
that it's on, it works!!
I've got CH 6 as the master and CH 4 as the slave. So cool!!
Thanks dude!
Old Aug 30, 2005, 02:02 PM
JayJay76 is offline
JayJay76's Avatar
hey cool! I can't wait to get home to try it out! You should be able to set your exponential on the aileron channel and it will affect both flaperons as it should.
Let me know how she flies!!
J
Old Aug 30, 2005, 02:05 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
My Harrier is ready for it's maiden flight but now there are thunderstorms rolling in.
May have to wait until tomorrow.
Old Aug 30, 2005, 02:18 PM
JayJay76 is offline
JayJay76's Avatar
Hawker,
is there a thread on your harrier? I would like to see some pics and read about it.
J
Old Aug 30, 2005, 03:20 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
The downside, to using a free mix to get flaperon, is the trims are not linked. When you move the aileron trim lever only the servo connected to channel#1 will move.
-Kwok
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Aug 30, 2005, 03:31 PM
JayJay76 is offline
JayJay76's Avatar
-Kwok
ARRRGH!! Is there a better way that will preserve trims?
J
Old Aug 30, 2005, 04:05 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
My threads... all foamie profile jets that are really fun to fly... Harrier still
awaiting maiden flight though.
AV-8B Harrier
http://www.rcgroups.com/forums/showthread.php?t=409206
YF-23A "Black Widow II"
http://www.rcgroups.com/forums/showthread.php?t=403123
EA-6B Prowler
http://www.rcgroups.com/forums/showthread.php?t=405130
JSF F-35C
http://www.rcgroups.com/forums/showthread.php?t=401629
And about the trims, true. I figured that one out already. Kinda don't like the
idea of not having symmetrical trim, but oh well, I should be OK without it.
Old Aug 30, 2005, 04:15 PM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
J
Nope. This question comes up all the time and its the only way. You can still trim the plane with one aileron during the flight. Just make the linkages adjustable and you can manually adjust the other aileron trim on the ground.
-Kwok
Old Aug 30, 2005, 10:42 PM
JayJay76 is offline
JayJay76's Avatar
i cant get this setup to work with my 7CAP. the channel 4 slaved to channel 6 (FLAPERON output) simply will not respond. I have tried everything I can think of, and I have used custom mixes before, but nothing works. any advice would be appreciated.
thanks
J
Old Aug 30, 2005, 11:34 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Do you have 6 as master and 4 as the slave?
Also your elevator dual rate switch probably needs to be ON if it's similar to mine. That turns on your mixing. If all else fails go to www.futaba.com and download the manual. It's in there. Just carefully follow the directions for custom mixing.
Old Aug 31, 2005, 12:26 AM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Don't you have an option to have a mix "allways on"?
perttime is online now Find More Posts by perttime
Old Aug 31, 2005, 02:31 AM
hul is online now
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
yes, but it takes creative mixing, as you found out, or a Graupner or Multiplex TX. You can assign any channel to any RX output in those radios.
Hans
hul is online now Find More Posts by hul
Discussion MPX EVO7 mixing with 4 channel receiver and dual aileon servos ezmo Radios 0 Apr 03, 2007 05:24 AM
Cool Flaparon with 4 channel receiver Marion Radios 1 Apr 14, 2004 09:34 PM
How to have Flaperons (flaps + ailerons) with a 4 channel receiver Flying Cat High Performance 8 Jul 03, 2002 12:42 AM
5 channel Tx and 4 channel Receiver Skysaurus Beginner Training Area (Aircraft-Electric) 5 Nov 29, 2001 09:08 AM
Any problems using a 4 channel receiver with a 7 channel radio? bluex Power Systems 6 Jul 06, 2001 12:23 AM
