Old Aug 26, 2005, 04:55 PM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
P-40 Warhawk Motor?
I have just bought a CMP p-40 ARF from Falir in the U.K. The finish on the model is superb and I am keen to find a powerful setup with LIPO's for it. The AUW will be in the region of 8lb.
http://shop.store.yahoo.com/raidente...60arfp40a.html
Any help would be appreciated.
Neil
Neil Guildford is offline Find More Posts by Neil Guildford
Old Aug 26, 2005, 08:18 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Big astro cobalt 40 or a big AXI outrunner - 41 or 53 series maybe.
See their respective web pages for what voltage/current/props to run it on.
http://www.modelmotors.cz/index.php?...%20-%20409%20g)
http://www.astroflight.com/e/env/000...roducts:af-640
Aim for about 7-800W or more if you can afford it.
At 30A that tends towards 8s LIPO
Old Aug 26, 2005, 08:33 PM
TRP is offline
TRP
Find More Posts by TRP
TRP
TRP's Avatar
United States, CA, Morgan Hill
Joined Jun 2002
I was going to say Big Axi or HackerB50 9 - 11 XL
800 - 900Watts is what you are going to need.
How do I know? I had the same question a while back while getting started on this gem: http://www.rcgroups.com/forums/showp...3&postcount=16
Ted
TRP is offline Find More Posts by TRP
Old Aug 27, 2005, 04:46 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Is 100 watts per pound going to enable large loops?
The watts surely change with prop size, so what size prop will give an adequate thrust?
Neil
Old Aug 29, 2005, 06:44 AM
Gonsos is offline
Find More Posts by Gonsos
Gonsos's Avatar
Madrid, Spain
Joined Jan 2004
I have almost finished the P-40 50"
AXI 4130/16
CC PH 60
APCE 14x10
4 packs Polyquest 2600 10C 6S2P 5200mAh
Hitec HS-85BB for ailerons and elevator
Hitec HS-225BB for rudder
Hitec HS-75BB for retract
AUW 6.8 lb
Gonsos is offline Find More Posts by Gonsos
Old Aug 29, 2005, 04:41 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Did the cells need to go all that way back for the CG?
I was hoping to slot them in from under the cowl, where it removes.
Neil
Old Aug 29, 2005, 05:22 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
What I'd like to know is the cost of the brushless motor, ESC and the lipoly's.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Aug 29, 2005, 07:05 PM
TRP is offline
TRP
TRP
TRP's Avatar
Joined Jun 2002
Lookin' good.
Hit those decals/stickers with some 000 Steelwool to dull 'em down a bit if you want to give 'em that weathered look.
Ted
Old Aug 30, 2005, 01:19 AM
Gonsos is offline
Gonsos's Avatar
Madrid, Spain
Joined Jan 2004
Yes
Neil
It was my hope too. Maybe if you can put the rudder and elevator servo in the tail and with lighter batteries you can get it.
Old Aug 30, 2005, 03:22 AM
Gonsos is offline
Gonsos's Avatar
Madrid, Spain
Joined Jan 2004
Originally Posted by TRP
Lookin' good.
Ted
Thanks, I didn't know that trick
Old Aug 30, 2005, 04:59 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
I've ordered the motor (same as you).
I must admit, you've done well on the AUW. I expected it to be as much as 8lb.
I'm going to try 3 packs of 2s 3200 Kokams ie 6S 1P.
Its going to be tricky getting the servos any further back than you have, but maybe the RX battery can be hot glued down the tail (done it before and its still there).
Any chance you can video your maiden?
Neil
Old Aug 30, 2005, 06:47 AM
Gonsos is offline
Gonsos's Avatar
Madrid, Spain
Joined Jan 2004
Neil,
I don't know if we are talking about the same P-40, I have the smaller one.
http://www.cmpairplane.com/p40-50.htm
http://www.cmpairplane.com/p40-140.htm
You are saving 100gr, 3.52oz in your packs if I compare with mine. So if we talk about the same plane yours can be lighter.
I use an old pack 2S 1200mAh Kokam for RX battery, what I'm not sure is if can be safe to put a long cable from the controller to the battery or from the motor to the controller. Also is more weight.
I don't have a video camera but I will tell how it goes the maiden.
Old Aug 30, 2005, 06:55 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
I've the 50, same as yours.
I was thinking about a 1000 Nicad for the RX.
When do you think the maiden will be?
Neil
Old Aug 30, 2005, 07:09 AM
Gonsos is offline
Gonsos's Avatar
Madrid, Spain
Joined Jan 2004
You can save weight if you use an UBEC or cheaper if you use Lipo for RX battery. I think that in this plane it is an investment.
I'm not sure when it will be the maiden, maybe next weekend if I can.
Gonzalo.
Old Aug 30, 2005, 08:31 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Excellent, well good luck. I may have mine ready for the following weekend.
Neil
Can you show me a picture of how you did the canopy and battery access?
Question P-40 Warhawk Willmsy Scale Fuel Planes 1 Jan 16, 2003 06:08 AM
AIRHOGS P-40 WARHAWK tc99 Foamies (Kits) 11 Apr 08, 2002 01:41 PM
P-40 Warhawk FLY or NOT Cosmic Shane Parkflyers 0 May 17, 2001 12:54 AM
A mate for the Cox Viper/ P-40 Warhawk Cosmic Shane Parkflyers 16 May 08, 2001 10:15 PM
