Old Aug 29, 2005, 11:17 PM
maarset is offline
Find More Posts by maarset
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Question
GWS Pico moth prop question
So I got a IPS DX2BB-CXCS motor for my pico moth
which weights around 6 oz. That is a C gear.
I am using a 7.4 Volt 250 mAh ETEC battery.
The GWS website says to use a GWS EP 1260 PROP.
It's HUGE! When the plane is on the ground the prop hits the
ground instead of the front wheels.
I must be using the wrong prop.
What prop should I be using?
I tried a 9070 and it flew but not much power.
Maybe I got the wrong motor for my plane?
Please help.
maarset is offline Find More Posts by maarset
Old Aug 30, 2005, 12:18 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Please help.
Correct motor gearbox is an AXCs which has a ratio of 5.9:1 whereas the CXCS you have has a ratio of around 8:1. My stock TM flies fine with either a 9x7 or 10x4.3. At 8:1 your 9070 is just not spinning fast enough. HTH
Roger Lombard is offline Find More Posts by Roger Lombard
Old Aug 30, 2005, 12:35 AM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
So I should get a A gear then?
Old Aug 30, 2005, 01:03 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Sorry, you must!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Aug 30, 2005, 01:09 AM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Thanks Mr Lin!
I'm going to "brown nose".
GWS ROCKS! Really good solid planes.
Old Aug 30, 2005, 01:53 AM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Well I had a blown up IPS A gear assembly that I was able to use the big gear and motor out of. Man never throw anything away!
Hopefully my pico moth will be back up in the air tomorrow!
Old Aug 31, 2005, 06:40 AM
isvana is offline
Find More Posts by isvana
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
Or a 3S LiPo...
isvana is offline Find More Posts by isvana
Old Aug 31, 2005, 12:03 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
The Tigermoth is a great Isp Plane I have converted all mine Moths over to use lipo battery packs a 2 cell 7.4 volt 1200 pack will kep your Tigermoth in the air for allmost 1 hour with throttle managment.
you you can get a bunch of 10 minute flights out of one pack!
now if you have 2 or 3 packs you can fly all day!
I fly I think with a ep1080 prop on mine most of the time with good results.
I also make all my servo holders out of epp foam for the inside guts real easu and adds no weight.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old Sep 01, 2005, 11:23 AM
isvana is offline
Random Flier
Joined Nov 2002
Good tip - thx!
Old Sep 01, 2005, 12:15 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Took my pico moth out this morning.
IPS A drive and a 9070 prop 250 mAh ETEC lipo. It flew.
Didn't climb like when I first put it together.
Pretty much flew full throttle the whole time.
Tried to get it pretty high so I could do some stunts.
It said NO WAY!
Weighs around 6.5 ounces.
Been in alot of wrecks. Glued back up alot.
Is that heavy?
Is it on the heavy side?
Old Sep 01, 2005, 08:22 PM
tallflyer's Avatar
Joined Jul 2002
Try a IPS C Gear.
Old Sep 01, 2005, 11:17 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
ha funny!
Old Sep 01, 2005, 11:48 PM
tallflyer's Avatar
Joined Jul 2002
I was Just Kidding try Different Prop Combos! Ep1080 and stuff
Old Sep 02, 2005, 04:03 AM
isvana is offline
Random Flier
Joined Nov 2002
...Weighs around 6.5 ounces.
Is that heavy?
I'm at 7.2oz WITHOUT battery - its my 1st TM so learnt lots. Etec450 3S makes it 8.5oz.
Will be using an HD9050 prop as I'm running a 3S battery.
Old Sep 02, 2005, 03:46 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
A EP 1080 and a C drive gear tallflyer?
GWS Pico Moth Kit plus - good deal? bhenry Electric Plane Talk 7 Jun 27, 2004 11:37 AM
GWS Pico BB Servo Question & Problem Azygos Parkflyers 9 Mar 23, 2004 08:08 PM
GWS Pico and Naro receiver question E=mc2 Radios 1 Apr 19, 2003 12:55 AM
GWS Pico Stick motor question mlehman Parkflyers 13 Jul 19, 2002 05:15 AM
GWS Pico Receiver / Crystal question. Airnut 2 Parkflyers 10 Oct 20, 2001 12:39 PM
