Old May 05, 2002, 07:27 PM
Magna is offline
Find More Posts by Magna
Malaysia
Joined Jun 2001
Do you get thermal on top of lake?
Hi all
My flying site have a huge lage in front. The banks are not steep or high. The wind is not strong either, so no sloping lift.
So as the day get warmer from 10-12 noon, can one get any thermal development here. I don't fly beyond 12 noon as I have other obligations, though luck!
Used to get tonnes of them when I fly behind the pit area as we have tonnes of factory/warehouses which generate tremendous lift.
But we are setting up a club and limiting the flying area so I need to check if the lake will be a friend or foe. I did manage to get one time, but only if the sun gets really hot!
Magna is offline Find More Posts by Magna
Old May 05, 2002, 08:36 PM
Ben Diss is offline
Find More Posts by Ben Diss
Ben Diss's Avatar
United States, OH, Powell
Joined Jun 2000
It's not likely. Typically, water is cooler than the air and does not radiate the sun's energy back into the air. The only way I can think that you might find a thermal over a large body of water is if detached from an upwind source and climbed above the water.
-Ben
Ben Diss is offline Find More Posts by Ben Diss
Old May 05, 2002, 08:54 PM
Ron Cichowski is offline
Find More Posts by Ron Cichowski
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
Every year I spend 3 weeks on the northern reaches of Lake Champlain on the Vermont side about a mile below the Canadian border. The cottage I stay at has about 200 acres of fields suitable for winch setup leading to the lake shores. This location in July and August has consistently the best thermal activity of any places that I fly. I have dotted out everything I have ever flown here from HLG to 3Meter. The activity is long lasting too, I've done an hour on every plane I bring to this site. Fatigue and boredom bring me down after 60 minutes.
Thermals are a result of a temperature differential between air masses. I think that that big body of temperature stable water adjacent to the land that heats relatively rapidly under the sun is the reason this activity is so pronounced and dependable. I also spend a fair amount of time on the lake fishing from a boat and take note of gulls working thermals over the water. I haven't yet had the nerve to try hand launch from the boat yet though.
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
Old May 05, 2002, 09:54 PM
sal is offline
sal
Find More Posts by sal
sal
NSP (Vermont)
Joined Aug 2000
The area you a flying from, Ron has a unique topology. I wouldn't count on this from most lake areas. You have to look at how the land sets up with the body of water and what are the prevailing winds.
sal is offline Find More Posts by sal
Old May 06, 2002, 06:12 PM
ThunderChicken is offline
Find More Posts by ThunderChicken
Private Pilot, M20J Owner
Lake Dallas, Texas
Joined Apr 2002
My father is a pilot (ya know, the full size things) and we fly over lakes specifically because the flights tend to be very smooth while flying over them. This is directly attributed to the fact that we never expect any thermals to be coming up off of the lake. I agree with sal, I wouldn't count on any thermals from a lake.
Oh ya, I should point out, my father prefers to fly in the early mornings and evenings when the air is a lot smoother...in the event that we are flying mid day...lakes become a fun place to fly over because it can smooth out most flights even during peak thermal hours...
ThunderChicken is offline Find More Posts by ThunderChicken
Old May 06, 2002, 08:59 PM
Tim Green is offline
Find More Posts by Tim Green
Joined May 1999
You can use the lakeside to your advantage - the land, if it's flat, and especially if it's unplanted, will heat up first - before the water. This will generate your thermals quite readily.
Here in Cleveland, we have the air show on the lake front each year. When the smokers fly, you can see the smoke come back off of the lake, just above the water, move onto the land (hot parking lots and runways) and then straight up for several hundred feet. At that point, it cools off a bit and travels back out over the lake, and I think it then falls back down towards the water - but it's hard to see at that point.
Tim Green is offline Find More Posts by Tim Green
Old May 06, 2002, 11:10 PM
Magna is offline
Malaysia
Joined Jun 2001
This started to sound hopeless to me!
The lakeside is flat but it have cow grass on it. Nice for landing and I doubt it will give me thermal action especially in the morning with the mildew barely evaporated.
Unless I have a down drift thermal from the factory area, otherwise I need to get a new plane that are lighter/floater ie the ELipsoid.
I just became a Secretary for a local Aero model that we want to set up, so we have new rules and all.
Duh!
Poll OT- How often do you get on RCG??? simo10 Electric Plane Talk 29 Apr 24, 2010 08:49 PM
How do you get the C or E clips off and on?? Waldo Pepper Power Systems 9 Jun 19, 2005 09:53 PM
How do you get out of a Thermal? My first thermal experience. High speed pass Electric Sailplanes 9 Jun 16, 2004 05:34 PM
Heat Sink on Mega - How do you get it on there?! Ninjak2k Electric Heli Talk 14 Aug 06, 2003 08:34 AM
How do you get at the Battery on Mini and SB??? m4tm Parkflyers 4 Oct 23, 2002 03:28 PM
