so the 5th servo would be for camera pan. cool. I leave the stock "V" to the wing with my SS equipped with ailerons. The trick to learn rudder control on a USA mode 2 transmitter is to fly with just the left stick as a 2 Chanel. With proper trim a SS Will climb with increase in power and descend with decrease in power. Impress you flying buddies by doing figure 8's and such with your right hand in your pocket
Kafie, don't forget to grab an external BEC, as the integrated linear BEC of the HURC 18A ESC will not be up to the task to power all them servos.
http://www.headsuprc.com/servlet/the...Battery/Detail I would also recommend a 400- or 450-size motor over the 370. Something with a low enough kV to swing a 10" prop. Slow Sticks like big props. |
Chris |
Joined Jan 2010
I agree with Phoam about the 400-size motor, especially with the added weight you plan to carry, and a 10 x 4.7 prop. Get a few extra props. A spare motor would be a good idea also if your supply line is long.
You don't need an external BEC. Counting servos is not a valid argument. You will never have all six servos active simultaneously. |
Change in parts list
Power Up 450 Slofly Outrunner Brushless Motor HURC 22 Amp Brushless Motor ESC 15x GWS 1047 Propellers ONE GRAY 10" Slow Fly Prop Im moving from a 4 ch war bird that was never made for a begginer or any one with out flying and airplane setup so im hoping its a bit easier haha |
United States, FL, DeLand
Joined Mar 2009
I'd change one thing. Get rid of that GWS prop. An APC slow fly prop will get you significantly more efficiency. At higher RPM the GWS props get excessive blade flutter, giving you wasted amps from increased drag with no increase in thrust. A study by a prominent university singled out GWS props as notably inefficient.
He intends to use only five servos, but anytime you're making a cordinated turn using rudder + elevator + ailerons, power is being supplied to four servos, and that's enough to overload a linear BEC. It's been said that those 9-gram servos are kinda power-hungry too. Personally, I wouldn't run more than three servos off of a linear BEC, no matter if they are used simultaneously or not. I like to elimate the likelihood of a brownout.
| Thread Tools | |
| The Ultimate Slow Stick Help Thread - Part 6 | Ron H | Beginner Training Area (Aircraft-Electric) | 544 | Feb 16, 2005 09:59 AM |
| The Ultimate Slow Stick Help Thread - Part 5 | boomerace | Beginner Training Area (Aircraft-Electric) | 793 | Sep 13, 2004 08:01 AM |
| The Ultimate Slow Stick Help Thread - Part 4 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 824 | May 31, 2004 01:00 AM |
| The Ultimate Slow Stick Help Thread - Part 3 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 639 | Apr 11, 2004 11:17 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
