Old Aug 15, 2005, 06:22 PM
Splummer is offline
Find More Posts by Splummer
Joined Dec 2001
31% Comp-Arf Video
Late last year the 31% Composite -Arf With Twin Hacker Motors was completed, since then The model has been flown many, many times. We have had several requests for video. Here is some video of Jason Shulman on the sticks.
31% Comp-Arf Video from July 2005:http://www.rccraze.com/comparf.mpg
Original Build Thread from Fall 2004:http://www.rcgroups.com/forums/showthread.php?t=287915
Sean Plummer
Hacker Brushless Motors
Splummer is offline Find More Posts by Splummer
Site Sponsor
Old Aug 15, 2005, 08:18 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Beautiful plane, as usual Jason makes it look easy. The prop sound is awesome!!! Thanks for sharing the video with us Sean. What is the wing loading on that big guy?
BTW, any plans on selling power systems like this already put together?
GregG is offline Find More Posts by GregG
Old Aug 16, 2005, 01:54 AM
Sul1 is offline
Find More Posts by Sul1
Sul1's Avatar
Midlands, UK
Joined Aug 2004
Great video Sean I followed your thread closely and decided to use the same power setup in a comp-arf 2.6m extra. I've got the plane mostly finished, should be under 25lbs, but am waiting on the gearbox from inner demon. I spoke to Dan there and he recommended a 5.5 to 1 gearbox, and suggested I wait for the new Hercules box - should be available mid September. I'm going with C50 16xl's and either a 26 or 27" APC prop. Any suggestions/tips on the setup would be much appreciated.
Cheers, Sul.
Sul1 is offline Find More Posts by Sul1
Old Aug 16, 2005, 02:44 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
What rpm do the 26x15" prop spinn?
Jocke is offline Find More Posts by Jocke
Old Aug 16, 2005, 10:33 AM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Great video Sean ! Thanks for sharing
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Aug 16, 2005, 10:37 AM
TRuss is offline
Find More Posts by TRuss
United States, OR, Salem
Joined Jan 2004
I've seen that plane in several photos and I have always thought that is quite beautiful. It is nice to finally see it in action. On that note. What the hell!? I'm sure if you asked Jason how he got so good, that his answer would be; practice , practice, practice. The thing is. I've flown a lot of flights in my days. I'm not saying that I suck. I can usually get 'em up and down in one piece...but no amount of practice will ever get me flights like that. So good.
TRuss is offline Find More Posts by TRuss
Old Aug 16, 2005, 10:54 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Wow! Nice video. If it weren't for the overcast sky I'd say it's the best I've ever seen. Certainly Jason was on that day. What fantastic pilot he is.
Thanks for posting the vid.
Wiz
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Aug 19, 2005, 12:12 PM
Splummer is offline
Joined Dec 2001
This morning I did a Whatt meter and Tach Measurement. Here are the measurements:
2ea.C50 16XL
2ea. Master 77-0-Flight
InnerDemon 32 @ 6:1 Ratio
1ea. Thunder Power 10S5P
Static test was performed at 95 degrees F. at 1000' ASL
Static Amps each Motor= 59Amps@35.5 Volts
Static Prop Rpm= 5400 rpm using APC-E 26x15
Static Thrust= +38LBS (Using fish scale attached to tail of model)
Sorry for the quality of the pics, the prop blast was very strong bouncing the camera around.....
Best Regards,
Sean
Site Sponsor
Old Aug 20, 2005, 03:09 AM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Lets see if i get this right... 2x 59A x 35,5v ..... 4189watts? and 5400rpm on 26x15 APCE.
What doas the setup weight... 2 motors, 2 controllers, 2 batterys ?
Old Aug 20, 2005, 08:04 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
2ea.C50 16XL
Static Thrust= +38LBS (Using fish scale attached to tail of model)....
Those are some impressive numbers. What does the motor eff. work out to?
Old Aug 20, 2005, 09:49 AM
Splummer is offline
Joined Dec 2001
Jocke,
Here are the weights of the system:
2ea C50 16XL@15oz.=30oz
2ea Master 77-0-Flight=4oz
1ea Thunder Power 10S5P=71oz
1ea InnerDemon Gearbox=8oz
Total system weight 113oz or 7lbs, to Produce +38 LBS of Thrust!!
Sean
Site Sponsor
Old Aug 20, 2005, 10:46 AM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Wow sounds havy to me!!!
Old Aug 20, 2005, 11:59 AM
Splummer is offline
Joined Dec 2001
Jocke,
Please tell me a Power system that is lighter than 7Lbs(3.2Kg) and WILL PRODUCE +38Lbs(+17.3Kg) Thrust?
Sean Plummer
Hacker Brushless #1
2000,2002,2004 FAI F5D World Champions
2004,2005 FAI F3A USA National Champions
2004 FAI F3A European Champion
Site Sponsor
Old Aug 20, 2005, 12:11 PM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
No i cant tell you that yet but i know that a Pletti Terminator (920g) swings a 26x15" @ 5200rpm+... one motor-one controller-no gearbox
Will soon try a Actro 60 on simular setup and i think it will deliver simular performance!
Old Aug 20, 2005, 12:20 PM
Splummer is offline
Joined Dec 2001
Jocke,
What you say seems like a joke, just to cause confusion.
Again you offer only theory , SHOW ME THE SYSTEM!!!! Show the video and REAL DATA like I show you!
I always hear about these fantastic systems from EUROPE, but NO PROOF......
-Sean
Site Sponsor
Sukhoi SU 31 Aerobatic ARF parkflyer from Simprop Cayman Electric Plane Talk 9 Jul 25, 2009 04:39 PM
Comp ARF whistle for AFP Fly-guy Simulators 0 Jan 06, 2005 01:47 AM
NEW Comp-ARF Extra 2x2 KodyK Sport Planes 43 Dec 09, 2004 09:17 PM
Sukhoi SU 31 Aerobatic ARF RC Park Flyer deadstk Aircraft - Electric - Airplanes (FS/W) 0 Jul 31, 2003 06:38 PM
Sukhoi SU 31 Aerobatic ARF RC Park Flyer YZYgold Sport Planes 4 Aug 18, 2002 12:48 PM
