Old Aug 24, 2005, 01:24 PM
kraker89 is offline
Find More Posts by kraker89
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
any idea whats up with my charger?`
i have a gp poly charge charger and every time i try to charge my battery (a 3s 640 mah pack for a flat foamie) after it detects the cell count for about 5 mins it beeps like mad and the led flashes 3 times. it says in the manual that it means theres a "voltage error". what does this mean exactly because the intructions say nothing more about it. and what can i do to remedy this. i think it might be thinking that its an overcharged 2s pack because my speed control (electrifly c-12) has a low voltage cut off of 2.75v per cell and it cut the power on the last flight. so at 8.25v per cell (i know thats bad) could it possibly think its an overcharged 2s? anyways any help would be appreciated
thanks in advance
kraker89 is offline Find More Posts by kraker89
Old Aug 24, 2005, 01:32 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
What is the voltage of the pack?
Old Aug 24, 2005, 01:50 PM
kraker89 is offline
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
its a 3s 11.1v pack
Old Aug 24, 2005, 01:55 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
No what is the actual voltage of the pack......
Old Aug 24, 2005, 01:59 PM
kraker89 is offline
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
oh well when metered from the charge leads i get 10.5v which is odd because the low voltage cut off cut the power to my battery in flight.
Old Aug 24, 2005, 02:06 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
No the resting voltage will be much higher than LVC as the voltage rebounds quickly. It is still "discharged" as when the load applied will drop quickly again.
That voltage is fine, it should charge. Have you tried another battery? Have you tried another port?
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
Does the charger work okay for other packs?
If may just be that the charger doesn't like the voltage because it considers it to be in a "gray" area. Perhaps if the charger isn't absolutely positive about the cell count, it won't charge.
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Aug 24, 2005, 02:10 PM
kraker89 is offline
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
yeah im charging a 2s 1200 mah pack at the moment so the charger works... and its the polycharge $25 dollar one lol only one port
if the battery is in the "grey area" is there anything that i could do to get it out of that so it will charge?
Old Aug 24, 2005, 02:21 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Yes but not with that charger. If you had one you could select a different battery type and a very low charge rate and do an attended charge for 10 minutes or so, to boost the voltage a bit. This obviously has to be an attended charge as you are defeating all the safety features of that charger.
But since the single Poly charge does not have other battery support, you will have to borrow one from someone....bummer I know.
Old Aug 24, 2005, 02:26 PM
Scott_NJ is offline
Find More Posts by Scott_NJ
RC Geek
Scott_NJ's Avatar
United States, NJ, Stanhope
Joined Dec 2004
What are you using for a power supply? I am guessing if its charging a 2s pack with no problems but giving a voltage error on a 3s that the power supply may not be putting out enough Voltage, or Watt's to keep the charger happy.
_Scott
Scott_NJ is offline Find More Posts by Scott_NJ
Old Aug 24, 2005, 02:31 PM
kraker89 is offline
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
i happen to have a charger for nicads that can do 300mah rate would it be ok to charge for perhaps 5-10 mins on that?
Old Aug 24, 2005, 02:35 PM
Joined Apr 2004
What Mike said.
You could use a nicad charger, or a 12 volt power supply and a resistor, or almost anything that will allow you to put a little more charge into the pack to get it up to 11 volts or so. DO NOT walk away from it while you are putting in this charge.
Dan
Old Aug 24, 2005, 02:37 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Yep what Dan said...
that 300mAh rate also needs to have a charge voltage output of 11v-12.4v or so. Otherwise it won't charge the battery at all. It is is much above 12.4v I don't know that I would use it either.
I would prefer a 100mA rate on the 640mA pack.......
Old Aug 24, 2005, 02:40 PM
kraker89 is offline
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
yea its a 12v out 300 mah i have like 2 or 3 that are 9v out that put out 100mah but i dont think that will work for my battery...
Old Aug 24, 2005, 02:46 PM
kraker89 is offline
kraker89's Avatar
Waxhaw, NC
Joined Mar 2005
allright well i did 5 mins on the 12v 300mah charger and it put the voltage right around 11.45v so hopefully the charger will detect it now
Discussion whats up with my HB? marsman711 Micro Helis 3 Jul 13, 2007 06:44 AM
Discussion Whats up with my old school packs?? JONBOYLEMON Batteries and Chargers 10 May 27, 2007 02:03 PM
Help! Help whats up with my motor? scottypotty Electric Motor Design and Construction 2 Mar 23, 2006 11:44 AM
Help! wacked up esc/motor... WHATS UP WITH MY MOTOR? lift off Power Systems 2 Apr 21, 2005 06:01 AM
Whats up with my new 1200 HP pack???? Speedfreak Batteries and Chargers 1 Jan 24, 2005 08:46 PM
