Old Aug 18, 2005, 09:52 PM
Ragemaster is offline
Find More Posts by Ragemaster
AMA#845099
Ragemaster's Avatar
Spokane Felts Fld, Washington, United States
Joined May 2004
Can Anyone tell me what size this Rossi is?
I was given this motor with an unassembled old Das Ugly Stick.
I can not find any markings whatsoever on it, just says Rossi on th side. Looks very new, good compression, maybe never run. Header and pipe with it is something I have never seen before with the pipe riveted onto the header, there is a smaller pipe inside of the main pipe. Small screw on the side of the header, not sure what that does?
Any help would be appreciated.
I can take closeups of the engine if that would help identify it.
Thanks In advance!!
Ragemaster is offline Find More Posts by Ragemaster
Old Aug 19, 2005, 07:11 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Looks to me like the Rossi 40. This is one of the older ones (more than 8 years old). Newer ones had a different (longer) pipe design.
Rossi made great performing engines. I think they went under about five years ago but restarted recently.
DaveSawers is offline Find More Posts by DaveSawers
Old Aug 19, 2005, 05:20 PM
Cdale03 is offline
Find More Posts by Cdale03
USA
Joined Sep 2004
I got that exact engine. a friend gave me two Rossi's with tuned pipes their are in the .40 range but I not sure where. .40 .45.46???? But I've seen his run and the screemmmmmmm!!
Cdale03 is offline Find More Posts by Cdale03
Old Aug 19, 2005, 05:25 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Looks like my Rossi .40, which is a very powerful motor.
It's best run on no more than 5% fuel, according to Rossi.
I use 10% in mine.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Aug 19, 2005, 08:11 PM
AMA#845099
Ragemaster's Avatar
Joined May 2004
Thanks Guys,
I grabbed some cool power 5% for it, what plugs do you guys use?
I have a bunch of OS 8's so that is what I will try tonight.
I was told this motor is for pylon racing, might be a bit much on this Ugly stick, but hey I can always throttle back, right?
Hope this pipe isn't too loud, the field I fly at is kinda picky about noise.
I grew up with nitro CL planes but have spent the last few years doing electrics, so this is my first entry back into nitro, I am excited. Is it true what I am told about stuffing steel wool into the pipe to quiet it down?
Old Aug 19, 2005, 09:32 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Try it first.
I run a 9x8 thin APC on mine, in an Evans Simitar.
Oodles of git-up-and-go!
Old Aug 19, 2005, 10:56 PM
AMA#845099
Ragemaster's Avatar
Joined May 2004
From what I hear about this engine I think I want to slow go with a bigger prop?
Old Aug 20, 2005, 12:22 AM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
Had one of these in a sports pylon model years ago. Heaps of power but it throttled really nicely & idled great.
Bad news about the pipe, starts off loud & just gets louder as the crappy pop rivets shake loose. I made up a second muffler & attached it to the first with it mounted on the fuselage. Perhaps a header pipe & a silenced tuned pipe is the answer. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Aug 20, 2005, 11:56 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
It could be the Rossi 45 because mine looks just like yours and no size marked on it either. If you've got the original box it'll be marked either R40 or R45. I guess the only other way to know for sure is to take the head off and measure the bore size. If it's 22.4mm (0.882") then it's a 45.
I've never been into fast models so I've only used an 11x5 prop and zero nitro. It's a one flick hand starter and behaves beautifully.
downunder is offline Find More Posts by downunder
Old Aug 20, 2005, 08:21 PM
AMA#845099
Ragemaster's Avatar
Joined May 2004
I wish I had a box, I was looking and asking around, some say because it has a black/silver head it is a .45, some say it is a .40 for sure because of no markings.
I need to grab some bigger wheels, not very much room for an 11" prop with the current trike gear and wheels.
I guess it really doesn't matter after what I have learned so far, use low nitro, it is fast, it is loud and it will be more than enough to put this Ugly Stick in the air.
I better quit pondering specs and get it built and fly the darn thing LOL.
I will let you know how it goes.
Question Can anyone tell me what kind of engine this is? theedge540 Engines 17 Jun 03, 2009 06:23 PM
Discussion Can Anyone tell me what Plane this is? MattZC Electric Ducted Fan Jet Talk 4 Apr 29, 2007 04:50 PM
Discussion Newbie..can anyone tell me what this is please??? UKPilot Electric Plane Talk 6 Apr 18, 2007 09:05 AM
Discussion can anyone tell me what ESC this is? RC-newbie Electric Plane Talk 11 Jun 18, 2006 06:25 PM
