This thread is privately moderated by genovia, who may elect to delete unwanted replies.
Old Apr 30, 2006, 07:24 AM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Originally Posted by gquiring
Ooops. I pulled up and it still went straight in.
Hi gquiring I can see it doesn't like rough landings. Other then that,
how does you Hobby Lobby plane fly?
I was thinking of getting one, they are real inexpensive right now.
Glen
biggy boy is offline Find More Posts by biggy boy
Old May 07, 2006, 06:53 PM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
Glen
I never thought I could have so much fun with a $20 plane. It flies great and we have many in our club. I repaired the plane using blue foam from Home Depot. Flies as good as before.
Here is an impact that happened today with two Yak's.
gquiring is offline Find More Posts by gquiring
Old May 08, 2006, 08:12 AM
The Judge is offline
Find More Posts by The Judge
The Judge's Avatar
OHIO
Joined Oct 2005
Tip Stall
Heres a Green R/C Cleverboy, It always had bad tip stall tendencys and I finally lost it on a low slow inverted pass. will fly again!
The Judge is offline Find More Posts by The Judge
Old May 08, 2006, 08:28 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Oooh nasty .... Btw I'm not sure I like the look of those battery connectors - not good for much current. What setup are you using in that plane (motor, controller, battery, etc)?
Looks like a nice smart model! Hope to see it back together soon
David
Hogster is offline Find More Posts by Hogster
Old May 08, 2006, 10:00 AM
The Judge's Avatar
OHIO
Joined Oct 2005
Cleverboy
Hi, The small JST connectors are fine for this set up as I am only running a park 400 motor with a 5.0-1 gearbox, a 2100mah lipo and a castle creations 25 esc. Fantastic flights of around 28 mins. (full throttle) This is only a toy to use when I am not flying gassers. Tim
Old May 08, 2006, 07:19 PM
Tonystott is online now
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
?? I understood that JST connectors are not suitable for more than about 5 amps.
Tonystott is online now Find More Posts by Tonystott
Old May 08, 2006, 07:30 PM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
That's what I was thinking Tony .... they're usually only reserved for receiver batteries or very small parkflyers .... I would put some micro Deans on there personally ....
David
Old May 08, 2006, 07:54 PM
Balsa Hound is offline
Find More Posts by Balsa Hound
SW Vermont
Joined May 2002
Those BEC connectors are rated at 3 amps. In most applicatons, they're fine up to 8 amps. I have a bunch of models that draw 8 amps or less, and the connectors remain at ambient temperature even after a long full-throttle flight.
Some people actually use them in 10-amp systems, but I find that current draw is pushing it as the connectors become warm after five minutes or so. For applications pulling up to 10 amps, the two-pin Micro Deans will work fine, and you can actually push those to about 12 amps or so without too much trouble.
Balsa Hound is offline Find More Posts by Balsa Hound
Old May 08, 2006, 09:11 PM
The Judge's Avatar
OHIO
Joined Oct 2005
Jst
No problem with the JSTs, they dont even get warm.
Old May 10, 2006, 04:30 PM
MKMotorsport is offline
Find More Posts by MKMotorsport
lawn darts r' us
Joined Sep 2005
please dont tell me you were using the wattage "Cirrus" RTF 27mhz. radio next to the plane to fly that plane?
MKMotorsport is offline Find More Posts by MKMotorsport
Old May 10, 2006, 06:05 PM
The Judge's Avatar
OHIO
Joined Oct 2005
cirrus
Yup!!!
Old May 10, 2006, 08:11 PM
The Other Dave is offline
Find More Posts by The Other Dave
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
Why rebuild if it such a tipstaller?
The Other Dave is offline Find More Posts by The Other Dave
Old May 10, 2006, 08:17 PM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
It's just a lesson learnt .... don't fly so slow
Old May 10, 2006, 10:36 PM
The Judge's Avatar
OHIO
Joined Oct 2005
Lesson Learned
Yup, too slow, but I have to rebuild it. You should see the crazy snaps this thing does! It snaps harder than most nitro planes, very inpressive when in the air with 4 or 5 nitro planes, the guys say "did I just hit you?" Ha!
Old May 17, 2006, 06:48 AM
KiwiKid is offline
Find More Posts by KiwiKid
Aeroplanes fly aerobatics!!
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Every once and awhile when I'm watching those guys hovering those ginormous patt ships or bipes I think that it would be kinda cool to see the prop come off, go straight up in the air and the guys flying the plane have to dodge the prop as it comes down - well it had to happen sooner or later:
http://www.tulsarc.com/videos/cat_cr...your_props.wmv
KiwiKid
KiwiKid is offline Find More Posts by KiwiKid
What's the best fully R/C 1/2A engine? thrashaero Engines 1 Jan 07, 2003 08:26 PM
Best charger for <$100? E-Pylet Batteries and Chargers 22 Nov 24, 2002 06:10 PM
How to de-skin bluecor foam in <1 min/side AndrewsJr Foamies (Kits) 12 Apr 16, 2002 05:03 PM
crash picture!!! Mig17 Electric Ducted Fan Jet Talk 24 Feb 06, 2002 01:56 PM
What's your worst/best crash? Vonbaron Electric Plane Talk 5 Sep 30, 2001 06:28 PM
