My setup is going to be a pusher (motor is mounted in those pictures), the reasoning is for a camcorder mount I'm going to laser cut and put in between the front landing gear.
But anyways, on an earlier stick I've used the same pusher mount and needed the two long booms because even if the battery is mounted far at the nose and I used the stock light tail setup, the wing was too far towards the rear. The two long booms instead of one long and one short means there's a little more weight, but a lot more space between the wing and the tail section so pitch-wise it's more stable |
![]() Razor, do you have the camcorder already? Maybe that will make for enough nose weight to shift the wing forward a few inches. |
Making your own LEDs takes work, but the results are worth it... I think the light strips also tempt you to go overboard (the foamy bomber was so bright it made my eyes water and I couldn't fly it.) |
| Thread Tools | |
| The Ultimate Slow Stick Help Thread - Part 6 | Ron H | Beginner Training Area (Aircraft-Electric) | 544 | Feb 16, 2005 09:59 AM |
| The Ultimate Slow Stick Help Thread - Part 5 | boomerace | Beginner Training Area (Aircraft-Electric) | 793 | Sep 13, 2004 08:01 AM |
| The Ultimate Slow Stick Help Thread - Part 4 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 824 | May 31, 2004 01:00 AM |
| The Ultimate Slow Stick Help Thread - Part 3 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 639 | Apr 11, 2004 11:17 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
