Dynamics of Bungee Launching
A look at the physics of the bungee launch, a frequently used method of launching EDF jets. The data and results are particular to my plane but the methodology could be applied to any model.
ANATOMY OF A BUNGEE LAUNCH
Mr. Kevin Rose of Rose Aviation Service (Akron, NY) owns and flies a Fouga Magister, a 1960’s era jet trainer that was used by the French Air Force. As I am always on the lookout for the unusual to model, his Magister was the perfect candidate. Kevin graciously allowed free access to his Magister, which I crawled in, on, under and over every inch. Armed with a tape measure, I gathered the dimensions needed to draw a set of plans. The result was a 1/8 scale Magister, 56” wing span (12% Clark Y, 354 sq. in.) and weighing in at 48 oz. A Wemotech MF480 ducted fan driven by a MEGA 16/15/2 brushless motor (275 watts) powers the Magister.
My intentions were to hand-launch the Magister but two unsuccessful attempts persuaded me to try a bungee launch. Bungee launchers (think aircraft carrier catapults) are simple to make and use. Mine consists of a nylon leader, the bungee cord, a foot release, an anchor pin and a launch ramp. To use, just stretch the cord between the anchor and the foot release, place the Magister on the ramp, attach the leader to the Magister, step on the release and the Magister is airborne. Power is applied after the cord drops away.
Out of curiosity, I decided to analyze the bungee launch. Using a tape measure, a “fish” scale, my observations, an old Physics textbook, some assumptions and a flat out guess, I quantified the bungee launch.
MEASUREMENTS
A “rule of thumb” is the bungee tension should be about 5 times the weight of the aircraft. The cord I am using allowed a maximum stretch of 154 feet, resulting in 13 lbs. of tension, not quite 5 to 1 but close. Of this length, 10 feet is leader and 54 feet is the relaxed length of the bungee. So the actual stretch of the cord is 90 feet.
A textbook review led me to “HOOKES LAW” concerning springs and spring constants.
F=K*X
Where F is expressed in lbs., K is the spring constant expressed as lb./ft. and X is the spring stretch in feet. I measured the tension in 10-foot increments and found the spring constant varied between .25 lbs./ft. at 10 feet of stretch to .144 lbs./ft. at 90 feet of stretch.
OBSERVATIONS
  • The launch takes about 1 second.
  • The altitude of the Magister, just after release, is about 30 feet AGL.
  • The speed of the Magister, just after release, is somewhere between 30 and 50 MPH. I find it very difficult to estimate velocity but I know its not 15 MPH and its not 100 MPH.
  • The bungee cord falls to the ground in front (up-field) of the anchor pin, not behind (down-field).
PHYSICS
Tension is a vector quantity that resolves itself into horizontal and vertical components. The horizontal component is what pulls the Magister forward while the vertical component pulls downward and adds to the weight of the Magister.
Once released, the bungee cord is horizontal for only a fraction of a second. As the Magister accelerates it gains altitude and increases the cord angle with the ground. The horizontal component of the tension is reduced by the cosine of this angle.
The energy stored in the bungee cord is equal to ½* K*X^2 where K is the “spring constant” of the bungee and X is the stretch distance.
The kinetic energy of the Magister is equal to ½*M*V^2 where M is the plane’s mass and V is velocity in ft./sec.
MY ASSUMPTIONS
By setting these two expressions equal to each other, the velocity of the Magister can be calculated as:
V = [(K/M)^. 5]*X
MY FLAT OUT GUESS
I drew a scale launch trajectory that I divided into 10-foot increments. Drawing lines that represent the cord at each point, I measured the length of the cord and the angle from the horizontal. From these measurements and F=K*X, I determined the total tension and both the horizontal and vertical components at each point along the trajectory.
CALCULATIONS
Click to open these images.
I calculated the Magister’s mass by dividing its weight by the gravitational constant Gc (equal to 32.17); thus the 3 lb. Magister’s mass is .09325 “slugs” (the "slug" is the unit of mass in the English Engineering System and its measurement is lbs.*sec^2/ft. Its counterpart in the MKS (metric) system is the kilogram).
I then calculated the total energy stored in the bungee. Based upon my trajectory drawing I calculated a value of [½* K*X^2] for each 10-foot increment. I then drew a graph using these values as the “Y” axis and the stretch length as the “X” axis. The calculated area under the curve was equal to 20571 lbs*ft^2. Dividing this by 90 feet yielded a stored energy of 228.6 ft*lb. It is important to note I have neglected all losses for this calculation.
Setting this value equal to ½*M*V^2, (kinetic energy of the Magister) yields a velocity of 70.0 ft/sec (47.7 MPH), assuming no aerodynamic drag.
I then plotted a second graph with total tension as the “Y” axis and stretch distance as the “X” axis. I determined the area under this curve to be equal to 735 ft*lbs. Dividing this by 90 feet yields an average tension of 8.2 lbs. Again, I have neglected all losses for this calculation
Typical graph  n/a
Solving F=M*A for A, using 8.2 lbs of force and a mass of 0.09325 slugs, the Magister’s acceleration is 87.6 ft/sec^2 or 2.7 G!!
From V=A*t, with V=70 ft/sec and A = 87.6 ft/sec^2, the elapsed time for the launch is 0.8 seconds, again, neglecting all losses.
Looking at the elapsed time from a displacement point of view and solving X = 1/2 A*t^2, with X = 90 feet and A = 87.6 ft/sec^2, the elapsed time for the launch is 1.43 seconds, again neglecting all losses.
I think it is safe to say the elapsed time is somewhere between these two values, again neglecting all losses.
CONCLUSIONS
Based on my assumed trajectory, the last interval of interest had a stretch distance of 64 feet, which is the length of the nylon leader plus the natural length of the bungee. Thus the cord tension is now zero and no further energy is imparted to the Magister. Since the tension in the cord is zero, there is nothing to keep the nylon leader attached to the launch hook. Due to drag on the bungee, the cord falls away. My trajectory drawing indicates the cord separates from the Magister about 50 feet before the anchor pin. The cord’s momentum and weight carries it forward and down, toward the anchor. This is borne out by my observations of the cord falling to the ground before reaching the anchor pin.
The maximum vertical component of cord tension was calculated at 44 feet down field, a bungee stretch distance of 111 ft. and 9 degrees from the horizontal. The cord tension added 0.8 lbs to the weight of the Magister for an apparent weight of 3.8 lbs. The vertical component decreased thereafter.
SUMMARY!
These calculations agree with my observations but without a means of measuring velocity and altitude, they cannot be confirmed. An accurate launch trajectory is crucial to the analysis but this requires very sophisticated video equipment. So my guess will have to suffice. In my fifteen (15)launches to date, the cord always fell to the ground before the anchor pin.
The effect of aerodynamic drag, which I assume to be 10%, may or may not be correct for the Magister. Further, my assumption of perfect energy transfer from the bungee to the Magister is not valid, the loss being somewhere between 25 and 35 percent. Considering 10% aerodynamic drag and and a 25% loss of energy from the bungee to the Magister, the Magister's velocity when the hook drops away might be closer to 63 ft/sec. If I assume a 2 G acceleration (25% loss of energy) the elapsed time for the launch is somewhere between 1.0 and 2.0 seconds. Not an unreasonable value when compared to my observation.
Changing the weight of the Magister, the launch hook location, the strength and/or length of the bungee cord will change the results. A more accurate scale would be helpful. Checking my scale against two gallons of water (16.6 lbs) leads me to believe the scale reads 10% high. !
The bungee launch is very effective when a hand launch can’t be achieved or your plane does not have landing gear. Prior to any first flight, it’s imperative to know where the CoG is located. If the plane is a kit, this is usually not an issue as the CoG has been established. But if the plane is a scratch built model, careful attention must be paid to this critical area.
The attachment of the launch hook to the fuselage requires some thought, as this is what must sustain the G forces of the launch. The hook has to be located ahead of the CoG and if it is going to come loose, it will do so during the bungee launch.
I have also made power-on launches. The EDF thrust adds to the cord tension and results in much higher altitude and velocity at time of release. While this is a subject for another investigation, I can report the cord still falls up field of the anchor.
I chose the Clark Y because of its high lift at low speed, making it an ideal wing for hand launching. If I were designing for a bungee launch I might have chosen a thinner airfoil that would result in less altitude but higher velocity.
A bungee launch gone badly is not a pretty sight. In about one second, the plane can accelerate to 60~70 ft/sec. At this speed, one can expect a lot of damage if the plane fails to get airborne and heads for the dirt instead.
Old Aug 13, 2005, 07:33 PM
sguty is offline
Find More Posts by sguty
Senior Member
sguty's Avatar
Redmond, WA, USA
Joined Oct 2000
Thanks for going through the analysis, Larry--especially with the added complexity of doing it in English units! (Nothing like having to convert to slugs...)
Your comment on the added apparent downward force on the plane from the bungee tension at even a modest angle of climb makes me wonder how many bungee crashes are simply due to applying too much up elevator and entering an acclerated stall. I'd suspect almost all the dutch-roll type bungee crashes start with an accelerated tip stall
I use about 25 feet of 3/8: latex tubing with a 10' nylon twine leader for my HET F-18, and try to stretch for about 15 pounds of pull. I launch with power on and no ramp--I hold my plane ~5 degrees up at chest height in my left hand, and twiddle the stick wtih my right thumb. I've found trying to launch power-off and having to fly the launch as well as get on the power induces pilot overload, at least for me.
I generally see the plane drop to about 2 feet off the deck after launch and just try to hold enough elevator to avoid dropping any further until the ring starts falling away. Lots of expo helps, at least for me--bungee-crash-free since the time I flew into my launch spike at Chilliwack two years ago
sguty is offline Find More Posts by sguty
Old Aug 14, 2005, 10:29 AM
punder is offline
Find More Posts by punder
Joined Mar 2005
Magister
Very nice article. I know this is a bit off-topic, but do you have any, er, plans to publish the plans for your Magister?
Patrick
punder is offline Find More Posts by punder
Old Aug 23, 2005, 07:35 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Punder,
I posted a Magister build article in the EDF forum. If interested do a search on "Fouga Magister" therein to see what was involved as the Magister was a tough bird to build. Bifurcated ducts at both ends plus most of the air frame behind the air inlets is planked. I think it took somewhere about 180 hours to build.
I have the plans but there are no instructions.
If still interested, send me a PM and we'll discuss further.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Aug 23, 2005, 07:46 AM
Joined Sep 2000
Sguty,
The down force added by the cord is very real and could become significant if the bungee tension is very high. I can see why someone would add up elevator during launch in an attempt to over come this added load. In all of my launches, the control surfaces were neutralized with no input until the cord dropped away.
Based on my data for the article, I developed a mathematical model of the launch. The resulting graphs are interesting (well, interesting to me), especially the graph of the launch trajectory.
Your comment "...I generally see the plane drop to about 2 feet off the deck after launch..." confirms my mathematical model's predictions.
I will clean up the text and submitt it as a follow on article
Old Aug 24, 2005, 04:21 AM
polyte is offline
Find More Posts by polyte
JOHNT
West Yorkshire UK
Joined Jun 2004
Bungee launch
An excellant article but one addition is an 'A' frame. After my Cougar hit the stake an idea was shown me by Mark Haigh. He uses a light hardwood 'A' frame about 18" high with a loosely hinged rear support, similar to an artists easel. This is set under the bungee near to the stake with the rear support on the model side. This will direct the model over the stake so in the event of a bad launch it does not hit the stake. The frame will be pulled down with the bungee tension before the model can hit it.It works perfectly.
John Thompson
polyte is offline Find More Posts by polyte
Old Aug 25, 2005, 07:35 AM
Joined Sep 2000
polyte,
Anything that reduces the inherent dangers of a bungee launch is a good thing. With the A frame the cord, at instant of release, is higher than the plane, so any vertical component of the tension will tend to lift the plane. This should make for a more effective launch.
Once your plane's altitude exceeds the height of the A frame, the vertical tension component will reverse and tend to pull the plane down. But by this time, the plane is well on its way to a successful launch.
Good idea.
Article Dynamics of Bungee Launching, Part II Larry Dudeck Electric Plane Talk 0 Nov 04, 2005 01:00 AM
has anyone tried bungee launching with a winch avie Electric Plane Talk 5 Jan 15, 2002 08:42 PM
Bungee launching kscheck Electric Ducted Fan Jet Talk 16 Sep 22, 2001 06:55 PM
Bungee Launching a TwinJet James Frolik Foamies (Kits) 1 Aug 08, 2001 12:40 AM
bungee launching troubles max z Electric Ducted Fan Jet Talk 34 May 27, 2001 07:31 AM
