Old Aug 27, 2005, 05:46 AM
bmaaa is offline
Find More Posts by bmaaa
Bertrand MICHELS
bmaaa's Avatar
Belgium
Joined Nov 2003
Best micro servo for a small EDF JET
Hello,
I am building a 1000 grammes Electric JEt that need 4 servos: 2 ailerons, 2 elevator.
(Kyosho F16, 4S LiPos, Schuebeler DS30 fan.... )
---> I therefore need to find the BEST servo in the 10 grammes range.
It need to be fast (and strong), but also to have a very accurate neutrol position.
I was thinking Dymond 60, Hitec HS 56., GWS Naro HP, ....
what can you suggest if price is not an issue.
Also, I was wondering : Is a DIGITAL servo really a plus ?? I have found many time that a digital servo has less torke and speed that their analog counterpart !! Why ??
bmaaa is offline Find More Posts by bmaaa
Old Aug 27, 2005, 12:34 PM
scratchandbash is offline
Find More Posts by scratchandbash
scratchandbash's Avatar
Grove City PA basement/park
Joined Feb 2005
With 2 elev servos and independent aileron servos, the HS-55 should be adequate, and is a good servo.
scratchandbash is offline Find More Posts by scratchandbash
Old Aug 27, 2005, 12:37 PM
Pacoson71 is offline
Find More Posts by Pacoson71
6 planes 2 jets 2 helis
Pacoson71's Avatar
United States, MA, Charlton
Joined Sep 2002
Hs 55 will do the trick.
This topic is huge for micro helis and I setteled with 4 Futaba S3103 for My Trex.
Similar #s to the HS 56 and same price too.
Pacoson71 is offline Find More Posts by Pacoson71
Old Aug 27, 2005, 01:33 PM
bmaaa is offline
Bertrand MICHELS
bmaaa's Avatar
Belgium
Joined Nov 2003
Thanks for the answers.
HS55 was indeed one of my choises, but more in the HS56 or HS 65 HB (Karbonite gear flavor).
Are the S56 or HS 65 HB karbonite better than the HS55 ??
also, what do you think about this DIGITAL stuff ? Is DIGITAL really a plus ?? I have found many time that a digital servo has less torke and speed that their analog counterpart !! Why ??
Old Aug 27, 2005, 09:49 PM
Joined Feb 2005
I guess most people here, like myself, have not experimented with digital. As for the Karbonite, I would not pay the extra money, though it is a good idea. For the most part, the gear strength is dependent on the close manufacturing tolerances, which eliminate gear play. Loose gear teeth will always break. I have accidentally back wound HS-55 servos many times. I have a 54" plane hanging from the ceiling, that seems to get its individual alieron servos jarred. I am convinced these little buggers have a precision, strong gear train.
Old Aug 27, 2005, 10:04 PM
Speed is Life is offline
Find More Posts by Speed is Life
Speed is Life's Avatar
FREE Gene!!! Get Banned!!!
Joined Jun 2005
My EDF's with 69mm size fans and lots of watts all use HS-56's for ailerons and HS-81 or HS-85's on elevator.
My Alfa Mig-15 (brushless) has HS-55's and does just fine.
Cheers, Mike
Speed is Life is offline Find More Posts by Speed is Life
Old Aug 27, 2005, 10:55 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Mike- Are your HS-56's the carbonite geared ones, or regular? For a few dollars more, I might try some if I hear good things. So far, they are less powerful, but possibly stronger.
Justin
roccobro is offline Find More Posts by roccobro
Old Aug 28, 2005, 12:29 AM
Joined Jun 2005
Justin
The carbonite ones.....very tight & smooth.....like them a lot. Like you said, just a hair less torque.
Note: my post on the Warbird/K&A F-84 thread, even the carbonite gears didn't survive an assault by a slowstick......
Old Aug 28, 2005, 02:30 AM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Do you have a link to the encounter you speak of? Sounds like... fun!
Justin
Old Aug 28, 2005, 02:43 AM
Joined Jun 2005
Off topic, however......
Nah.....no cool video or anything. Probably should have had the dumbell with the 'stick have to eat crunched fibreglass. Oh well, big sky theory & all that.
For sad pix just find the post on this EDF section about K&A F-84 started by netmechanic and scroll down to bottom.
Best micro servo for a FAAAAAAst plane bmaaa Radios 4 Aug 02, 2006 05:43 PM
What is the BEST MICRO servo (for a JET) bmaaa High Performance 9 Jul 05, 2005 09:32 AM
Question What is the BEST MICRO servo (for a JET) bmaaa Radios 1 Jun 28, 2005 12:38 AM
small, scale fuselage for indoor EDF jet rchant Scratchbuilt Indoor and Micro Models 16 May 13, 2004 06:26 PM
Best micro servo for low voltage? Tapio Radios 4 Aug 28, 2002 08:04 AM
