Old Aug 11, 2005, 11:24 PM
ravencsr is offline
Find More Posts by ravencsr
Melbourne, Eastern Sub.
Joined Sep 2004
Do you need an Incidence Meter ????
How necessary are using these instruments when building from plans?
I am building a Kittyhawk that requires +1 incidence on the main wing and 0 on the tailplane. I was thinkink of getting the GreatPlanes AccuPoint Laser Incidence Meter to do this. http://www.greatplanes.com/accys/gpmr4020.html
Is this necessary? Is there anyone who has built their own?
If you just try to 'wing' it from the plans, are you seriously setting yourself up for a fall when it comes to the maiden??
Thanks Raven.
ravencsr is offline Find More Posts by ravencsr
Old Aug 12, 2005, 02:35 AM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
No, you don't. I can't even remember how many models I've built from plans over the years and I've never had any kind of incidence meter, let alone a laser one. You can measure the angles that are "designed in" using a rule and a protractor on the plan itself. If the plan is accurately drawn, and you built the parts accurately according to the plan, then it will be as the designer intended.
If you WANT a laser incidence meter, though, feel free to get one!
Work in Progress is offline Find More Posts by Work in Progress
Old Aug 12, 2005, 05:36 AM
ravencsr is offline
Joined Sep 2004
Thanks Work in Progress
What effect would a couple of degrees have on the flight characteristics of a model in regards to its incidence ??
And how many builders out their use an incidence meter? Is the correct incidence important ?
Old Aug 12, 2005, 05:49 AM
rcminiman is offline
Find More Posts by rcminiman
Scotland
rcminiman's Avatar
I draw my own planes, and ive never used an incidence meter. I got a loan of one once, but never got around to using it. Airfoils like the clarke Y actually still produce lift at -6 degrees incidence.Basically, if it looks right, it normally is right.
rcminiman is offline Find More Posts by rcminiman
Old Aug 12, 2005, 07:23 AM
I. Klemetti is offline
Find More Posts by I. Klemetti
Taken Lightly
I. Klemetti's Avatar
Pietarsaari, Finland
Joined Mar 2003
With high school mathematics, you can calculate the relation between the angle of incidence and the leading edge height.
H = S * sin()
If you are not familiar with trigonometric functions, don't worry. At small angles the sinus function is almost linear. If you measure angles in degrees you can use the following formulas instead:
H = S * / 57.3
= H * 57.3 / S
With the latter formulas the error is less than 0.05 degrees if you are working with angles below 10 degrees. If you need more than 10 degrees angle of incinence, you sure have other problems than just measuring angle of incidence.
So, I have used a ruler and a simple calculator as an incidence meter for years.
I. Klemetti is offline Find More Posts by I. Klemetti
Old Aug 12, 2005, 07:31 AM
Joined Sep 2004
A change of a couple of degrees of incidence on a wing or tail will make a fair diffreence to the trim, so you should try to make the angles accurate. The easiest way to do that is twofold:
1. make your wings and tail surfaces properly warp-free, with the amound of washout specified in the wings
2. build the seats for the wing and tail accurately. Usually these angles are determined at the point where you built or cut out the fuselage sides. Using a long straight edge you can usually draw a line produced by the extremities of the leading and trailing edges of the wing, extend the line back towards the tailplane, produce a similar line off the tailplane, and where the two meet use a simple $2 protractor to measure the relative angles of incidence. Or you can just draw a datum line down the fuselage and measure the wing and tail incidences separately in comparison to that datum.
Old Aug 12, 2005, 08:49 AM
4 Scale is online now
Find More Posts by 4 Scale
Trampling out the vintage
Joined Feb 2002
I generally agree that for monoplanes an incidence meter is unnecessary. However, while not strictly necessary for biplanes, it helps a little more there in getting the top wing right. Almost all biplanes have different incidence in the upper and lower wings. Again however on a biplane careful building and attention to incidence makes an incidence meter an aid not a necessity.
4 Scale is online now Find More Posts by 4 Scale
Help! How do you use an incidence meter? rcwilbur The Builders Workshop 3 Aug 29, 2005 05:18 PM
Do you need an Aiptec SD? cainebean Aerial Photography 3 Oct 04, 2003 07:42 AM
how big of a slope do you need? breadboy Electric Sailplanes 8 Oct 04, 2001 12:06 PM
How do you choose an airfoil? DeaninMilwaukee Power Systems 9 Jul 05, 2001 02:26 AM
Do you need CA glue to build the sky scooter? e-flyer Parkflyers 6 Apr 30, 2001 07:42 PM
