Old May 29, 2007, 03:59 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
you darn kids and your hot rods! lol
Herb seen oliver around lately? pm and mail but havnt seen hide nore hair
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old May 29, 2007, 04:01 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
He's regularly around here and on the other forum - What da ya need, another Gnat ??
Herb is offline Find More Posts by Herb
Old May 29, 2007, 04:15 PM
Joined Aug 2002
no lol! I wanted to pick up some of the ky rotors for the BAE. looked around at setups and it's the most prudent way to do it. Use the same housings and pods and just swap rotors.
Barry
Old May 29, 2007, 04:40 PM
Byam Wight is offline
Find More Posts by Byam Wight
Canberra, Australia
Joined Sep 2003
G'day Bill,
Going by our speed difference at Albury, that doesn't surprise. Could you email me your new address as I don't seem to have it.
Byam.
Byam Wight is offline Find More Posts by Byam Wight
Old Jan 13, 2008, 06:25 AM
JPHen is offline
Find More Posts by JPHen
JPHen's Avatar
USA, VA, Spotsylvania
Joined Nov 2003
I got one of these coming to me. What servos are you using? Is cell thickness going to be a problem (ie, no thick 5 cell packs)?
Thanks.
Joe
JPHen is offline Find More Posts by JPHen
Old Jan 13, 2008, 09:22 AM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
I buy mine on E-Zone last year and is my favourite plane so far.(i did not try yet my new Electra)
I use 3 HS 65 (?)( karbonite gear) they fit perfectly. Schubeler DS51.Motor Hacker 50/16 l/Hyperion 80 amps controller,4 800mah cell for RX. I made a new exhaust tube to fit the DS51. The cells are the Li poly lite (6S)2*3S 3300 MAH from :http://www.zebrahobby.ca/cgi-bin/cp-app.cgi.
You have to strip the cells to made a long pack who fit in the battery compartment.
You have to add ~ 2-3 once off lead to balance ( I use epoxy with sand)
Here is a picture of the pack ,very easy to remove from the plane. With this setup the Mig is a missile.....
bidule is offline Find More Posts by bidule
Old Jan 13, 2008, 02:56 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nice Bidule !
Post some pictures, will you ... ! What power do you have, ca. 850W? I heard karbonite gears have no play but are delicate (strip).
Mine's down for maintenance - I have to sort out a number of minor issues which have to do with a) weak paper thin intake, cracked in a number of place and now fixed b) elevator servo and linkage is binding a tiny bit which annoys me, maybe replace with digital high torque servo c) needs custom lipo pack d) slight thrust alignment issue e) my takeoff are a bit hairy as it tends to get its nose glue to the ground and f) does not want to land (high lift rg14) so needs plenty of unobstructed space.
Other than that, as a bystander described mine, it's scary fast
Old Jan 13, 2008, 03:35 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Thank Herb
Were I fly, the landing strip is like a golf club, perfect for smooth landing....Now is more like NHL field!!
I did not measure watts yet. Pack is just warm after flying .
Here two pics with big friend, just painted and waiting for details
Old Jan 13, 2008, 03:39 PM
JPHen is offline
JPHen's Avatar
Joined Nov 2003
So if I understand correctly, you don't put the packs on either side of the intake, you slide the packs end to end????
Joe
Old Jan 13, 2008, 04:01 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes, in the location it's designed for:
http://www.rcgroups.com/forums/showp...&postcount=104
Old Jan 13, 2008, 04:13 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Incidentally this old 2006 video shows, at the end, how the LiPo pack is inserted:
SOD ("scrape off the dirt") MiG-15 video
I was flying conservatively as a police helicopter can be heard hovering over the field
Old Jan 13, 2008, 04:57 PM
JPHen is offline
JPHen's Avatar
Joined Nov 2003
Herb - nice video. I was thinking about a Medusa 1600 kv motor on 6s. By the way, are you using a UBEC?
Joe
Old Jan 13, 2008, 05:55 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Joe, Not familiar with medusa but it might work. I don't use upec (ultimate plane elimination circuit) in any of my high powered edf, always separate receiver battery. 720 mah 4.8v Sanyo in the case of the MiG-15.
Old Jan 30, 2008, 01:10 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by JPHen
... was thinking about a Medusa 1600 kv motor ...
Kontronic has just come out with a new line of high performance Kira inrunners with integrated fans, which should be perfect for most 69mm (400,480) and 90mm (500,600,650) fan applications (esp. the long can 650 one)
http://www.kontronik.com/Kiraauswahl2008.htm
Old Feb 26, 2010, 01:18 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Wemotec MiG-15 "scary fast"
I wonder what happened at the end ... the caption does not sound too good.
Reminds me a lot of mine - including attempts at trying to land it (endless glide).
WEMOTEC MIG15 First (Final) Flight (3 min 40 sec)
Old Feb 26, 2010, 12:21 PM
mungrelv8ute is offline
Find More Posts by mungrelv8ute
mungrelv8ute's Avatar
Belgium, Flemish Region, Sint-Katelijne-Waver
Joined Apr 2003
I flew my Mig many times and then sold it, I regret that decission....awesome model. I hope that Wemotec bring them back...
mungrelv8ute is offline Find More Posts by mungrelv8ute
Old Feb 27, 2010, 07:46 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It is very nice , I still have mine but disassembled w/o fan & electronics.
I got tired of the scrape off the ground takeoffs, and my intake kept collapsing.
I have been contemplating doing some work to it :
Like making a nice hatch like you did.
A more scale intake.
Paint it all red (russian aerobatic demo scheme)
Getting a clear canopy (anybody... ?).
Installing retracts, I am thinking of the e-flites I have which would work (up tp 4.5lbs) and reduce my headaches.
New Product WeMoTec Mig 15 termite Electric Ducted Fan Jet Talk 3 Feb 11, 2006 10:22 PM
MiG-15 by Kamdax Herb Electric Ducted Fan Jet Talk 70 Dec 28, 2004 02:03 AM
MIG 15 by Graham Cornford dave morris Electric Ducted Fan Jet Talk 5 Aug 03, 2001 08:49 AM
