Pusher Jet Power Set-Ups...Need For Speed!
Hey guys,
I'm REALLY feeling the need for speed again! I've been super busy with all my 3D stuff lately and have completely ignored the jet bug that's been lurking inside... I'm completely awed by the number of foamy pusher jets that have cropped up in the last year! Anyway, I'm thinking of revisiting a couple of my older designs in Depron and am looking for input on the various power systems being used now. WAY too many threads to sift through to gleen the info... What are the fastest set-ups being used now (motor/prop/batt.), direct drive and geared? I'm thinking 3 classes. Small - under 12oz. Med. - 16-30 oz. Large - 30 plus oz. Below are some pics of some of my foamy pusher designs that I did about 3 years ago with Fan Fold foam. Wasn't much interest then... This was back when you couldn't even get Depron in the US. How things have changed... I'm thinking about re-visiting the MB339 and Bobcat, but with updated power systems (pusher). I've got tons of ideas for some cool stuff... Any interest in the MB339 and/or Bobcat? I've also dug up my plans for an F-20. I'm thinking of doing it first. Don't know yet though... Anyway, post your successfull power setups here. Hopefuly, we can turn this thread into the diffinitive "Pusher Jet Power Set-Up" thread. Let's see whacha' got guys... MB339 set up - Then Mega 22/20/4 10 cell CP1700 APC 9x6 electric VERY fast, but heavy with the CP cells. Video of MB339 prototype Bobcat set up - Then MF480/Kontronic Fun-400-36 10 cell CP1700 Fast, but heavy... Pusher set-up Mega 16-15-3 8 cell FAU1700 NmH 4.75x4.75 prop fast, but heavy too. Tim H. |
Northwest Ohio
Joined Jan 2002
Hi Tim,
Here's a kit that I am producing called the AeroCat. It's a high performance pusher "Jet" for brushless power. My current favorite power system is a Warp 4, 4 turn motor with a Thunder Power 2100 mAh 3 cell pack. I'm running an APC 6/5.5 E prop and this setup will push the AeroCat to the mid to high 60's. The vertical is simply amazing. It will just about disappear in 12 seconds. The wing span is 32". The Warp motors are also available in 2, 3, 5, and 6 turn versions. My buddy tried a 2 turn in the AeroCat, and we clocked it at 72 mph!!! But that is really pushing the limit for a flat foam airplane. The AUW with that power package is 15 oz. It also slows down extremely well. It's a blast to fly and is a great diversion from 3D. I've included a link to the video: http://modelaero.com/video/Aero5.WMV Regards, Scott www.ModelAero.com |
Northwest Ohio
Joined Jan 2002
Hawker- I'm getting 14 to 16 minutes (approx) from the TP Gen2 2100. It's a strong pack.
Northwest Ohio
Joined Jan 2002
Tim,
Thanks for the comments on the Aerocat. I didn't mean to hijack your thread. I really like the looks of your MB339. I considered a flat foam version of that airplane. However, I am concerned about getting it to balance with a big can motor hanging off the back end. Your thoughts on that, Tim? Regards, Scott |
Ballance was a bit of an issue with the Mega 22/20/4, but the big heavy CP1700 pack made ballance easy. Lipos would not have worked in the proto unless I used a big pack. Lipos will be a challange, but manageable. I'll just have to re-arrange things a bit. The smaller GWS type geqared setup and the Outrunner stuff won't be a problem on the smaller version with a 2100-2400ma 3 cell pack.
Ballance was an issue with the E-Bobcat too. I had to move the motor/fan mount aft a bit to ballance the 10 cell Sanyo 1700 Nimh pack. They were the AU "AA" sized cells so it wasn't too bad. My 3 cell Apogee 4200ma pack ballances it perfectly. Tim |
Tim |
I mid mounted my motor in the EF2000
http://www.rcgroups.com/forums/showthread.php?t=394408 This allowed me to use the correct size pack for 8+ mins wot kokham 3s 1250 (106 gramme) It has a go brushless motor built onto a 3mm carbon prop shaft and uses a cut down 100mm gunther prop 15 amps at 24500 on the bench best guess is approaching 30000 rpm in a dive |
Bill, in what plane you put the Kontronik 400 ??
Bill, in which plane are you using this setup ? Don't you think that the Kontronic 400, at 110 grammes, is quite on the heavy side, and that there should be motors with equivalent power in the 75 grammes range ? The attached chart ( from http://justgofly.com/tech_450TH.htm ) is for a motor that weight only 55 grammes ! I believe that I will give it a try in my TwinJet (2 of them) I am looking for killer set-up for booth, a MicroJet and a TwinJet. |
Yes the Kontronik is relatively heavy but (a) it's what I had and (b) it's rated for 30A continuous / 40A burst and up to 16 cells. So running at 26A on the equivalent of 10 cells it barely even gets warm
| Thread Tools | |
| Mini IFO Power? (need for speed) | The dude | Flying Wings | 1 | Jun 26, 2005 09:05 AM |
| "The Need for Speed" | fly4fun | Foamies (Kits) | 22 | May 16, 2003 03:25 PM |
| Need for Speed - Sirius, Smart, ? | Radek Z | Electric Sailplanes | 24 | Jun 29, 2002 11:20 AM |
| Set-Up Instructions for Speed Demon 202 ESC (Viper Model Products) | Kevin Murray | Electric Plane Talk | 0 | Feb 24, 2002 01:09 AM |
| Need for Speed, 480 race bb timing? | JasonJ | Electric Ducted Fan Jet Talk | 1 | Nov 13, 2001 12:29 AM |
