Old May 02, 2002, 08:13 AM
thor4944 is offline
Find More Posts by thor4944
thor4944's Avatar
Joined Feb 2002
Easy way to find C.G.
I am not the sharpest tool in the shed so I wanted to find the c.g. for my plane...I am a Biology teacher and I asked our Physics teacher how he would find the C. G. for my airplane. He said the easest way to do it is...
1. Tie a heavy object to a string
2. Put a pin in one wing (did not want to put a hole in my plane so you can hold it up with two fingers so it can swing freely, does not matter where, I like the top of the wing)
3. Where your finger is hold the string with the heavy object hanging like a swing. and draw a line where the string crosses the plane.
4. Do the same thing to the other wing and where these lines cross there is your C.G.
* I dont know how to put more than one pic on a thread so I have them numbered as the steps are...what do people think of this way.....?
This pic is pic 1
thor4944 is offline Find More Posts by thor4944
Old May 02, 2002, 08:14 AM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
Picture 2
Pic 2
Old May 02, 2002, 08:16 AM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
Picture 3
Pic 3
Old May 02, 2002, 08:17 AM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
Pic 4
Picture 4
Old May 02, 2002, 08:18 AM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
Pic 5
Picture 5
Old May 02, 2002, 09:08 AM
mtayl is offline
Find More Posts by mtayl
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Sure enough. That worked great on an old 400X with the battery in it. It crossed exactly at 8". Very cool. I need to try this with all of my other wings. I had to keep the battery in it, otherwise it wound up at 10 inches or so.
mtayl is offline Find More Posts by mtayl
Old May 02, 2002, 09:19 AM
mtayl is offline
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Where the superimposed red line is and the ribbon is exactly 8". (My bottom spar is a bit forward)
Old May 02, 2002, 09:22 AM
mtayl is offline
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
I just had a thought though. Let us assume that you build a new wing with no instructions. There are calculations to figure out where the CG should be. This will only show you where it is, not where it needs to be. Right?
Even so, this is a lot more accurate for me than balancing it on my fingers.
Old May 02, 2002, 09:30 AM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
Yep
Yep......it shows you where the C.G. is in your plane..what is pretty cool is you can hold the wing any place as long as it freely swings and you place the string with the weight were your hand is and the C. G. should be the same place.....I just know I am not a very smart person (at least with planes) and this was a very cheap and easy way to find it...I had problems with the pencil on the bottom of the plane.........certain problems keeping the marking it once I found it....Hope this helps...........
Old May 02, 2002, 10:53 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
That is a very sensitive method.. works with wing-tail-fuselage planes also.
Sparky Paul is offline Find More Posts by Sparky Paul
Old May 02, 2002, 11:00 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Well, of course. The battery has mass, which will affect the C.G.. Always find the C.G. of an airplane in ready-to-fly condition. The only exception is in the case of a slimer with the fuel tank in front of the C.G.. In that case, you want to find the C.G. with the tank empty because the plane gets tail heavy when as tank empties.
Nose heavy flies poorly, but tail heavy flies once.
mkirsch1 is offline Find More Posts by mkirsch1
Old May 02, 2002, 12:54 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Mytal has it correct.
Your method will, in fact, show where the CofG is.
Bear in mind, though, that CofG location may be absolutely incorrect for flight.
Take your ZAGI, move the battery pack either way, do the CofG thing again. You will find the CofG is now in a different location, one that may be unsafe for flight.
I know of two ways to determine the correct CofG.
One is to build a 'chuck' glider of your model. Balance this until it glides in a nice flat trajectory. Hang it by a string, adjust the hang point until the plane hangs level, note the location of the hang point. Transfer that location to you full size model. Bingo, CofG location is solved.
The other method involves calculations of the wing area, horizontal stab area, tail moment (which requires the mean aerodynamic chords of both the wing and horiz.stab). If the wing has either forward or aftward sweep, that has to be accounted for in the M.A.C.
Then plug all the values into the formula (see May 2000, EFI). The answer is expressed in inches aft of the leading edge, measured on the MAC.
I have used both methods while building a 48" WS twin EDF jet with a swept back wing. The numerical value placed the CofG about 1" farther forward than the chuck glider.
Either location would be suitable for the initial flights, the mathematical location being the safer of the two.
After the initial flights, the CofG is then tweaked to suit your flying needs.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old May 02, 2002, 02:31 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Neat trick
Thats a cool trick.
I know of two other way to find where the CG should be.
one is a graphical drawling of the wing show on page 2 of this post 6th post down
http://www.rcgroups.com/forums/showt...t&pagenumber=2
The other is to use a program that can find the C of G of a drawn object,, $$$$$ or a cool little freeware program I found linked in the above thread and was so kind to attach to this post
BTW,, the freeware prog lets you do forward and rear swept wings as long as you know the angle,,,,,, spits out the Mac and you just X that by you .25 for distance from LE.
JasonJ is offline Find More Posts by JasonJ
Old May 02, 2002, 02:55 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Uhh... what ever happened to the balance it on your finger method?
Jim McPherson is offline Find More Posts by Jim McPherson
Old May 02, 2002, 03:04 PM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
Wait
Now wait....this is why I just do it my way...I get a plane and put the battery and everything in where I want it when I fly...balance it out and find the C.G. if I dont like the C. G. I add weight to the nose..and do it again....calculators and measuring stuff...naaaa I would rather fly!!!!!
Discussion Whats an easy way to find out if your wing is warped? arukum17 Sailplane Talk 9 Jan 01, 2006 09:16 PM
help me find the C.G. of a fuselage xoon The Builders Workshop 2 May 24, 2004 11:44 PM
I Need to Find the C/G of a Pizza Box. Boss248 Modeling Science 1 Mar 07, 2004 03:49 PM
What method to find C of G? FEARLESS FLY Electric Plane Talk 5 Oct 30, 2003 10:15 PM
How to find the C/G of a delta wing? Travis Power Systems 2 Oct 19, 2001 01:42 AM
