May 07, 2002, 05:35 AM
Haslemere, Surrey, UK
Joined Jul 2001
Re: foam vs balsa construction...
[QUOTE]Originally posted by Arbo
[B]I know this has been talked about before, and all have their own opinions on what is best... but....
Which is lighter? I can make some light foam stuff, but that requires glassing for strength... where with wood I can just use normal shrink covering...
Arbo
Whenever I think about using foam for a wing I remind myself that a proper wood structure is mostly trapped air and go and lie done until the urge goes away.
Seriously - if you can't build a wooden wing for less wright than a foam one of equivalent strength, size, and section there is something wrong with the design and/or the building technique.
All the best
