Old Dec 05, 2012, 12:26 AM
phoam is offline
Find More Posts by phoam
Boogity boogity shoo
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
Originally Posted by aurorae View Post
Great work!
I did something similar, but your's is way nicer than mine.
I ended up with an overall design very close to yours. Including the one servo for the rudder, and the support between the two sticks where you mounted a camera. My support is just a stiff wire, though.
I think you will like flying it. Mine uses 2 1300 3S batteries, and 400 size motors and 8 inch props, and flies quite well at half throttle.
Mine weighs in at 49.40 ounces. That's AUW with a couple 3S 2200s. Camera included: 53.90. However, it's got a staggering 788" wing area that makes for a decent 9oz/sq.in. wing loading. I am really looking forward to taking it for a spin.
Still need to devise a method of remotely triggering the camera in flight, which will probably just consist of mounting a servo to the cam with double sided tape to trip the shutter. Originally I was gonna use a small digital camera with an intervalometer so that I can set it to snap a pic at any given interval, but they're more hard to find than I thought. The servo method is the way to go anyway as it would eliminate a lot unwanted shot.
Do you run your batts in parallel?
Do your motors spin the same direction or do you feel the need to counter spin one another?
phoam is offline Find More Posts by phoam
Old Dec 05, 2012, 03:12 AM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
One of the easiest ways to trigger a camera is a GentLED. I use one with a Pentax Optio S10.
chris1379 is offline Find More Posts by chris1379
Old Dec 05, 2012, 11:19 AM
phoam is offline
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
Yeah thanks Chris. My particular cam is not comparable with 'em, but I assure you my next one will be.
Do you shoot pics from your SS?
Old Dec 05, 2012, 09:59 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
I plug one battery into each ESC.
Same direction. I don't think I would notice any difference with counter rotating props.
aurorae is offline Find More Posts by aurorae
Old Dec 06, 2012, 10:23 AM
phoam is offline
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
I'm plugging each battery into their own respective ESC too, but I would probably sleep easier at night if I run balance wires from one ESC to the other. This would ensure that the motors will spin at the same RPM even if the two batteries' charged values varies a bit from one to the other.
Old Dec 07, 2012, 12:11 AM
aurorae is offline
aurorae's Avatar
Joined Sep 2008
I think it is pretty forgiving. With all that wing it can't fly very fast. So I don't think you need to worry to much that the rpm is exactly the same. As long as the motors and props are identical, you'll be good.
Old Dec 09, 2012, 05:17 PM
Bernip is offline
Find More Posts by Bernip
What The...
Bernip's Avatar
Greensburg IN
Joined Sep 2003
Took it up today.
Thanks to all who posted in this thread and elsewhere.
Just got it together enough to fly it. Still need to sort a couple of things out and add a camera. It was a miserable day today. Rainy with a 10 to 15 mph wind but I walked outside about noon to find the wind at almost zero and not actively raining so I strapped on the battery and had at it. I have the wrong prop on it its about a 10x7 apc on the turnigy 480 850kv. Only pulls about 11 amps full throttle but it had plenty of power. Once I prop it up correctly It should really haul some freight. It is almost completly aftermarket. The only stock parts are the wing foam and one main wheel I used for the tail wheel. I think the wing is warped a little as it wants to turn right power off and it takes almost full left trim to get it to glide straight. But it was sitting in a shed for about five years so I kinda expected it although I cant really see it by eye.
I got it a little muddy landing in the field but it was a lot of fun.
Description:
Description:
Bernip is offline Find More Posts by Bernip
Old Dec 09, 2012, 06:28 PM
chris1379's Avatar
Joined May 2006
I did a lot at first but don't have much time to fly these days with my hours at work. I like to find interesting scenery and then hunt up a landing spot nearby.
Old Dec 09, 2012, 11:41 PM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Whoo Hoo! Page 1000. Neato.
Moonbeam is offline Find More Posts by Moonbeam
Old Dec 10, 2012, 09:41 AM
SOOFLY is offline
Find More Posts by SOOFLY
United States, SC, Greer
Joined Nov 2012
I'm just about finished with my slow stick and wanted to check with guys on preferred CG of this plane. The manual says 95-100mm from the LE.... Are those measurement working for everyone?
SOOFLY is offline Find More Posts by SOOFLY
Old Dec 10, 2012, 10:45 AM
drcigg is offline
Find More Posts by drcigg
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
I was given a slow stick earlier this year but never got around to using it. I have now passed it on to someone brand new to planes. The only thing needed to fly is a battery, receiver and radio. The gentleman was nice enough to include, motor, props, etc... The motor is
Ripper Outrunner OBL 2928/09 can anyone recommend a battery for this plane?
Any help would be greatly appreciated. Everyone has been so helpful on the forums here.
drcigg is offline Find More Posts by drcigg
Old Dec 10, 2012, 11:11 AM
Bill0 is offline
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
My experience is that if you balance it on the aft location, the plane will float a lot more than the forward location. It penetrates wind a lot better in the forward position. with power off, in the forward position, the nose drops and does not come back up, it's not a fast descent, but one you will have to pay attention to.
Bill0 is offline Find More Posts by Bill0
Old Dec 10, 2012, 11:13 AM
Bill0 is offline
Bill0's Avatar
Joined Aug 2010
I'm not familiar with that motor, but if it's compatible with a 3 cell, I would think anything from a 1300 to a 2200mah would be fine.
Old Dec 10, 2012, 11:44 AM
drcigg is offline
drcigg's Avatar
Joined Sep 2011
Thank you very much
Old Dec 10, 2012, 01:59 PM
SOOFLY is offline
Joined Nov 2012
Thanks Bill0.... I'll start somewhere in the middle for the maiden and then test the forward / aft CG's positions and see where I like it better.
I ended up making the wing completely flat and replaced the stock spars with three 4mm thick carbon hollowed spars. I then fiberglasses the carbon rods to the wing using fiberglass tape and polycrylic. The wing is solid as a rock and has almost no flex at all.
She's gonna be on the heavy side with all the X-gear, ailerons and reinforcements I've made. Hopefully the 450 motor ( 890kv) will pull its weight.
I'll post some picks when I finish up
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 10:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 09:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 02:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 12:17 PM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 11:35 AM
