This thread is privately moderated by Stark Flyer, who may elect to delete unwanted replies.
Old Nov 11, 2005, 04:39 AM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
thanks jim.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Nov 11, 2005, 11:43 AM
Stark Flyer is offline
Find More Posts by Stark Flyer
Stark Flyer's Avatar
Canal Fulton, Ohio
Joined Jun 2003
If it helps I fly that blue foamie of mine with a Park 370 5400kv motor, 10x8 prop, GWS "D" gearing with a 2S pack. At wot it justs barely goes verticle. Plane weighs 9.6oz without the 2S battery. If I recall correctly it draws around 10 - 11amps static at wot. Motor is a little warm to the touch. I put a 3S 2100 pack on ot once and it went ballistic. Motor was pretty hot.
Dick
Stark Flyer is offline Find More Posts by Stark Flyer
Old Nov 12, 2005, 01:51 PM
Tommy632 is offline
Find More Posts by Tommy632
Mayor of Simpleton
Tommy632's Avatar
Cleveland, OH, USA
Joined Oct 2002
Originally Posted by jmullane
I put the 370 4100 Kv in MotoCalc with a 9 x 6 prop and a 3s 1320 Lipo:
Batt Amps = 25.7
Motor Amps = 25.7
Motor Volts = 9.3
Input (W) = 239.7
Loss (W) = 206.3
MGbOut (W) = 33.5
MotGb Ef(%) = 14.0
Shaft Ef(%) = 11.7
Prop RPM = 5553
Thrust (oz) = 9.6
PSpd (mph) = 31.6
Prop Ef(%) = 0.0
Total Ef(%) = 0.0
Time (m:s) = 3:05
With a 12 x 6 prop.....
Batt Amps = 24.7
Motor Amps = 24.7
Motor Volts = 9.4
Input (W) = 232.4
Loss (W) = 214.7
MGbOut (W) = 17.7
MotGb Ef(%) = 7.6
Shaft Ef(%) = 6.5
Prop RPM = 3062
Thrust (oz) = 9.3
PSpd (mph) = 17.4
Prop Ef(%) = 0.0
Total Ef(%) = 0.0
Time (m:s) = 3:12
Those numbers seem odd. Did you include a gearbox in that??
Tommy632 is offline Find More Posts by Tommy632
Old Nov 12, 2005, 03:34 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
went to hobby town and traded in the park 400 (can) for the 370 out runner. we'll see if it works.
Old Nov 12, 2005, 09:07 PM
RktMan is offline
Find More Posts by RktMan
Something Clever
RktMan's Avatar
Cleveland, OH
Joined Aug 2005
Tommy,
I attached a picture of the MotoCalc screen. This is how I received the numbers listed above.
Jim
RktMan is offline Find More Posts by RktMan
Old Nov 12, 2005, 10:31 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
you need to add a gearbox , the way you have it set up is as a direct drive, that is why the amps are so high.
The Don is offline Find More Posts by The Don
Old Nov 13, 2005, 01:50 AM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
so what are you saying, don? this is the wrong motor for this plane (E-flite Park 370 Outrunner 1360kv)?
the plan calls for either a GWS EPS100-A or EPS300C-C and the AUW is around 12oz.
i plan on using a 2S lipo too.
Old Nov 13, 2005, 05:21 AM
RktMan is offline
Something Clever
RktMan's Avatar
Cleveland, OH
Joined Aug 2005
MotoCalc with a Park 370 Outrunner 1360Kv / 9 x 6 Prop Direct Drive/ 2s Lipo
Batt Amps = 13.4
Motor Amps = 13.4
Motor Volts = 6.8
Input (W) = 90.5
Loss (W) = 28.5
MGbOut (W) = 62.0
MotGb Ef(%) = 68.5
Shaft Ef(%) = 62.7
Prop RPM = 6821
Thrust (oz) = 14.5
PSpd (mph) = 38.8
Old Nov 13, 2005, 08:13 AM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
thanks again jim. those numbers look good.
Old Nov 13, 2005, 08:49 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I am saying the motocalc simulation shown used a Park 370 inrunner with a KV of 4100 running a 9x6 direct drive prop. So you would need a gearbox added to it to lower the amps. Or the simulation changed from and inrunner to an outrunner , but then the KV would have to change from 4100 to 1360.
Old Dec 01, 2005, 11:22 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
besides don, who has done a Xtal exchange with radicalrc?
Old Dec 26, 2005, 12:15 AM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
has anyone ever used the Dean's 3 pin for the ESC to motor connection. i'm thinking about using these for a CDrom with a CC TB9 on a 2S lipo. i have bullet connectors on the motor now and this may be a weight issue.
got it done. yes it works. nice and light too. although it was running the wrong direction, i hooked it up to the PHX-link and made the change. running good now!!
Old Dec 28, 2005, 12:44 PM
Tommy632 is offline
Mayor of Simpleton
Tommy632's Avatar
Cleveland, OH, USA
Joined Oct 2002
Hey Jack, I just got some of these from Parma Hobby. http://www.astroflight.com/e/env/000...roducts:af-520 There non-polarized.
Tommy
Old Dec 28, 2005, 04:30 PM
Carnifax is offline
Find More Posts by Carnifax
Carnifax's Avatar
Cleveland
Joined Jun 2002
I got some of those Deans micros for the ESC-Motor connection. They work well but you have to patient when soldering them.
Carnifax is offline Find More Posts by Carnifax
Old Dec 28, 2005, 05:52 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
thanks tommy.
those would probably work since i am only (hopefully) going to draw less than 5 amps.
