Old Aug 25, 2005, 07:07 PM
mildewing is offline
Find More Posts by mildewing
Salem, Oregon
Joined Mar 2005
E-Flite 4in1 with tail servo?
Well i'm attempting to get a 3D Pro with a shaft driven tail to work with an E-Flite Blade 4in1 and Tx.
I tried to just plug the tail servo into the #4 port on the 4in1's Rx and it doesn't work, when i move the Tx stick the servo doesnt do anything. Is there any way i can get the 4in1 to control the tail servo? What would happen if a put a seperate gyro on to run the tail servo?
Thanks!
mildewing is offline Find More Posts by mildewing
Old Aug 25, 2005, 08:06 PM
Salem, Oregon
Joined Mar 2005
It looks like a no go. When i was trying the seperate gyro i noticed that what i thought was ch4 on the rx was actually ch5 so i don't even have a ch4 option. Besides the ch5 that does nothing, there is a ch B that gives power but it doesnt operate the servo on input.
Old Aug 25, 2005, 09:25 PM
tps is offline
tps
Find More Posts by tps
tps
New Jersey
Joined Jan 2004
I have an ESKY Honeybee CP. If the electronics are the same on the Blade, which I believe they are, try disassembling the 4 in 1 and unplug the rx from the esc/gyro board. On the Esky, channels 3 and 4 are fed directly to the esc/gyro and are not even accessible without disassembly. Once you do this, the rx half is just a basic 6ch rx. I'm actually using mine in a new X-400 i just built.
Good luck
tps is offline Find More Posts by tps
Old Aug 25, 2005, 09:27 PM
tps is offline
tps
tps
New Jersey
Joined Jan 2004
I have an ESKY Honeybee CP. If the electronics are the same on the Blade, which I believe they are, try disassembling the 4 in 1 and unplug the rx from the esc/gyro board. On the Esky, channels 3 and 4 are fed directly to the esc/gyro and are not even accessible without disassembly. Once you do this, the rx half is just a basic 6ch rx. I'm actually using mine in a new X-400.
Good luck
Old Aug 25, 2005, 09:56 PM
Salem, Oregon
Joined Mar 2005
I have taken it apart before and they are the same but, i need to use the ESC out of the 3in1 side to run the main motor.
Old Aug 25, 2005, 11:15 PM
Salem, Oregon
Joined Mar 2005
Ok, i ended up transplanting an ESC from one of my other helis and puled the Rx out of the E-Flite 4in1.
Thanks!
Using an E-flite EFLA104 with Lipos? steve crewdog Power Systems 0 Dec 15, 2005 09:56 PM
4 in 1 with a tail servo and gyro possible? cat5 Micro Helis 6 Nov 15, 2005 07:45 PM
E-flite motor with jeti controller William164 Electric Plane Talk 1 Nov 04, 2005 07:55 PM
ESKY and E-Flite 4in1's ? mildewing Micro Helis 5 Jul 10, 2005 10:57 PM
Need help with tail servo waug Electric Heli Talk 3 Jan 10, 2005 11:26 PM
