Old Sep 05, 2006, 08:58 AM
Account closed
Joined Oct 2002
John & Christo,
Congrats....as I thought it will zing okay for you...
Just think that's with the 11 X 8 and can you imagine with the 11 X 10...
Wonderful news!
guapoman2000 is offline Find More Posts by guapoman2000
Old Sep 05, 2006, 09:00 AM
oldpilot's Avatar
Australia, NSW, Katoomba
Joined May 2002
Originally Posted by pda4you
Yep that is what I thought....
I wonder if the "other" cowl is a bit longer....it certainly looks more scale.
YES !! The HA Spitfires cowl is 8mm longer than the Ripmax one.
However it fits right onto the Rippers Spit with no modification. See here.
Use the short steel propshaft adaptor (Aeronaut) obtainable from
http://www.aircraft-world.com Part No:-AN-7124-17
Cheers. Paddy.
oldpilot is offline Find More Posts by oldpilot
Old Sep 05, 2006, 09:24 AM
oldpilot's Avatar
Joined May 2002
Good Onya J & C.
Not all maidens go perfectly, but at least you only have minor damage and will soon have it sorted.
Yours is certainly a "Full house Mouse", and with all the extra work you have done on it you had to expect a few "Glitches".
Good luck on the 2nd maiden.
Cheers. Paddy.
Old Sep 05, 2006, 10:38 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Paddy - that is exactly what I need - and the exact amount that I am short!
My collet is a bit long too, as well as the Hyperion motor shaft. All those are killing me...
I will take a look at the short adapter too. Check your PM's!
Old Sep 05, 2006, 02:36 PM
Warbird crazy!
new2rc's Avatar
United States, CA, San Mateo
Joined Sep 2004
Thanks gang .
That bit of under wing damage is barely noticible, but I want to come up with a way to make it look like battle damage from a lucky shot off a 109. Silver covering patch with rivets perhaps?
As it turned out the 11 X 10 provided more than ample power such that, just like the real one, more blades can be used to "absorb" the power. After the next series of tweaks hopefully I will be closer to using that 4 blade.
Have to avoid the nose over though. I may try and set the gear with more forward rake, but with the aft geometry it may not be possible. All part of the fun .
Can't wait to actually use the retracts. This should look great with a nice climb out and scale retracts going up with a 2.5 sec. delay. As a side benefit, there is a bit of differential from one servo to the other lending even more realism .
Still very excited to have a successful fllight under the belt esp. with a FHM (Full House Mouse). That's a keeper Paddy.
John and Christo
new2rc is online now Find More Posts by new2rc
Old Sep 05, 2006, 02:49 PM
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Originally Posted by new2rc
Thanks gang .
John and Christo
I have the perfect way for you to put a "silver patch with rivits". Get some aluminum foil tape from Home Depot(its in the plumbing or airduct section right near duct tape). Now, go to Wal-Mart and buy a dressmakers wheel(its not called that at Wal-Mart, but the associtate in the fabric departmenty should know what you mean). Its a little blue handled tool that has a metal wheel on it with flat like teeth. You cut out the foil tape to the size you want, then flip it over(while the backing is still on it) and run the wheel along the edges to imprint the rivits. Do this on a surface thats a slight bit of give(such as carboard on a counter). If you do this directly on a hard surface, the rivits wont show well. If you careful, you could do it on a couch cushion(dont press too hard).
Here is pic of my B-17 in progress using this technique. Mind you, this was my first attempt at doing stuff like this. I have seen much better jobs. But for what you want, theres nothing to it.
kahloq is offline Find More Posts by kahloq
Old Sep 05, 2006, 05:56 PM
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Originally Posted by kahloq
I have the perfect way for you to put a "silver patch with rivits". Get some aluminum foil tape from Home Depot ......
Been there... done that, and boy do I ever share your pain!
Good idea though!!
Tommy D
Tommy D is offline Find More Posts by Tommy D
Old Sep 05, 2006, 10:50 PM
Warbird crazy!
new2rc's Avatar
Joined Sep 2004
That looks awesome kahloq! Thanks for the tip very cool.
John and Christo
Old Sep 06, 2006, 12:53 AM
oldpilot's Avatar
Joined May 2002
Mike.
I originally had an aluminium adaptor and to make the prop and spinner fit close to the cowl I drilled out the adaptor 8mm. (on a lathe). Unfortunately that weakened it sufficiently that it failed. Not in the air thank goodness.
A better way is to shorten the propshaft 8mm ---best done with a cutoff wheel on a Dremel. If you do that be sure to wrap up the motor good and tight so no metal filings will be drawn into the magnets of the motor. That would spoil your whole day. I now use a steel adaptor.
Cheers. Paddy.
Old Sep 06, 2006, 09:17 AM
pda4you's Avatar
Joined May 2002
Yep I am going to shorten it a bit, that won't get me all the way there. Actually I may just go have a chat with my good buddy Keith Sparks (Sparky) and have him pull me a new "scale" one....
That might be the best solution! They did such a great job on the scale lines everywhere EXCEPT the cowl. Bummer...
Old Sep 06, 2006, 09:22 AM
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Hey Mike... Just woke up. Takin' the spitty to work today and Ill have your measurment.
If Sparky makes a Cowl <made me one for the Formosa II> put me down for one!!
Tommy D
Old Sep 06, 2006, 09:45 AM
the Swamp Fox's Avatar
Wadmalaw Island ,SC
Joined Dec 2003
That tape is cool ,,, A bit off topic , but the smell of that stuff makes me feel a little sick to my stomach anyone else ?
B-17 looking good K
take care all ~
the Swamp Fox is offline Find More Posts by the Swamp Fox
Old Sep 06, 2006, 10:33 AM
pda4you's Avatar
Joined May 2002
Tommy D
Will do - if he goes to the work, I will post it here for all of you...
It will be a good source and top notch as all of his "stuff" is...
Old Sep 06, 2006, 10:47 AM
Joined May 2005
Keep us posted: I am interested as well!!
Richard
OneDayFly is offline Find More Posts by OneDayFly
Old Sep 06, 2006, 12:08 PM
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
take care all ~
Wow.. thats really odd. I never noticed a smell. Used a few different brands of tape as well. Then again I smoked for a lot of years ans sense of smell is not my strong suit.
Yes Mike, put me in line for a cowl. Sparky's FII one worked out real good for me.
Tommy D
Discussion what do ya think about this video? furyflyer2 Foamies (Kits) 2 May 05, 2006 05:19 PM
Discussion What do ya think, JR 10x heli or JR 9303? Bunyan Radios 2 Apr 24, 2006 04:20 PM
Discussion brushless pcw, going lipo 1stimer, what do ya think? snowcrash75 Flying Wings 1 Dec 31, 2005 02:36 AM
What do ya think about that? dad57c Engines 2 Dec 15, 2005 09:15 AM
Mini-Falcon,..What do ya think?,. wackyd Slope 19 Jan 29, 2005 09:41 PM
