You might try a MEC Turbo 10 GT on with their 6:1 reduction box. 8-10 cells and a 13x7 folding prop. This is not really cheap, but I'd guess it costs less than the cobalt motor. You can find this setup at www.modelelectronicscorp.com
Matt |
Bristol, England
Joined Aug 2000
Hi Newton,
Yes it is a lot of use, but it might take a little experimentation. If the end bell is simply crimped over, and it says "ROAR Legal" it is a 27 turn "stock racing motor" that would probably take the stock prop on direct drive. Does it not say how many turns on the label?Your motor is probably a "Modified" with adjustable timing, in which case you will HAVE to use a gearbox. If you have 6 cell packs to start with I would use them for initial tests with this motor. If you can tell me the number of turns, I can give you some idea of the starting point for gear ratio and prop size. For a 19 turn car motor at around 2.5:1, I would suggest starting with something like 9x7 or 10x6. This is some useful reading to start with: http://www.ezonemag.com/disc/Forum1/HTML/005358.html I would also do a search (top right of the screen) on "car" and "buggy" in Open Discussion and Modeling Science Regards, John |
| Thread Tools | |
| Poor Man's Heat Shrink for Homemade Battery Packs... | flytowner | Parkflyers | 28 | Mar 12, 2010 11:45 PM |
| Poor man's Helistar | Iain | Micro Helis | 25 | Dec 01, 2005 06:15 AM |
| Poor man's cheap repair !!! | jnyoun | Micro Helis | 9 | Oct 06, 2003 01:20 PM |
| What to do? W/lb of poor man's F5B (long post) | 96S14 | High Performance | 14 | Sep 29, 2003 03:02 PM |
| Poor man's Super Slow Stick fun flyer? | uglyplane | Parkflyers | 1 | Jul 03, 2003 11:54 AM |
