Old Aug 19, 2005, 09:09 AM
markmm is offline
Find More Posts by markmm
Joined Jul 2005
4 Blade props and spinner
Does anyone know where I can buy 4 blade electric props and spinners?
Something 11" or smaller, but with higher pitch if possible.
I've found a few places that sell electric 4 blade props, but to get a decent pitch, the blades are huge (13+").
I also need a 2" spinner for 4 blade props.
Any ideas?
markmm is offline Find More Posts by markmm
Old Aug 19, 2005, 09:16 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
GWS makes this one...
http://www2.towerhobbies.com/cgi-bin...?&I=LXHHZ3&P=7
And someone else makes a 8x8 or something like that. But that is it...
http://www.rcgroups.com/forums/showt...ghlight=c+119+
Then if you have money you can get VArio....
http://www.aircraft-world.com/shopdi...variable+pitch
Old Aug 19, 2005, 09:35 AM
markmm is offline
Joined Jul 2005
Thanks.
The 10X8 actually keeps most of the flight characteristics I had with a larger 2 blade prop (in motocalc).
I noticed that the GWS uses a 5.5mm nut (0.2165354 inch)....and my motor shaft is 1/4" (.25 inch).
Anything special I need to do to get it to work with my motor? Drill it out to accept 1/4"?
In addition, who makes a 4 blade spinner to match that prop?
Old Aug 19, 2005, 09:49 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
markmm....what is the application for this?
Yes you can drill/reem it out, but I would not put significant juice through the GWS props...
Old Aug 19, 2005, 10:04 AM
markmm is offline
Joined Jul 2005
I'm redesigning a P51 to make it a scale "H" model and I need a 4 blade prop and spinner.
I found one person that put a four blade (APC) on the exact model (though he kept the model a "D" version for the most part). I PM'd him in hopes he could point me in the right direction.
4 blades obviously are not that popular, but this has to be scale, so I need the four blader.
I'm open to other 4 blade props...I just can't seem to find them...yet.
Old Aug 19, 2005, 10:08 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
How many ams/watts are you going to be putting into the power system. That is my question. GWS does make a 4 blade prop.
They are not very popular in RC application due to the way our power systems work. Typically they are less efficient than their two part counterparts.
What I am getting at here is that is a slowflier prop, and can't take significant power before it would fly apart!
Old Aug 19, 2005, 10:19 AM
markmm is offline
Joined Jul 2005
Putting in 20-25 amps, 220-262 watts. Of course I could be wrong...I'm still new to this and I'm still finding my way around motocalc, but that's what I'm finding the amps/watts are.
I understand that 4 blade props are less efficient. But this MUST be scale...I won't settle for anything less than scale on this build (within reason of course).
Old Aug 19, 2005, 10:20 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
No way can you use the GWS prop, maybe to 10-11 amps, but I would not go above that.
You will need to use the Vario system. Since it must be scale the price should not be an issue!
Old Aug 19, 2005, 10:30 AM
markmm is offline
Joined Jul 2005
I looked at the Vario stuff, but it is a bit confusing. Do you buy each blade seperately and assemble it?
I didn't see any 4 blade configurations...it all looked like individual blades.
I just looked again. It does appear that you install and adjust each blade. But they only have hubs for 6.0mm shafts and the shaft on my motor is 6.35mm.
Old Aug 19, 2005, 10:40 AM
diver don is offline
Find More Posts by diver don
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
Look at the hubs pick 4 bladed then just buy 4 blades of the proper length. CK. Aircraft-World.com What motor has a 6.35 motor shaft? DD
diver don is offline Find More Posts by diver don
Old Aug 19, 2005, 10:41 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
Yes you buy a hub for two three or four blades. Then you buy individual blades to go in the "holes" on the hub.
So you need a 4 blade hub, 4 of the same blades and then it allows you to select the Pitch you want! Very cool.....
Old Aug 19, 2005, 10:45 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Cool but, mounting a spinner on the 6B Hub can be a problem.DD
Old Aug 19, 2005, 10:50 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Zinger propellers makes a wide selection of 3 and 4 blade props. They work well and the shape of the blades have a scale appearance.
http://www.zingerpropeller.com/
pdawg is offline Find More Posts by pdawg
Old Aug 19, 2005, 10:53 AM
markmm is offline
Joined Jul 2005
Astro 020 803G...it has a 1/4" (6.35mm) shaft.
Old Aug 19, 2005, 10:55 AM
markmm is offline
Joined Jul 2005
Will any of their props work with electric?
3 or 4 blade props to solve a problem? mad mike Sport Planes 3 Apr 17, 2003 12:09 AM
FS: GWS Spinners for 3- and 4-Blade props. GoEFlight Aircraft - Electric - Airplanes (FS/W) 0 Nov 19, 2002 09:48 PM
FS: GWS Spinners for 3- and 4-Blade Props GoEFlight Vendor Talk 0 Nov 19, 2002 09:46 PM
4-blade props Viper Pilot Power Systems 0 Jul 15, 2002 10:11 AM
3 and 4 blade Props for GWS Zero. Electriflight Parkflyers 4 May 17, 2002 08:50 AM
