Old Nov 30, 2012, 10:37 AM
branflakes is offline
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
Was linked here from another thread
Thought it might be helpful to know how to reinforce a stock tail assembly in a way that is stronger, lighter, and freer than any vert stab reinforcement I've ever seen
Cut six inches off spare ss metal pushrod, on the z bend side
Drill hole through rear fuse
Insert z bend, epoxy into hole, tape rest of wire up against surface of tail
Unbelievably strong, enjoy, its all you need
branflakes is offline Find More Posts by branflakes
Old Nov 30, 2012, 11:33 AM
Razor_Racer is offline
Find More Posts by Razor_Racer
Actively makin humans obsolete
Razor_Racer's Avatar
Northern Virginia
Joined Jul 2007
My coroplast tail setup! It can take quite a beating. V-tail plywood mounts from radicalrc
Razor_Racer is offline Find More Posts by Razor_Racer
Old Nov 30, 2012, 11:49 AM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
Originally Posted by kaptondave View Post
Where does it say this is only for beginners? I have been flying for several years and still consider the Slow Stick as a favorite, but mod them to the extreme. Mods are not needed but sure add to the enjoyment. Here is one of mine. Upgraded airframe with CF stick and landing gear, upgraded motor, Millennium SSX wing and tail feathers, lots of Radical RC goodies.
That contraption isn't a SlowStick. Some kind of parkflyer maybe?
Gohmer is offline Find More Posts by Gohmer
Old Nov 30, 2012, 05:18 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Really? It started out as a Slow Stick NPS kit. All of the mods other than the CF gear struts use parts that are designed and marketed by Millennium RC and Radical RC specifically for the purpose of modifying and upgrading the Slow Stick. At what point did it cease to be a Slow Stick? What are the rules that must be followed?
kaptondave is offline Find More Posts by kaptondave
Old Nov 30, 2012, 05:24 PM
bubbleman is offline
Find More Posts by bubbleman
bubbleman's Avatar
United States, TN, Cornersville
Joined Jan 2007
Really? It started out as a Slow Stick NPS kit. All of the mods other than the CF gear struts use parts that are designed and marketed by Millennium RC and Radical RC specifically for the purpose of modifying and upgrading the Slow Stick. At what point did it cease to be a Slow Stick? What are the rules that must be followed, and who makes them?
+1 Dave
I am as guilty as any of not building a "pure" slow stick.
Anton
bubbleman is offline Find More Posts by bubbleman
Old Nov 30, 2012, 05:26 PM
Bill0 is offline
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
Whats a pure stick? I have three of them and they are all modded. Stock WAS fun, modded they are really fun.
Bill0 is offline Find More Posts by Bill0
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Well, it does have a stick.
Raften is offline Find More Posts by Raften
Old Nov 30, 2012, 06:25 PM
carlsoti is online now
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
kaptondave's plane is most certainly a "stick." It's probably not slow, though. An evolution on a design, for certain. The SSX wings can be built with dihedral, and the flapperons can be slightly cambered (think tiny bit of flap) to make them fly more like an original slow stick, and still be much more sporty than it, too.
carlsoti is online now Find More Posts by carlsoti
Old Nov 30, 2012, 08:17 PM
phoam is offline
Find More Posts by phoam
fly 'em if ya got 'em!
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
When you replaced everything on it? Lol let's face it, you didn't modify your Slow Stick NPS parts, you outright replaced them, all of 'em. What you have is simply known as an SSX, not to be confused with a GWS SS.
There is a whole thread on them in the Millennium vendor forum.
I really need to get around to building my Micro SSXs I got in 2010
phoam is offline Find More Posts by phoam
Old Nov 30, 2012, 08:27 PM
Northern Virginia
Joined Jul 2007
I made landing gear today! For the tail I laser cut a tail wheel bracket. For the front gear I modified some of the same landing skids for quads.
Currently waiting for another 800mm long boom section because the stock 800+200 is too short for this beast!
Old Nov 30, 2012, 08:29 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Not wrong, but I should have said "as effective". Of course ailerons will work on a wing with dihedral. Look at a Piper Cherokee for example, which has a moderate amount (about 6 degrees) of dihedral. However, dihedral tends to make the wing self-leveling, which is why it is used on trainer RC airplanes such as the SS. A flat wing with ailerons tends to hold a bank angle, but dihedral works against that.
I have three SSs, one having a flat wing with ailerons and two with the standard 12 degree dihedral with no ailerons. All three fly nicely but the aileron ship is crisper.
Fair enough. metalwizard, there is no war here.
Ron H is online now Find More Posts by Ron H
Old Nov 30, 2012, 08:31 PM
phoam is offline
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
You're aiming for a 1600mm total length?
Old Nov 30, 2012, 08:32 PM
Northern Virginia
Joined Jul 2007
Is it that crazy?? right now to get it to balance my trailing edge of the wing is about 4 inches from my v-tail
Old Nov 30, 2012, 08:50 PM
phoam is offline
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
Ha, well, I'm not implying that it won't work, but you might not need the full length of that second 800mm fuse to get it to balance OK. Heck, maybe the full length would do a pusher some good anyway. Alternatively, you can use a heavier batt for the nose weight. Or just stick a camera on the nose.
Old Nov 30, 2012, 08:55 PM
Ron H is online now
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Maybe carlsoti will chime in here, but I don't think short coupling with a V- tail works very well.
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 09:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 08:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 11:17 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
