Old Dec 05, 2005, 02:35 PM
tow is offline
tow
Find More Posts by tow
tow
tow's Avatar
Norway, Nord-Trondelag, Namsos
Joined Dec 2003
[B]tow, the fences will go on there at some point. Spanwise flow, what's that, you mean fly slow ??
Well..You have to land sometime..........Seriuosly, just as an advice, I`ve had a number of MiG`s over the years, they all fly great, but especially at a higher wingloading , they trend to be a little tricky on high AOA. The wing-fences helps considerally, just as intended on the full-size. - But then again, guess you are aware of all that....
Good Luck w. the ship!
tow is offline Find More Posts by tow
Old Dec 05, 2005, 03:48 PM
Jindra M is offline
Find More Posts by Jindra M
Jindra M's Avatar
Eibergen, The Netherlands
Joined May 2002
Herb, it was a PM message actually, where to send is if you do not get it.
CG is according to instruction, proto few with almost no trim at all. Maybe a little tad up, caused by end of the fuse covering the thrust tube. My one has been modified so outlet was free.
Throws were +/- 6mm and it was more than enough. I started with lousy 450W upgrading to 750W later. Your steroid-o-Mig should fly out of your hand, proto got to 2250g.... I use bungee all the time. Dont be nervous about decals only czechs would know
Jindra M is offline Find More Posts by Jindra M
Old Dec 06, 2005, 08:44 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Awesome work as usual Herb!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 07, 2005, 08:26 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks Kevin !
Bob, the 3200's will slide in for sure. But then you have to find a way to secure them so they don't move, and yet come out easily.
Marek, thanks for the throws & other info.
I had to dremel out some more wood to get the pack to fit, it needed to slide further out to the fron to get the CG right:
Herb is offline Find More Posts by Herb
Old Dec 07, 2005, 08:31 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Jeti controller with 10 degree fixed timing was not the best choice for the Hacker B50, I swapped it out for a Kontronic 70A 3SL opto. Watts decreased from 1400 to 1300, which is good (part of it is just better efficiency due to the less agressive timing of the Kontronic esc).
Also pic of receiver and antenna installation added.
To get the CG right controller is moved way up front (as far as it will go) :
Old Dec 07, 2005, 08:33 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Fiberglass cnc pre-cut fences are a good fit, not much too it ...
Old Dec 07, 2005, 08:36 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Painting's almost done, still need to make the numerals ...
Old Dec 07, 2005, 08:38 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Nice stuff as usual Herb!
I also like the little stack of missiles you got!
maiden flight this coming saturday?
Bruce
bmiller is offline Find More Posts by bmiller
Old Dec 07, 2005, 09:09 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Herb you are killing me! I've always wanted a Mig 15 and this one looks so niice. I give, I'm calling Oliver in the AM, EARLY!
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Dec 08, 2005, 12:40 AM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
Nice Herb, you redid decals too. If Oliver sent you the decals again you may want to wait with numerals. People here use surplus numerals on Alfa Mig sheets. Its about the right size and very thin.
Can you please post a view through the ducting? Particulary the trust tube? Does the top part of the fuse get to the air stream a little bit? You may want to modify that....... With power you pump in it, it may tuck under full power. Good luck on maiden.
Old Dec 08, 2005, 01:25 AM
demetrius is online now
Find More Posts by demetrius
demetrius's Avatar
Van Nuys
Joined Mar 2004
I am also interested!
demetrius is online now Find More Posts by demetrius
Old Dec 08, 2005, 06:15 AM
mungrelv8ute is offline
Find More Posts by mungrelv8ute
mungrelv8ute's Avatar
Belgium, Flemish Region, Sint-Katelijne-Waver
Joined Apr 2003
My one is on the way, I think Santa has it with him....:-)
mungrelv8ute is offline Find More Posts by mungrelv8ute
Old Dec 08, 2005, 11:56 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Man thats beautiful Herb! awesome job on the fuse to wing transition! I still love that scale looking stab.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Dec 08, 2005, 02:46 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Jindra M
... Can you please post a view through the ducting? Particulary the trust tube? Does the top part of the fuse get to the air stream a little bit? You may want to modify that....... With power you pump in it, it may tuck under full power. ....
Hello Marek,
I did dremel out and smooth/flatten a bit of the top fuse appendix where it overhangs the thrust tube, I think it should be ok. I also closed the gap with some transparent tape.
Old Dec 08, 2005, 05:30 PM
mmormota is online now
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
What is the secret method of buying this bird?
mmormota is online now Find More Posts by mmormota
Old Dec 09, 2005, 12:49 AM
Heiner Skroblin is offline
Find More Posts by Heiner Skroblin
Cologne-Deutz R.R. Svc, Germany
Joined Jan 2002
Hello,
I found some black stripes at the decal set, they should belong to the wing. Has some one a photo to show where they should be placed?
Heiner
Heiner Skroblin is offline Find More Posts by Heiner Skroblin
Old Dec 09, 2005, 12:50 AM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
Herb,
you think of everything I'm little bit worried of landings on the dirt strip. It looks strange but this one lands on the last 10 inches of belly. Are you planning to stick a heavy packing tape there?
How can I contact you?
Jindra
Old Dec 09, 2005, 01:03 AM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
Originally Posted by Heiner Skroblin
Hello,
Heiner
walk paths for wings?
Old Dec 09, 2005, 01:07 AM
demetrius's Avatar
Van Nuys
Joined Mar 2004
thanks Oliver for the response!
Old Dec 09, 2005, 01:11 AM
WeMoTec is offline
Find More Posts by WeMoTec
Willich / Germany
Joined Nov 1998
@ mmormota:
There is no secret, it is all in this thread.
You can order it and we put you on the waiting list.
By the time it is available we will contact you and ask if you still want it. Since a couple of those on the list decided to take the model at a later point, you are currently looking for about six weeks waiting time, if you are lucky, even less.
Price to the US is 392,97 Euro total which converts to about 470 USD for Model, Midi Fan and premium insured shipping.
So Gregg only ordered it rather early.
Oliver
WeMoTec is offline Find More Posts by WeMoTec
Old Dec 09, 2005, 01:12 AM
Joined Jan 2002
@ Jindra,
do you have a photo?
Heiner
Old Dec 09, 2005, 01:54 AM
RoverTomcat is offline
Find More Posts by RoverTomcat
Zoom-Zoom
RoverTomcat's Avatar
Switzerland, ZH, Dietikon
Joined Jun 2004
Hello,
Heiner
Hi Heiner!
Maybe... Like this? The Planes of Fame MiG15 has those black walkways painted on!
HERE's a hi-res version of the pic.
Best regards - Paco
RoverTomcat is offline Find More Posts by RoverTomcat
Old Dec 09, 2005, 02:09 AM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
Hi Heiner!
or this one
HERE's
shows your cammo.....
Jindra
Old Dec 09, 2005, 02:13 AM
Joined Jan 2002
Ok,
thank's
Heiner
Old Dec 09, 2005, 03:38 AM
tow is offline
tow
tow
tow's Avatar
Joined Dec 2003
Hello,
Heiner
Can`t recall any black striping in the color-cheme you are using - I belive you are talking about the black Wing-walker panels, they should be placed at the front part of wing-root butt against a separation panel at the wing-root. Front edge angeled opposite of wing sweep angle. Hope this clarify some.
Old Dec 09, 2005, 12:00 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Herb,
... I'm little bit worried of landings on the dirt strip. It looks strange but this one lands on the last 10 inches of belly. Are you planning to stick a heavy packing tape there? ...
Jindra
Jindra, Yes there will be lots of tape on the fuse bottom (I even thought of three tiny wheels for maiden, but I don't think I have the right size).
I was hoping for rain so there would be some California grass to slide off, but no luck yet ...
Old Dec 10, 2005, 07:52 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Well I had the maiden today and all went well
I installed (with silicone) two triangular balsa strips on the fuse bottom to avoid excessive belly scraping, loaded the batt, advanced the throttle to 1300+ Watts and off she went straight as an arrow ...
It bareley needed any trim, just a tad of down. But the elevator (+-7mm) was way too sensitive, so it will be reduced next flight. It picks up speed very nicely already at quarter throttle ... After the usual mig wobble in the last turn before the landing approach it did glide for quite a loong while, this thing (like my other migs) has no drag to speak of.
The midi runs as smooth as silk, with no annoying resonances either - a true turbine sound they said (well ok maybe they did not know what a real model turbine sounds) ...
All in all a great model
Old Dec 10, 2005, 08:42 PM
kriptonic is offline
Find More Posts by kriptonic
kriptonic's Avatar
Los Angeles
Joined Aug 2004
Right on Herb, Glad to see the maiden went smooooooooth.....
Gene
kriptonic is offline Find More Posts by kriptonic
Old Dec 11, 2005, 12:45 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
I was at the field today and that Mig is a real beauty! The glasswork is very nicely done including the ducting. Herb did a great job on it. I got to see it takeoff on its belly, on dirt! Herbs not kidding about the elevator, it had lifted off about 4ft high and it instantly went 90 degrees verticle when he pulled up! I expected to see a typical stall and crash but it just kept accelerating up til He was quickly able to level it out.(can you say power?!)Tons of power!(pounds anyway)
Bruce
Old Dec 11, 2005, 12:57 AM
Henry V is offline
Find More Posts by Henry V
Henry V's Avatar
Long Beach
Joined Jan 2004
Where's the video?
Henry V is offline Find More Posts by Henry V
Old Dec 11, 2005, 04:38 PM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
Great Herb, congratulations
Old Dec 12, 2005, 12:34 AM
Joined Jan 2002
Congratulations Herb!
Heiner
Old Dec 12, 2005, 02:14 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Seeems like a very nice flier, I really did not do much myself besides the paint ... More flights next weekend, with more reasonable reduced elevator throw, airbrakes and parachute .
Hey Henry nice hearing from you Formation flying anytime soon ? How's the F4U doing.
Old Dec 13, 2005, 11:25 AM
Joined Dec 2000
Vey Nice Herb. I should have my model around Christmas.
Is the Hacker motor a B50 18S?
thanks,
Bob
Old Dec 13, 2005, 01:04 PM
Joined Dec 2000
Herb,
I have access to a Vacuum former. I will see about making a casting from my model and making a clear canopy available.
Bob
Originally Posted by Herb
For such a beautiful (and quite close to scale) model a clear canopy (& pilot) would add a needed touch of realism. That would be my no. 1 request to the manufacturer. A scale intake lip would be my no. 2 request.
Old Dec 14, 2005, 11:56 AM
Ductedfann is offline
Find More Posts by Ductedfann
Ductedfann's Avatar
mid west
Joined Jan 2002
Nice Report Herb, can't wait to have xx of these.
Morris
Ductedfans.com
Ductedfann is offline Find More Posts by Ductedfann
Old Dec 14, 2005, 12:14 PM
Henry V is offline
Henry V's Avatar
Long Beach
Joined Jan 2004
Hey Herb
Yeh, Ive been out of it for about 5months with other personal projects, but I started going out to fairview again on my lunch brake...I still have the f4u and me109 along with my pushers and now my new alfa mig, not as fancy as yours ,Cant wait to see all you new toys
Henry V
Old Dec 15, 2005, 02:59 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Bob, a transparent canopy would be nice, so you can keep an eye on the receiver . Ok thanks send me one ... Actually the K&A MiG-15 canopy almost fits. Yes it's the 18S.
Henry, so I'll see you one of these days. My Spit is ready.
Old Dec 16, 2005, 07:02 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... and I usually don't fly during the week, but we tend to be regulars on Saturdays after 1pm (when the glider guys leave) .
Jindra you don't happen to have a hi-res image of the cssr numbers you can mail me so I can use to make the monokote serials? The one I have (from a decal set) is poor quality and does not enlarge well (blurred).
Old Dec 16, 2005, 08:00 PM
Joined Dec 2000
Herb,
I will be out for the New Year if your in town I would love to see your Mig fly.
Are the control surfaces live hinged?
I decided to go with a Kontronik 600-17 for power.
It will provide plenty of go power!
I have even considered painting it like the Stoli Mig which I think is actually a 17.
Old Dec 16, 2005, 08:23 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
The Stoli Migs (now Smirnov) are indeed 17's http://www.users.globalnet.co.uk/~ga...lery/stolimig/
But I have likewise thought about taking a bit of artistic freedom....
Greg
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old Dec 16, 2005, 11:42 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Is the redbull mig still around? That paintjob was smokin!
Old Dec 17, 2005, 01:56 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
The Red bull was based out of San Bernardino. I know one of the mechanics..I think they are moving..Not sure where
turbonut is online now Find More Posts by turbonut
Old Dec 17, 2005, 10:38 AM
Cant fly enough
USA, CA, Berkeley
Joined Dec 2003
Yup, certainly shows the need for a Mig-17 kit.
Greg
Old Dec 17, 2005, 12:16 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I just saw Bill Reesman in the Red Bull Mig at the Nellis Airshow last month, sweet performance that was. I got some brief video of his night show from across town, he has some sort of giant sparklers that leave a 1000 foot trail for sparks and he drops exploding type colored fireworks as well, really neat. I could see it from where I'm at, south of the strip, Nellis is about 20 miles away from here.
I wonder if he still has his Yak 50, that was a neat airplane.
Nice work on the Mig 15 Herb!
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Dec 18, 2005, 12:39 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Steve C and Mark T flew a very nice pair of Steve Toschi designed (now kitted by K&A) Stoli MiG-15's a few years ago. Yes the original was a 17, but it's still a cool scheme .
Old Dec 18, 2005, 12:55 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
It was Steve Tosci (sp?) who designed the original I believe. He and Steve C put in unheard of gobs of power and making 150mph+ passes.
Old Dec 18, 2005, 01:48 PM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
Herb,
should not be a problem to make your own. This cammo has been flown on 3 different airplanes 3214, 3233 and 3234. I have no decal sheets at home, but you may try to trace numbers on
http://www.alfamodel.cz/php/index.ph...016&_RQsiz=big
Tomorrow I can ask friends to make a scan for you. Maybe someone in States can do that right away for you. Alfa Migs are quite popular there.
What rates you fly your one? I needed 7mm up to slow it down a bit for the landing. 135 g/dm^2 is quite a high loading
J.
Old Dec 18, 2005, 02:04 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Jindra Those decals are better than what I had Thanks, that should do it.
I flew it again yesterday, and maybe again later today. I have decreased the rates a bit but not by much, I am around 6mm on the elev. I also definitely needed about 1mm up trim, I might try moving the CG back a bit.
The wingloading (32 oz/ft2) actually feels very low, I am used to occasionally much higher wingloadings. To me it flies like a glider ... It does take a good circuit to slow down, part of it is low drag, and part of it is actually low wingloading (I did quite a bit of "gliding" yesterday, now I switched to my 3-rd controller, a Hacker Master 77A esc). I guess everything is relative.
I've had jets (eg jepe pyranha) that when you turn the power off they come down like a brick, very good for spot landings. The MiG is certainly not like that.
Old Dec 18, 2005, 02:48 PM
Jindra M is offline
Jindra M's Avatar
Joined May 2002
I know it glides forever. I like clasic jets, they fly on wings not on the power (it's stil nice to have). 1mm up hmmm, check how she flies on her back. Does she climb? I fly elevator almost neutral. Shallow dive in in both cases and hold her on the stick. Just personal prefference.
Yep Piranha does not really glide, but it's different style. Mig is far more agile then the little fish. Glad you can go on with details...
J.
Old Dec 18, 2005, 07:41 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
would flaps help?
Old Dec 18, 2005, 07:45 PM
Joined Dec 2000
Herb,
Did you let the blue smoke out of your controller again?
Bob
Old Dec 18, 2005, 10:25 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Herb,
Bob
He kept the magic smoke inside but that ESC was getting too hot running at less than WOT. Herb flew it again late today, I'd say hes got it trimmed out quite well. I still can't get over it taking off from dirt on its belly!
Herb,
I have the Alfa mig kit if you need to photocopy the decals, just ask!
Bruce
Old Dec 19, 2005, 01:36 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Jindra, I haven't moved the CG around yet, as I flew every time with a different controller & controller location . I did get the decals today though!! Thanks Oliver.
Bob, the white smoke was out of my 3-yr old Mega 30 in the Focke-Wulf Ta-152 at the end of a 6 min turn and burn flight (even caught it on video), I did not know at the time that the Mega winding epoxy vaporizes to a dense white smoke, the effect is kind of cool though .
The (four year old) Kontronic 3SL 70A controller works very well with the Hacker, but does not like reduced throttle, and therefore gets really hot. This is not unusual for older brushless controllers. I had five or six thermal shutdowns on the second flight, very good for testing extended glide properties .
The third flight of the MiG-15 yesterday was with a Hacker 77A Master and the flight went flawlessly. This time the controller barely got warm. It takes off no problem from dirt, I have two balsa triangular shaped rails glued on with silicone to the bottom, so the nice fg does not get scraped on takeoff or landing. On wet Ohio grass, you would just slide on the belly.
I did a few moderately fast passes yesterday, I think I exceeded the speed limit of 150 km/h by 60 km/h ... With the motor off it's got that nice whistling sound of a molded airframe.
Demetrius I don't think flaps are necessary once you get used to a long glide approach. Maybe spoilerons. As I said it glides around very nicely, at least with my (relatively lightweight) setup. All in all a lovely plane, and a good relaxing no-frills weekend flier.
Old Dec 19, 2005, 02:12 PM
Joined Dec 2000
Thanks for the updates Herb. I will use a Kontronik Fun 600-17 with a Jazz 55 controller on 6s. The motor was on sale at Tower for $139.00 and free shipping, it came today. The bearing plates now have large cooling slots. The Jazz controller handles partial throttle settings very well and features a switch BEC. I have used this controller in the Pyranha with great success!
I'm hoping my kit will arrive before Christmas.
Old Dec 19, 2005, 07:38 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
This is a really nice looking plane, but I don't see it on the website. Are they not quite available yet?
Steve C
Steve C is offline Find More Posts by Steve C
Old Dec 19, 2005, 08:27 PM
WeMoTec is offline
Willich / Germany
Joined Nov 1998
@ Steve
They are available, the information is in this thread. But there is a waiting list, since the supply is low compared to demand.
So the safest and quickest way to get hold of one is to put yourself on the list. You will be contacted ASA the next batch is available and you can decide than, if you take it.
That is how the others in this thread did it. Current waiting time is about two months. Once its freely available, we will put the MIG on our new website to be launched soon.
Two american dealers, ductedfann and Dynamoelectrics ordered a couple and will get one each soon. If you are lucky, you may get hold of one of these.
I would be glad if the manufacturer would deliver more, but that is the current situation. At least I can tell, that the quality is well worth waiting.
Oliver
Joined Dec 2000
What timing I was just going to make that suggestion Oliver.
I'm hoping to get mine by weeks end. If not next week is a okay too.
I have all the components ready for my Mig.
Old Dec 19, 2005, 10:17 PM
drksyd is offline
Find More Posts by drksyd
MultipleCrashSurvivor
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
... I will use a Kontronik Fun 600-17 with a Jazz 55 controller on 6s...
I'd like to hear what kind of power you'll get with that setup. I just ran up my 600-15 in a Midi on 6S (two TP 3S2P 4200 PL's in series) and got about 850 watts under 50 amps. I'll try it with my 3S3P 6000 PL's and PQ 3700 20's. In a pre-production Air Power fan I got over 1kw on 5S with the 600-17. I'll be making a stand to hold fans on the scale to measure thrust soon so I'll be able to see how much thrust I'm actually getting. Now I'll even be able to run up a 22/30/3 with 8 or 9S.
drksyd is offline Find More Posts by drksyd
Old Dec 20, 2005, 12:43 AM
Joined Jan 2002
I have also the FUN 600-15 in my Mig-15, it's working ok.
@ Demetrius,
you don't need flaps for the Mig,like Herb told you. (the field I am going to to fly my Mig, has the size of a carrier!)
Heiner
Old Dec 20, 2005, 01:51 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Steve C
This is a really nice looking plane, but I don't see it on the website. Are they not quite available yet? Steve C
Aaah MiG-15 fever strikes again ... And no bungee Steve
Bob, the Fun 600-17 will be just a tad over 1000 Watts wot on very good LiPo cells, and in the 900W range on soso LiPos. That motor at tower is a very good deal! Too bad my Hacker B50's never die ...
Old Dec 20, 2005, 03:00 PM
Joined Dec 2000
I plan to use the 3200 Kokam cell. I think 1000 watts will be just fine!
Old Jan 09, 2006, 07:57 AM
Joined Dec 2000
My kit finally showed up last week. Very nice model.
Looking forward to flying this one alot.
I really like the fact that the wing and stabs are removeable.
Herb how about a photo of the underside of your jet.
Bob
Old Jan 10, 2006, 01:41 AM
Joined Apr 2003
My jet arrived today.
Excellent quality and very well packed, no damage at all.
I plan to go with the 600-17 and 6S set-up. (Thanks Adam)
Sure is pretty.
Gregg
Old Jan 20, 2006, 04:37 AM
demetrius's Avatar
Van Nuys
Joined Mar 2004
Herb any thoughts on astro bobs' 840 3t on 6s?
Old Jan 20, 2006, 12:24 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
What are the specs (wingspan and length) on this Mig 15? I couldn't find it on the wemotec site nor in the first few pages of the thread.
Old Jan 20, 2006, 12:55 PM
mode101 is offline
Find More Posts by mode101
mode101's Avatar
Wellington, Florida
Joined Oct 2005
Dynamo Electrics has it listed on their site, not yet available but the specs are listed as such:
Wingspan: 1030mm
Length: 900mm (est.)
http://www.dynamoelectrics.com/detail.aspx?ID=1042
mode101 is offline Find More Posts by mode101
Old Jan 20, 2006, 01:13 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
http://www.rcgroups.com/forums/showp...18&postcount=4
Btw It appears that the text on the site you quote was copied verbatim from my first and fourth post here in this thread:
http://www.rcgroups.com/forums/showp...14&postcount=1
Old Jan 20, 2006, 01:15 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I am not familiar with this motor, Astro claims on their site it will work on 6s at ca. 1400 Watts in the Midi, which should work .
The question is how long the $130 motor will last at these (or even significantly lower) power levels, as I said I have no experience.
Old Jan 20, 2006, 01:16 PM
Joined Dec 2000
Herb,
Anymore flights on the MIG?
Old Jan 20, 2006, 01:19 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Plenty ...
I just switched to a new Futaba 9C super, the five year old 8AUF went bezerk two weeks ago .
Old Jan 20, 2006, 01:35 PM
termite is offline
Find More Posts by termite
Utica Il.
Joined Dec 2002
Herb,
So far you are the only source of info for this kit
Randy
Dynamo Electrics
termite is offline Find More Posts by termite
Reply With Quote  (Disabled)
Old Jan 21, 2006, 07:55 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Anymore flights on the MiG?
Today's video of the MiG-15, taken by Jon (LittleJon), thanks Jon !
WeMoTec MiG-15 video
Full flight was ca. 4 mins, used up 1.7 Ah out of 3.2Ah on the Kokam 3200's.
Old Jan 21, 2006, 09:05 PM
mode101 is offline
mode101's Avatar
Wellington, Florida
Joined Oct 2005
Herb no grass with all that recent rain? Err...the belly grinding against the dirt ouch! Nice to see it takes off without a bungee though.
Old Jan 22, 2006, 12:35 AM
drksyd is offline
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
I'm quite sure there's a lot of tape or another layer of glass to protect it, too nice of a plane to get it all scratched up. I do like that take off though, no tossing or bungee.
Old Jan 22, 2006, 08:19 AM
Kevin Cox's Avatar
Joined Jan 1997
Awesome video Herb!
Old Jan 22, 2006, 12:57 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks Kevin !
Jon's cell phone went off twice while he was recording, the second time he even managed to answer it . That part was edited out for obvious reasons, entertaining as it might have been ...
If that wasn't enough, the sound you hear halfway through the recording is a Costa Mesa police helicopter hovering over the field (speed limit? ).
The Mig slides on two long thick removable balsa rails, see post 127:http://www.rcgroups.com/forums/showp...&postcount=127 . They are almost invisible in flight.
Old Jan 22, 2006, 01:17 PM
Joined Dec 2000
That swept wing looks great in flight Herb.
. I contacted Oliver and he confirmed this. Other than photos graphs of the various stages of construction I did not see any written instructions on the CD. The production kits to not come with ANY hardware. The manufacturer decided to leave this up to the builder.
If you could list the throws and any expo settings and of course the CG that would be great.
Old Jan 22, 2006, 01:32 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
My kit did not contain much hardware either, but I don't mind (the Aeronaut kits don't contain much hardware either). Most people prefer to use their own stuff (eg ball links) so that was fine with me. Yes there's no text, but I thought the pictures were pretty good and self-explanatory.
* I provided my own aileron linkages (see photos) using ball links from my LHS.
* I used their elevator ball links, but had to use a thinner steel wire
* I did not solder the wire together (yes it can be done, but going in there with a soldering iron ), I used plenty of epoxy instead, pretty foolproof I think.
* Mine came with all the wing joiners, and the steel pins to hinge the fuse bottom.
* I mounted the fan differently (siliconed) because I don't like all that resonating noise of the fuselage acting like a violin case. No harware needed there, at least for my installation.
* I cut & glued a piece of liteply for the rec. batt and receiver in the nose.
Old Jan 22, 2006, 01:35 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I use ailerons +- 7mm, elevator +-6mm , expo -20%. CG at 166mm.
The MiG-15 is still a bit pitch sensitive, I need to reduce the elevator rate a bit more. Roll rate is fine though.
The CG on mine is at 166mm, as stated in the instructions (it's actually a picture). Mine's a bit noseheavy, so will have to move something back a bit.
Old Jan 22, 2006, 09:03 PM
LittleJon is offline
Find More Posts by LittleJon
LittleJon's Avatar
Laguna Beach, California
Joined Nov 2004
I'm glad the video came out alright. I'm not experienced with videography, photography is more my forte, so that was a bit of a baptism of fire! Herb's MIG is very fast and the sun was in just the wrong place, so I kept getting dazzled whenever Herb flew to the left of me.
LittleJon is offline Find More Posts by LittleJon
Old Jan 23, 2006, 11:37 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Jon you did a fantastic job ...
I found btw that there's a second nice video of the same MiG-15 flight here, taken by our friend C Corumang :
http://www.rcgroups.com/forums/showp...1&postcount=23
Old Feb 12, 2006, 12:15 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
New video
New longer video has short trailer from yesterday's flight showing the model closeup, hatches and battery extraction (thanks Bob),
MiG-15 short video
Old Feb 12, 2006, 04:15 PM
Joined Aug 2002
Awesome Herb! What more could one ask from a kit today?
Barry
Old Feb 12, 2006, 07:55 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
You're becoming quite the video editor these days Herb! Very nice!
Old Feb 13, 2006, 11:22 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
Herb, is there a way to fit an 8s pack in there to possibly feed it with a b5012xl?
Old Feb 14, 2006, 12:26 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... depends what the pack size is like.
As I said, a Kokam 3200/3900 6S (3S+3S) will fit in the battery opening. Other sized packs might or might not fit (you have to look up the dimensions, and compare to the Kokam pack).
What do you need a paperweight B50-XL for ?? Mine weighs 63 oz with the B50-18S and does not need much power to go .
I had to replace one Kokam cell in one of the two 3S packs, it had sprung a leak on the last flight (aborted at ca. 1/3 capacity left I later found out) and had spewed a bit of that sweet smelling electrolyte inside the shrink wrap. Took a whole evening to re-balance the 3S pack with a new cell, re-stress-tested the new pack & new solder joints, 1420W hot off the charger . Aah the pleasures of Monday LiPo battery maintenance ...
Old Feb 14, 2006, 01:52 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Serious question Herb - what is your typical flight profile like? Full power is how long a burst, how long in between at what approximate power setting? 70 amps and 1,400 watts should qualify for BOTH Hacker abuse AND Kokam abuse .
Chris True is offline Find More Posts by Chris True
Old Feb 14, 2006, 02:52 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
You can see the flight profile in the video, full throttle is only needed in short burst. Hacker B50 motor is three years old (was in the JePe A-4 I sold). As you can also see from the video, all the Kokams 3200's HD have temp monitors on them, they barely reach 50 deg Celsius at the end of the flight (Kokam have been run to 80+C with apparently no adverse effects ).
The Kokam cell in question was one year old (jan 05) and the leak was at - or very close to - the tab, unfortunately the older tabs & pcb connectors are a bit thin for a full 20C (64A) load. The tabs can get quite hot if conditions are right:
http://www.rcgroups.com/forums/showt...=302171&pp=100
Mechanical stress on the thin Kokam tabs might also have played a role.
Some germans (cells are sold individually there) use a much beefier pcb board & connector setup on the Kokam 3200's :
http://www.rc-network.de/forum/showt...ght=Kokam+3200
Old Feb 15, 2006, 11:57 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
MiG-15 power options
Just so as to avoid possible misunderstandings, this particular MiG-15 is very light, and will fly very well already on 600-700 Watts!!! My setup is just one of many possible (see comments below).
That the MiG-15 is very light is clearly seen from Atindra's videos (he flies it on a Mega 20/xx), and from the smooth glide on mine (right Bob?).
There are a number of reasons why I went with the specific setup: I standardized batteries over a year ago (I only own & use multiples of 3S ) and motors (Hacker B50-18S) so that both motors and batts are interchangable (ie, if I smoke a motor in the Rafale, which luckily has not happened yet).
Ok, so having said that, I think an ideal setup for the MiG-15 might be a Kokam 3200HD (or similar) 4S pack combined with a motor delivering ca. 700-800 Watts. That would shave off another 160g=5.6oz, and bring the weight down to a ridicoluous 57 oz (1.62kg). This is exactly the kind of setup that Ulf Herder used in his SOD ("Scrape Off the Dirt" ) Aeronaut Panther, and it still delivers a respectable 200W/lbs.
You have also to keep in mind that if you add too much weight, the wings will fly off, it's not a question of if, only when . That's one further reason I tend avoid wild areobatics on these kind of birds, wings coming off are not a pretty sight, esp. when there are bystanders.
Old Feb 15, 2006, 12:07 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
One more note, these 3S packs have all comparable dimensions, and so I think will fit in width/height (lenght is not much of an issue) in the MiG-15:
Kokam 3200 131x43x23mm 240g
PQ 3700XP 130x44x21mm 255g
Tanic 3650 135x44x21mm 273g
XCell 3900 134x43.5x21mm 276g
Above dimensions and weights are without shrinkwrap, cables etc.
Looking at the data above you can see all four are very close in size and weight.
Old Feb 17, 2006, 10:24 PM
kriptonic's Avatar
Los Angeles
Joined Aug 2004
Hey Herb, Steve (U812) sends his regards, drop him a line over at www.wattflyer.com He'll be in the EDF section.
Gene
Old Feb 19, 2006, 02:04 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Gene, Thanks for the link ...
Old Feb 21, 2006, 08:35 AM
Joined Apr 2003
Nearly ready
OK my Mig is just about ready. I hope to fly it on Sunday.
Having looked carefully at the other set-ups I chose to go a different route with the battery location. Instead I cut a new hatch around the cockpit area and as you can see by the pic I think it looks like it was meant to be like this. In fact I would recommend this to anyone contemplating the model. I have used a 6S2P battery of the Hyperion LiteStorm CL2100ís (Thunder Power 2100ís).
The CG is smack on 170mm with this layout. Looking at Herbs comments I think this will be OK.
I am using the Kontronik 600-17 and static load is 57A @ 21.3V = 1214W. This drops back to around 1150W. I think in the air it will drop to around 1050W. I will check this with the Watts Up meter.
Gregg
Old Feb 21, 2006, 09:55 AM
Joined Dec 2000
Outstanding Gregg!
I have all of my items needed to put mine together.
I had planned on inserting my Packs(Kokam 3200's through the canopy opening but will have to take a closer look now.
BTW I watched herb fly his from the California grass
two weeks ago this is a very nice flying model, I'm sure you will be very pleased.
Bob
Old Feb 21, 2006, 10:43 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Can retracts be added with out much trouble?
Bob
bruff is online now Find More Posts by bruff
Old Feb 21, 2006, 04:50 PM
Joined Apr 2003
Bruff
No, I donít think this airframe would take it. Check the picks back at the beginning of the thread.
Gregg
Old Feb 22, 2006, 09:39 PM
Joined Apr 2003
Herb,
Bob
Say Bob
Did you make any of those canopy's. With my setup it would be real easy to make a cockpit.....
Gregg
Old Feb 23, 2006, 01:49 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... BTW I watched Herb fly his from California grass ...
Sorry Bob this time you only got to fly the Spitfire ...
Old Feb 28, 2006, 03:42 AM
demetrius's Avatar
Van Nuys
Joined Mar 2004
I've accumulated a few more pictures of the MiG-15 ... The Midifan took some vinyl tape to balance properly on my magnetic balancer.
Later the Hacker B50 was mounted with a nice cooling gap, it will need it .
Hi Herb, i am not sure what's vinyl tape, Is it red duct tape or similar to duct tape? Where did you get it?
Also, what's in the gap between the hacker and the fan? The blue substance?
thanks
New Product WeMoTec Mig 15 termite Electric Ducted Fan Jet Talk 3 Feb 11, 2006 09:22 PM
MiG-15 by Kamdax Herb Electric Ducted Fan Jet Talk 70 Dec 28, 2004 01:03 AM
MIG 15 by Graham Cornford dave morris Electric Ducted Fan Jet Talk 5 Aug 03, 2001 07:49 AM
