Old May 03, 2002, 02:15 AM
RookieOne is offline
Find More Posts by RookieOne
Michele Somaschini, Spain
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
GWS Piper J-3 Cub
Hi all,
I've took a GWS Piper J-3 Cub for indoor flying (outdoor too).
Anyone else?
Landing gear seems to be too fragile as well as the wing joint. Both halves glue together with double sided tape and that's not too much strong.
Any modification to be done?
There's an optional piece to disipate motor heat but I forgot to take it. How can I do the same with more standard stuff?
Bye,
RookieOne
RookieOne is offline Find More Posts by RookieOne
Old May 03, 2002, 02:33 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
check the parkflyers forum and do a search for the cub... you'll find reports and various mods to keep you busy for a while. The common weak spots are exactly as you mention, the key being the wing. Use epoxy and micro-balloons and it'll hold together better.
Martin Hunter is offline Find More Posts by Martin Hunter
Old May 03, 2002, 11:14 AM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
Do a search but just about any of the Mods that have been done to the Tm or Stiks would apply here. It seem that the Cub kinda got lost in the rush to buy the TM. But most of us that have one like them great flyer but the wings have to be made stonger. And DON'T fly with out the wing struts or SNAP!Also the mounts for the wing struts should be turned 90 degrees on the wing and fusalage. And yes the wings won't hold up with the sticky tape to hold them together. I took mine and cut the wing tips off and turned the wings around so I now have square wing tips.
russ6421 is offline Find More Posts by russ6421
Herr Piper J-3 Cub Park Flyer DaveG Parkflyers 4 Feb 14, 2008 06:15 AM
Herr Piper J-3 Cub *Flight Report* genovia Parkflyers 14 Feb 12, 2008 05:53 PM
WTD--wanted plans/ instructions for piper J-3 cub derailed Aircraft - Electric - Airplanes (FS/W) 0 Jul 30, 2002 09:45 PM
Herr 1/2A Piper J-3 Cub (My love for the Cub) genovia Parkflyers 30 Jun 10, 2002 09:18 AM
Herr Piper J-3 Cub Rod Parkflyers 7 Oct 03, 2001 08:39 PM
