Old May 01, 2002, 05:47 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
Crazy Max with Flaps
When I made it I used two servos for the Ailerons so not having much to do today I switched it to the new radio and put in Flaps. Only went about hafe throws on the flaps any one tried this or should I mix Flaps and Elev. so I won't get the pitch up or is it pitch down ???
russ6421 is offline Find More Posts by russ6421
Old May 01, 2002, 05:54 PM
DaveA95131 is offline
Find More Posts by DaveA95131
DaveA95131's Avatar
Long Beach, California, United States
Joined Jan 2002
Be careful of the amount of flap you give it, it doesn't take much (I know from personal experience). Also, give the elevator a slight amount of "up" when the flaps go down. My first try at this I had too much flap deflection and too much elevator and when I threw the switch on landing approach the CrazyMax performed and incredibly tight loop almost instantaneously ... Yikes!
Take care,
DaveA95131
DaveA95131 is offline Find More Posts by DaveA95131
Old May 02, 2002, 01:04 PM
Tim Seidenstricker is offline
Find More Posts by Tim Seidenstricker
Boise, ID 83703
Joined May 2001
Start High
I did 25% flaps on my Virus 400A, but it had a 57" wingspan and a bigger plane. I started with 15, but it wasn't enough. I didn't have to add any up elevator, it simply slowed the plane down. Just practice up high in case your plane has an allergic reaction.
Tim Seidenstricker is offline Find More Posts by Tim Seidenstricker
Crazy Max with LiPo Batts on stock motor? Dampy Parkflyers 18 Aug 13, 2005 10:31 PM
Crazy Max with lipos SoaringDragon Parkflyers 1 Nov 04, 2003 07:33 PM
FS - NIB Wattage Crazy Max with servos and Rx. Etonic Aircraft - Electric - Airplanes (FS/W) 1 Jun 29, 2003 02:12 PM
FS- NIB Crazy Max with GWS ICS-300 15Amp ESC Etonic Aircraft - Electric - Airplanes (FS/W) 3 Jun 26, 2003 04:11 PM
I have a Crazy Max with flaps, any tips? pedsnurse Parkflyers 3 Mar 19, 2003 11:17 PM
