Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old May 04, 2002, 08:44 AM   #1
Leave well enough alone and other old adages we ignore.
Why does it seem everytime I try to "improve" a plane that flies just fine I end up making repairs, uh, I mean modifications? Judging by the posts I read I'm in good company.
captain crunch is offline Find More Posts by captain crunch   Reply With Quote
Old May 04, 2002, 09:23 AM   #2
Well, guess we just have to prove the "old Adage".
Besides, if it can go wrong, it will.
Just my 2 cents.
DBCherry is offline Find More Posts by DBCherry   Reply With Quote
Old May 04, 2002, 10:04 AM   #3
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
RE INVENT THE WHEEL
I often wonder why guys will take a great flying 3 channel model and put ailerons on it, when it was designed to be flown 3 channel in the first place. Had a buddy do that to a great flying model and all but ruined it. It now hangs in his garage, never to fly again. Do we know more the the designers? Tom
Tom Smith is offline Find More Posts by Tom Smith   Reply With Quote
Old May 04, 2002, 01:09 PM   #4
Not usually. But sometimes it does pay off. Like putting ailerons on a Sig Kadet Sr.
It's not necessarily that a plane flys better, but that it flys differently, or is capable of different things with ailerons. Usually requires the removal of some dihedral though.
Old May 04, 2002, 01:49 PM   #5
Tom Smith's Avatar
Exactly what my buddy did. He left the dihedral the same and added ailerons. The setup didn't work worth a darn, and added so much weight and drag that the OS 10 was no longer able to pull it along safely. Darn shame, I flew it on R,E,M, for years and it flew fine. There is now a guy in my club trying to put ailerons on a Wingo. I just walked away when he told me that. Tom
Old May 04, 2002, 02:49 PM   #6
an earth bound misfit, I
Silver Member
Basketcase's Avatar
Hi Tom, it doesn't always have to result in a ruined plane. I'm not claiming I know more than any designer, in fact I know nothing about anything.
But after flying my GWS Tigermoth with R/E/T I always felt something looked wrong when it turned. After rudder is applied it yaws then banks, then turns. It's not 'right'.
So when I built a Hobby Lobby Stearman PT-17 I removed the dihedral to full scale specs and added ailerons. The wings are slightly undercambered. A lot of folks advised that they would not work or would cause adverse yaw. Happily this is not the case. It flies great. And the turns look much more scale than the turns by the 'moth.
It's not real aerobatic but will do a nice barrel roll and (at least to me) looks very scale like cruising around in a Stearman like fashion.
I'm very happy with my aileron conversion and would do it again.
BC
  • Name: 0st_pic_600.jpg
Basketcase is offline Find More Posts by Basketcase   Reply With Quote
Old May 04, 2002, 08:44 PM   #7
Tom Smith's Avatar
Nice paint scheme. I have one too, but I built mine stock. It flies great on a speed 300 geared 4:1 using 7, 500mah nimh cells. One of my favorite planes. Tom
Old May 04, 2002, 09:38 PM   #8
Oh Jeez.... Now I have to start thinking about ANOTHER plane!
Old May 04, 2002, 09:50 PM   #9
Crazy Cessna Owner
Robbie d's Avatar
Wow, that is the best small scale Stearman I have seen. As to adverse yaw, that all depends on the throw of the ailerons. Makes a nice alternative to al the TM's flying around.
Robbie d is offline Find More Posts by Robbie d   Reply With Quote
Old May 04, 2002, 10:15 PM   #10
Silver Member
Basketcase's Avatar
Thanks for the kind words everybody.
Tom, it's good to hear you have one too. It is a pretty biplane.
I'm using the HL recommended 300 motor also, except with 8 cell 800 mah NiMH packs.
Robbie you're probably right, I was worried about adverse yaw and dialed in differential using 2 servos and epa settings. Never tried it with equal movement both ways.
In addition to the dihedral and ailerons, I cut the battery hatch in the bottom, redesigned the landing gear and bulkhead and made the wings removable, and don't really feel I messed it up.
I never flew it stock so can't really compare but can't image it would fly better without the ailerons.
BC
How old are we all? mrfirkin Micro Helis 148 Dec 26, 2004 09:48 PM
what material would mill well enough to make a mold? annihilator Composites Fabrication 31 Sep 05, 2004 01:02 AM
How old are we, just making a poll biors Micro Helis 7 Jun 20, 2004 07:58 AM
FA: 40FP, cox, Goldberg Jr Falcon and lots of other old kits, engines, etc.... annmarie cross rec.models.rc.air 0 Dec 10, 2003 04:00 AM
A question for other old farts Geoff Sanders rec.models.rc.air 25 Sep 07, 2003 03:00 AM
Bored? Want to fight?
Join the RCGroups clan!
