Old Aug 15, 2005, 02:49 AM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
This is why I should fly slope only... (warning this post contains graphic images!)
I was chucking a friend E wing and he hit the throttle as a I chucked it BANG ouch Blood not good
I said dont hit till AFTER I THROW IT....
So here is reason #834 to fly slope and not power....
Mick Molloy is offline Find More Posts by Mick Molloy
Old Aug 15, 2005, 03:23 AM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Yeeeeoouuuch!
Seeing Bone is not good - that's probably nerve damage waiting for you. See a Dr...
Or, hydrogen peroxide and then thin CA - who needs drs? You got rcg!!!!
ajroahkni is offline Find More Posts by ajroahkni
Old Aug 15, 2005, 03:33 AM
MINE!
Joined Jul 2003
Originally Posted by ajroahkni
Yeeeeoouuuch!
Dont laugh I was going to do that... isnt that a use for CA, eye Surgery
Old Aug 15, 2005, 04:29 AM
Ozprey is offline
Find More Posts by Ozprey
Fix all the things!
Ozprey's Avatar
Australia, ACT, Canberra
Joined Jan 2004
Howdy from IMAC, Mick
Yeah, CA was first intended to patch up small wounds, as opposed to sewing them up as normaly done. Vietnam era invention I belive. Nasty cut anyway, we've had a few guys do that here. One was through a tractor prop on a pylon model. The launch man's thumb slipped and went through the prop. Not pretty.
Peter
P.S
Let Brandon know I'm working in a hobby shop, and say hi to him for me.
Ozprey is offline Find More Posts by Ozprey
Old Aug 15, 2005, 06:34 AM
AntonL is offline
Find More Posts by AntonL
antipodean recalcitrant
AntonL's Avatar
Melbourne, Victoria, Australia
Joined Feb 2004
Nasty wound there Mick. Sorry to see/hear about the misfortune. I'd definitely see a doc if I were you.
Anton
AntonL is offline Find More Posts by AntonL
Old Aug 15, 2005, 07:14 AM
groundlooped is offline
Find More Posts by groundlooped
groundlooped
sydney nsw australia
Joined Mar 2005
just use thick cyano
Cheers,Col
groundlooped is offline Find More Posts by groundlooped
Old Aug 15, 2005, 08:00 AM
ZIPPER is online now
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
Mere flesh wound
ZIPPER is online now Find More Posts by ZIPPER
Old Aug 15, 2005, 08:09 AM
MrBlenny is offline
Find More Posts by MrBlenny
MrBlenny's Avatar
Australia, TAS, Hobart
Joined Nov 2004
No its not, your bloody leg is chopped off!
Come back here and I'll bite your head off!
Sorry,
Damo
MrBlenny is offline Find More Posts by MrBlenny
Old Aug 15, 2005, 11:35 AM
screamin' eagle is offline
Find More Posts by screamin' eagle
R/C Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Yikes! They heal quickly. I'm already on the road to recovery (i.e., growing back the missing chunk of my finger) from the utility knife injury I stupidly suffered Saturday while cutting Ultracote...
screamin' eagle is offline Find More Posts by screamin' eagle
Old Aug 15, 2005, 01:27 PM
Stefan Enström is offline
Find More Posts by Stefan Enström
Joined Jan 2005
Hi!
Som info on the use of cyanoacrylate glue to fix people up.
Quote from science.howstuffworks.com :
"Another interesting application is the use of cyanoacrylate to close wounds in place of stitches. Researchers found that by changing the type of alcohol in super glue, from ethyl or methyl alcohol to butyl or octyl, the compound becomes less toxic to tissue. With further research, the practice may become more widespread and could eventually replace the need for stitching up lacerations. "
That is, 'less toxic'.
With a boner like that, I would absolutely go see a doctor!
Best regards
Stefan
Stefan Enström is offline Find More Posts by Stefan Enström
Old Aug 15, 2005, 01:47 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
That suxors! Hope you heal up quick, fingers usually do pretty well with bandages and whatnot but you might want to get some stitches for that bad boy.
Props are dangerous!!!
Steve
surfimp is offline Find More Posts by surfimp
Old Aug 15, 2005, 01:55 PM
Cody WIlson is offline
Find More Posts by Cody WIlson
plane obsessed
Cody WIlson's Avatar
Denver, CO.
Joined Nov 2003
Medium CA should do the trick! just make SURE it's closed first- oh yeah, and no kicker!
Cody WIlson is offline Find More Posts by Cody WIlson
Old Aug 15, 2005, 02:04 PM
RCFlybry is offline
Find More Posts by RCFlybry
Faster Faster!!
RCFlybry's Avatar
Kaysville Utah, U.S.A
Joined Oct 2001
I'm sorry I couldn't resist. That's how my 3 month old son came about! For God's sake see a doctor fast! You never know what may come of it. Sorry 'bout the cut though. Hope this cheers you up a tad.
Bryan
RCFlybry is offline Find More Posts by RCFlybry
Old Aug 15, 2005, 02:16 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I use CA on most of my cuts these days. I find that they heal much
cleaner, without a scar, than having some sweaty bandaid over it
for a week. Also helps seal up painful punctures from cactus and
stops em from itching and such. I had a cactus needle get stuck under
the edge of one of my fingernails recently and after I finally dug it out,
the whole area was incredibly sensitive when touched. A little CA
made all the difference in comfort.
Instead of squirting the CA directly on the wound (which usually results in
it running all over my hand) I usually drip a drop of super thin on my glass
table and then simply touch that spot with the cut spot on my finger. Yes
you don't want to user kicker, but you do need to make it go off fairly quickly,
otherwise the blood from the cut will ooze out into the CA before it
cures which just looks nasty (still works though).
ian
Daemon is offline Find More Posts by Daemon
Old Aug 15, 2005, 02:27 PM
Daniel G is offline
Find More Posts by Daniel G
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
I had an index finger cut to the tendon while cutting some scrap foam to repair a wing.
It took 4 stitches and a tetnis shot to fix it up.
Daniel G is offline Find More Posts by Daniel G
This is why I like to fly WITHOUT people around!....ugghh. mike93 3D Flying 19 Nov 14, 2005 02:28 AM
Discussion You guys should read this post FRAMEDNLVS Electric Plane Talk 10 Nov 20, 2004 04:54 PM
How do I make an avatar??? where should this post go? willin Site Chat 4 Oct 13, 2004 06:53 PM
