Old May 04, 2002, 01:07 AM
SoulShell is offline
Find More Posts by SoulShell
SoulShell's Avatar
Cincinnati, Ohio
Joined Apr 2002
Speed 280 Ball Bearing Soldering
I have a question about soldering wires to my speed 280 BB motor. On the back there are two loose copper wires. What do I do with these? Also, is it ok to get solder on the posts that are near the terminals? These posts have a spring around them. Those of you who know what the back of a 280BB looks like should know what I am talking about. HELP!!! Thanks.
Nick
P.S. If any of you have a picture you could post that shows me that would be great too.
SoulShell is offline Find More Posts by SoulShell
Old May 04, 2002, 02:04 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Here you can see everything. Wires, Capacitors and ESC. Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 04, 2002, 07:12 AM
ifxmnfly is offline
Find More Posts by ifxmnfly
Born in the USA.
ifxmnfly's Avatar
USA
Joined Mar 2001
Soldering on the can
Nice piture Jurgen! I zoomed in and adjusted the brightness/contrast so I could see the soldering on the can. Your soldering is a lot tidier than I've been able to get on these cans. What wattage of soldiering iron do you use?
I attached the image in case anyone else wanted to see it too:
ifxmnfly is offline Find More Posts by ifxmnfly
Old May 04, 2002, 10:14 AM
Joined Sep 2000
I use an old ERSA pen type soldering iron - 15W only. Jürgen
Old May 04, 2002, 04:12 PM
SoulShell's Avatar
Cincinnati, Ohio
Joined Apr 2002
Thanks a lot. This has helped me out a great deal!
Old May 04, 2002, 06:10 PM
ifxmnfly is offline
Born in the USA.
ifxmnfly's Avatar
USA
Joined Mar 2001
15 watt Iron
Yeah! Thanks Jurgen.
Now there is a new tool I need to get. Uh ... could you explain this to my wife?
Old May 04, 2002, 10:53 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
I have no use for the soldering guns to big, with the pen type you can sit it on the bench and use two hands to solder wires together would be ok for doing packs with a big tip.I have a new gun someplace that has never been used.
russ6421 is offline Find More Posts by russ6421
Old May 05, 2002, 06:34 PM
I FO nut is offline
Find More Posts by I FO nut
Lazy sob
I FO nut's Avatar
Rural retreat, Virginia
Joined Apr 2002
jurgen
So you solder the loose copper wires to the ESC leads and in turn solder both to the motor terminals? Am I getting this right!? I couldn't quite tell from the pic.
I FO nut is offline Find More Posts by I FO nut
Old May 06, 2002, 10:33 AM
Joined Sep 2000
ESC wired, copper wires and capacitors, all soldered to the terminals of the motor. A bit tricky, but with the right tools - no problem. Jürgen
Sold Great Planes Speed 380 Ball Bearing with Gearbox Twmaster Aircraft - Electric - Power Systems (FS/W) 2 Jul 08, 2007 11:16 AM
Graupner speed 700 Ball Bearing with speed control stealthy Aircraft - Electric - Airplanes (FS/W) 5 Apr 23, 2005 07:44 PM
FS: 2 Speed 280 motors and ball bearing gear boxes - $20 for both Ben Lanterman Aircraft - Electric - Airplanes (FS/W) 2 Jan 05, 2005 07:00 AM
MJ8043 5:1 Gearbox for SPEED 300, Ball Bearing jim mathis Aircraft - Electric - Airplanes (FS/W) 3 Jun 08, 2004 06:30 AM
MPI dual ball bearing gearbox for speed 400 Steve H. Aircraft - Electric - Airplanes (FS/W) 4 Apr 10, 2002 11:25 AM
