Old Aug 22, 2005, 07:08 PM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
Yippee!
The Ghost. A micro rigger with GB power!
I wanted to make a small rigger that was cdrom powered, but as usual I didn't manage to keep it normal...
She's almost done now, missing turn-fin and rudder.
My plan is to use a thin curved lexxan plate for the top hatch after adding a charge-port with balancing function and two air-plugs in case it needs drying out inside.
Motor is way too big for the size, especially since I only run a 10 amp ESC.
Will probably swap out motor later for a single stack and use a kokam 340.
The ESC is a Phoenix 10 wich I have sprayed with PRF 202. (waterproofing it)
Regardless of how I went overboard on this one, it will be immensly fun.
Weight is 172g now. Only a few tidbits to go. Will make sure I have video for maiden, just in case.
KreAture is offline Find More Posts by KreAture
Old Aug 22, 2005, 07:09 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Oh, and motor is a 6t GBx3 with tripple 26ga wire. It does 15210 rpm on a not topped off 3s 700 mAh LiPo sucking 1.2 amps idle.
Old Aug 22, 2005, 09:44 PM
DEATHWISHINC is offline
Find More Posts by DEATHWISHINC
DEATHWISHINC's Avatar
United States, IL, Jerseyville
Joined Aug 2005
Where can i find the thing's you secured the prop onto the shaft and what are they called. Thanks for any help you can gave.
DEATHWISHINC is offline Find More Posts by DEATHWISHINC
Old Aug 23, 2005, 12:54 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
The inner thing is called a drive-dog. It usually comes in a set with a blocing collet thingy. Together they are usually just called propeller stopper or similar. Kyosho part number 94444 is 4mm type. I used the wall of a fanta-can rolled up to stuff out the diff between 3mm shaft and 4mm prop system.
Old Aug 26, 2005, 02:35 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Update! It runns!
Weeeee.
Here's a video of hos smooth the shaft runns:
http://www.kreature.rchomepage.com/b...tshaft_big.mpg
Here's a vido of the boat in action:
http://www.kreature.rchomepage.com/b..._rigger_01.mpg
Any tips on imporvements would be greatly apprechiated. Looks like it digs in a bit on right sponson? Also, I think I need to beef up rudder as it seems to oscillate abowe 70% throttle.
Old Aug 26, 2005, 03:25 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
It looks a lot of fun The problem with boats that size (it looks twice as small in the video) is that there usually very sensitive to adjustments. Did it go right under water towards the end?
martin richards is offline Find More Posts by martin richards
Old Aug 26, 2005, 04:44 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Yes it did!
Either I jolted the throttle, or I snagged something under water.
I kept it in the video because it was funny LOL.
The hull is shaped so that if it pulls under it will not pop back up under power as it digs in deeper... Not best design probably, but looked good
The prop is a 42mm dia, 1.6" pitch one so it really twists the boat too. WOT = 15k rpm, 8 amps.
I am deffo sure I need to do something about rudder though.
Old Aug 26, 2005, 04:51 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
kre, the Ghost looks the biz, looks like it will give a graupner ecospeed racer a run for its money. congratulations on a first run
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Aug 27, 2005, 02:38 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
The rudder tube looks fairly short. If there's anyway to make it 5 mm or so longer it should help to support the rudder better.
Old Aug 27, 2005, 05:31 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Here's piccys of the rudder.
As you can see, the ammount of area to attach anything to on the rear there is very limited. I think I need to beef up the plate I attach to the rear.
Then I can beef up the rudder.
The sharkfin on rudder was in case I flipped, to try and keep some control.
Rudder can turn till hitting the shaft and out same distance other way.
I was planning 2-3mm FG for the mount-plate and 3mm FG shaped like a wedge for the rudder. The new mounting plate needs to extend further back from the boat to give the linkage room for gentler flexing, Also the rudder needs to be larger I think.
Old Aug 27, 2005, 08:11 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
Whats the rudder blade made of? Could it be flexing itself rather than slop in the linkages? That would be consistent with the effect being more evident at full speed.
Old Aug 27, 2005, 02:13 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Yes. I made a better rudder with 3 laminated 1mm FG plates and sanded it to a razor-sharp wedge. New rudder is 1" deeper.
I also made a new mount that holds the rudder a bit further out to right and back to help linkage.
It seems very nice but still not great. Having rudder before prop seems to make it very weak. Maby I should use a rudder up front at the sponson ?
The tail seems to track well and maby it should only have a blade to help it against the prop travel.
It ran much better now. Vide will be coming up later tonight!
Old Aug 27, 2005, 08:02 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Video is UP!
http://www.kreature.rchomepage.com/b..._rigger_02.mpg
It's 23 MB almost 4 min long.
The new rudder really helped, but I want more authority on it.
Old Aug 27, 2005, 09:18 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Here's some in-action shots grabbed from the raw video off camera
Theese should be great for seeing what can be tweaked.
Old Aug 28, 2005, 09:16 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
New prop balanced...
I made myself a simple yet very accurate prop balancer to balance the new Prather s215 prop. It turned out quite ok I think.
Here's a piccy of the balancer and prop. Should have used thicker balsa as the mags pulled tight to the shaft
Anyway, I just cross-braced and it worked great.
Prop is as mentioined a Prather s215 which is a 1.6" diameter, 2.5" pitch prop.
I was using a plastic Kyosho prop measuring 1.6" diameter and 1.6" pitch so maby this will give me more speed... I know the motor has enough torque so I'm not worried about that.
Any other tips for me on how to fix the sponsons digging and the weak rudder ?
Video Micro L-39 with 180W Power Chris T Electric Plane Talk 3 Oct 08, 2006 12:55 PM
Micro-Canard Design with Diversion Power/Control System Canard Flyer Scratchbuilt Indoor and Micro Models 8 Jul 19, 2005 06:38 PM
Home made micro heli with GWS IPS power kwan Micro Helis 16 Jun 15, 2003 11:09 PM
Revolutionary micro heli with 5" blades! gpeden Electric Heli Talk 18 Aug 07, 2001 08:07 PM
The CP Micro Heli with Flybar - Practical Theories Mario Electric Heli Talk 32 Jul 05, 2001 12:01 AM
