This thread is privately moderated by genovia, who may elect to delete unwanted replies.
Old Jan 08, 2013, 01:36 PM
BobaFett1138 is offline
Find More Posts by BobaFett1138
Too much to do not enough time
BobaFett1138's Avatar
Wisconsin
Joined Sep 2010
Wing is salvageable, but the fuselage/tail is all 1 unit. So yes, it IS fixable, but I'm not 100% happy with the construction of the wing in the first place. More expedient for me to just make a brand new airplane.
BobaFett1138 is offline Find More Posts by BobaFett1138
Old Jan 08, 2013, 02:14 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I often feel the same way....I'd rather spend 3-4 weeks building a NEW plane than 1-2 hours fixing a crashed one
tailskid2 is offline Find More Posts by tailskid2
Old Jan 24, 2013, 07:48 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Threw together a little light viewing of some crashes from 2012. Micros, park size up to 60 size planes. Was a fun, but damaging, year! Hope someone gets a little laugh out of it.
Marlin
2012 RC Aircraft Crash Compilation (9 min 6 sec)
Fish99 is offline Find More Posts by Fish99
Old Feb 09, 2013, 02:32 PM
flyaboveall is offline
Find More Posts by flyaboveall
United Kingdom, Northern Ireland, Belfast
Joined Nov 2012
This was my second flight with easystar. I had before just little bit of flying with auto-stabilized plane and 1-2 hours on simulator. Here I crashed after two succesful loops, third was tooo low and I lost orientation. Hope, some glue will help now .
flyaboveall is offline Find More Posts by flyaboveall
Old Feb 09, 2013, 02:36 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by flyaboveall View Post
I had before just little bit of flying with auto-stabilized plane and 1-2 hours on simulator....I crashed after two succesful loops, third was tooo low and I lost orientation. Hope, some glue will help now .
Biting off more than one could chew, methinks!! I'd buy the SuperSaver size of glue if I were you....
Colonel Blink is online now Find More Posts by Colonel Blink
Old Feb 09, 2013, 10:37 PM
kwmtrubrit is offline
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
I can see the Sir Winston Churchill backbone showing through here (Keep calm and carry on), but I must say that it might be time to find the bin. Then again, if you do try to breath life back into the bits, more power to you.
kwmtrubrit is offline Find More Posts by kwmtrubrit
Old Feb 10, 2013, 03:00 AM
Joined Nov 2008
I'll agree that it's at the upper end of the damage spectrum but I've seen worse repaired.
Bang on, jolly good show what?
Old Feb 10, 2013, 03:28 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Well, here is one from the other day.... Was flying my UMX gee bee at the park, I managed to clip a tree while flying, which I am pretty sure would have caused a crash had it not been an AS3x plane.... Upon landing, I found it put a 1/8 inch dent about 2" from wing root...
I was a little bummed, but about two min later, it seemed pretty small.... I was practicing rolls, and trying to use some elevator when inverted to keep it from losing altitude. The first try looked great, then I turned and tried it again going the other direction, brain farted and I gave up elevator as soon as I hit inverted, noticed it coming down and, per usual, did what I normally do to gain altitude fast, which is full UP elevator.... unfortunately I was going pretty fast and low, so pulled it in straight down into the asphalt at full speed....
The right wing is being held on only by the flying wires, wheel pant broke in half, front crushed.... Now more good news, I picked up all the bits, and with a little glue, its good as new....ish..... well, its flyable anyway, i hope. At least the motor wasnt damaged, apparently, the rest of the plane broke its fall...
dacaur is offline Find More Posts by dacaur
Old Feb 10, 2013, 04:05 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
who cares about the fram. you got an awesome set of electronics to put into a home brew project
scrub monkey is offline Find More Posts by scrub monkey
Old Feb 10, 2013, 06:29 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Owww, poor little bugger is all smashy.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 10, 2013, 07:44 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Ouch, hard to look at.
microflitedude is offline Find More Posts by microflitedude
Old Feb 10, 2013, 09:25 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Aah yes, the "when inverted down is up and up is expensive" syndrome...
Up&Away is offline Find More Posts by Up&Away
Old Feb 16, 2013, 09:47 PM
Finally got a couple good pics of a pretty bad crash to share :/. Gonna be an ugly repair.
Loss of orientation/dumb thumbs
Old Feb 17, 2013, 10:46 PM
w1nd6urfa is offline
Find More Posts by w1nd6urfa
Too windy to fly? Lets surf
w1nd6urfa's Avatar
Athens, Greece
Joined Oct 2008
The paint scheme doesn't help
w1nd6urfa is offline Find More Posts by w1nd6urfa
Old Feb 18, 2013, 01:06 AM
Correct. The bottom does have grey paint and black stripes but it was getting dark out when this happened and I couldn't tell which way was up. If I make another one it will be bright colors again. Good news is all electronic parts are fine and all servos and control surfaces respond.
What's the best fully R/C 1/2A engine? thrashaero Engines 1 Jan 07, 2003 07:26 PM
Best charger for <$100? E-Pylet Batteries and Chargers 22 Nov 24, 2002 05:10 PM
How to de-skin bluecor foam in <1 min/side AndrewsJr Foamies (Kits) 12 Apr 16, 2002 04:03 PM
crash picture!!! Mig17 Electric Ducted Fan Jet Talk 24 Feb 06, 2002 12:56 PM
What's your worst/best crash? Vonbaron Electric Plane Talk 5 Sep 30, 2001 05:28 PM
