Old Dec 30, 2012, 09:53 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
The pad is a simple base made from 2" plastic pipe with a 1/2" bolt to hold the blast plate and rail. There is no adjustment as I launch all of them straight up and pitch into the wind after it clears the rod if needed. I have a hose clamp on the rail about two feet up from the bottom. The launch buttons sit on it so I don't need a standoff and it holds the model high enough that i don't need to worry about any back blast melting the foam. The rail buttons keep the wind from making the model twist due to any breeze. Simple and very stable. I've had tripod based launch pads blow over with gliders on them.
Frank
Originally Posted by ttabbal View Post
Great flights burkefj. Makes me want to get off my butt and build some.
Looks like you're using a standard rail / rod launch pad. Anything unique about it?
burkefj is offline Find More Posts by burkefj
Old Dec 31, 2012, 07:51 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Frank
Beautiful flights, Frank! I noticed on the last video, the X-2 that the ascending fight was more horizontal. Are you using the r/c to control it at that point? Or, at what point are you allowing the r/c to fly, @ apogee? Glen
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Dec 31, 2012, 04:12 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Glen, I steer them on the way up, more or less depending on what I want, and what the wind is doing. The X-2 I pitched over a bit to make sure I was upwind.
This was the first flight where I had only full flying tail controls on that plane(no ailerons) and it has a large wingspan so I wasn't sure how much turning authority I would have and wanted extra room for my approach, turned out to be a non issue.
Also, it isn't as horizontal as the video appears, it's pretty vertical but due to the camera person being in a different spot than me, it always looks like the plane is level or diving when it doesn't look like that me when I'm flying it
On the bomarc, It started to go toward the nose a bit, so I pitched back up vertical and then pitched over when the motor burned out, but on the video, the smoke cloud and wind makes it look like it was doing a sort of corkscrew...
Frank
Old Jan 10, 2013, 06:45 AM
mice1m is offline
Find More Posts by mice1m
Joined Aug 2012
off a bungee
HK Radjet 680r (0 min 39 sec)
mice1m is offline Find More Posts by mice1m
Old Apr 15, 2013, 03:32 AM
clipper is offline
Find More Posts by clipper
clipper's Avatar
United States, CA, Lake Forest
Joined Sep 2005
bungee launched
How are you igniting the motor?
Originally Posted by mice1m View Post
clipper is offline Find More Posts by clipper
Old Apr 23, 2013, 05:49 PM
mice1m is offline
Joined Aug 2012
...with a sparkler..
Old Apr 23, 2013, 09:15 PM
clipper is offline
clipper's Avatar
Joined Sep 2005
bungee launch
You'r prelighting the sparkler? Seems like a marginally safe practice.
Old Apr 23, 2013, 09:59 PM
X30PILOT is offline
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
Agreed, an electronic Radio Controlled air start would be a much wiser chose. That way if the high start launch goes bad you could abort lighting the motor.
X30
X30PILOT is offline Find More Posts by X30PILOT
Old May 11, 2013, 04:52 PM
iter is offline
Find More Posts by iter
High-power Rocket Gliders
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
Originally Posted by iter View Post
Well, the original kit has a full 24" 24mm tube running up the length of the fuselage. I cut mine to 2.5" and put servos right in front of it, but if you put servos further up front, you can use the 6-grain (9") G65. Get some video--I'd like to see the fireworks. On a slightly saner note, a 3-grain (5 1/4") F30 might actually be survivable.
Ari.
Well, this has happened. I have flown the Ecee Thunder on an F30 (83% F longburn). I'm waiting for video to percolate up. In the meantime, here are a couple of post-flight shots. I have servos right in front of the motor mount, so the 5 1/4" motor can only go part way in and hangs off the back.
I'm very happy with the flight and the extra altitude. On the up part it got going pretty fast. I tried to correct a roll and ended up severely overcorrecting. The roll was very axial, and with the glider still going straight up, so no harm came of it, just my surprise at how lively this glider can be with a bigger motor.
My Ecee is fun again!
Ari.
iter is offline Find More Posts by iter
Old May 12, 2013, 10:59 AM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
The CTI F30 is one of my favorite motors. I wonder though, Rob I believe says not to airfoil the balsa,but I think the Ecee is large enough that it could do it much good if an AG type for example was correctly carved into the balsa. Well maybe I'll just have to save up and try it myself.
Saw the video on TRF, love the slow mo take off! Hope you get a full vid on too.
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old May 12, 2013, 03:51 PM
iter is offline
iter's Avatar
Joined Jan 2005
I'm afraid that's all the footage that I have. Cameraman was expecting a shred. He filmed at 240 fps and didn't follow the glider up once it didn't shred :=)
Ari.
Ecee Thunder Cesaroni F30 longburn (0 min 6 sec)
Old May 14, 2013, 08:10 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Ari.
www.youtube.com/watch?v=iBY9XFZB2Z0
This is still a cool vid in slowmo!
Old May 14, 2013, 07:25 PM
iter is offline
iter's Avatar
Joined Jan 2005
240 FPS man!
Ari.
Old May 21, 2013, 08:06 AM
kmj73us is offline
Find More Posts by kmj73us
SPOOOOOOON!
kmj73us's Avatar
Joined Oct 2006
Here is a RBG getting trimmed out prior to the first boost:
kj
kmj73us is offline Find More Posts by kmj73us
Old May 31, 2013, 02:07 PM
mvpricop is offline
Find More Posts by mvpricop
Bucharest
Joined Jul 2010
Kaspichan World Cup, 2013, Bulgaria
S8E/P round 1
Kaspichan 2013 - S8E/P - 1st round (2 min 17 sec)
S8E/P round 2
Kaspichan 2013 - S8E/P - 2nd round (2 min 12 sec)
S8E/P round 4
Kaspichan 2013 - S8E/P - 4th round (11 min 26 sec)
mvpricop is offline Find More Posts by mvpricop
Discussion I have some RC rocket gliders up For Sale jfruge Rocketry 0 Jul 10, 2007 03:47 PM
Discussion anyone else see fred in an rc heli mag? helifrek Electric Heli Talk 9 Dec 29, 2005 08:10 PM
Reloads available for RC rocket launched gliders red arrow Product Announcements 0 Oct 16, 2005 10:10 AM
Anyone else doing an RC club at school? JTinCT Electric Plane Talk 2 Sep 25, 2004 11:16 AM
Anyone else catch "the best RC pilot in the county" tonight? Mikey C. Electric Plane Talk 0 Oct 29, 2003 10:19 PM
