Old Aug 18, 2005, 01:39 PM
paulywood is offline
Find More Posts by paulywood
paulywood's Avatar
United States, CA, Sacramento
Joined Feb 2003
DSing 2m Carbon Blade, Vtail Suggestions
I have a new 2m Carbon Blade, That I'm putting together for just DSing.
Is that single screw going to hold that Vtail in place?, or should I do some other kind of hold down?
Any 2m blade DS'ers out there?
Thanks, Pauly.
paulywood is offline Find More Posts by paulywood
Old Aug 18, 2005, 01:44 PM
KingOfTheHill is offline
Find More Posts by KingOfTheHill
Ninja of the Nasty
KingOfTheHill's Avatar
Joined Jan 2004
dab of goop!!!!!!!!!!!!!!!!!!!!!!!!!
TRUST ME a DAB of goop and your safe and sound.... and a little bit of toulene or xylene dripped on it can take it off later if you need to make repairs or ship
JOe
KingOfTheHill is offline Find More Posts by KingOfTheHill
Old Aug 18, 2005, 01:51 PM
paulywood's Avatar
Joined Feb 2003
I was thinking of that, but I was seeing what other guys are doing also.
Thanks for reasuring me. Pauly.
Bill L is offline
Find More Posts by Bill L
Bill L's Avatar
San Diego
Joined Apr 2003
I drilled and re tapped the screw, new size was 6/32, used goop to keep it in place then added a band of 2oz cloth on both sides of the tail, make sure you fill in the void on the leading edge of the elevator with a bit of epoxy, this will add ridgitity to the surface itself, mine were pretty flexy, some have a big enough gap for a small aluminim tube to be epoxied in
good luck
B
keep it under 210
Bill L is offline Find More Posts by Bill L
Old Aug 18, 2005, 04:57 PM
aneigher24 is offline
Find More Posts by aneigher24
slope-a-holic
aneigher24's Avatar
Oak Park, CA
Joined Mar 2005
My screw began to loosen up a bit over time untill i had a secent wiggle, what i did was do all my aligning double check tripple check then mark then epoxy with microballons to glue it in ther good...then 40ooplecheck youre measurements for incidence..etc and let it set,
Make sure to check for proper c.g after
@lex
aneigher24 is offline Find More Posts by aneigher24
Wanted 2m Carbon Blade Wing screamin' eagle Aircraft - Sailplanes (FS/W) 1 Sep 14, 2005 12:11 PM
DSing 2m Carbon Blade, Vtail Suggestions paulywood Dynamic Soaring 9 Aug 21, 2005 07:39 PM
Wanted Wanted: 2m carbon blade fues 2lsvtec Aircraft - Sailplanes (FS/W) 2 Jun 29, 2005 02:18 PM
TheTick (Ben) Goes 206 with his 2M Carbon Blade! Z06kal Dynamic Soaring 34 Jan 28, 2005 11:04 AM
WTB- 2m carbon blade wing KingOfTheHill Aircraft - Sailplanes (FS/W) 1 Dec 17, 2004 12:20 AM
