Old Aug 11, 2005, 11:35 PM
Alexis_Ruiz is offline
Find More Posts by Alexis_Ruiz
Joined Mar 2004
Finally received my aero-naut TF4000!!!
After a 7 month wait and several thousand miles of travel (Germany- California- Caribbean-California-Ontario-kentucky- Caribbean!!!!! , It got all the way to my place and was returned to California by the USPS because of an undeliverable address, then re-sent through UPS's network)my TF 4000 for the Rafale finaly arrived, if it were on a frequent flyer program it would have accumulated enough miles to travel the world all over again!!!! Below are some pics;
BTW, I'm working on building a Turbine powered TGA interceptor, and though, Hummm!!! what about an EDF conversion?? what do you guys think?? possible? the plane is HUGE in size, it's the one on the last photo...
Alexis_Ruiz is offline Find More Posts by Alexis_Ruiz
Old Aug 12, 2005, 12:46 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
I have one of these and I think it would be do-able. Its a big fuse but very simple and light enough, not to mention a slippery design. Glad you got the fan too! I would get one in a heartbeat if I knew it would be here within a year or so! lol
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Aug 12, 2005, 02:03 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Alexis, you're a lucky man! Not only the trip itself, but these are backordered until way into 2006 @ the moment! Have fun with it!!
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Aug 13, 2005, 05:55 PM
Joined Mar 2004
Guys:
Just one major drawback! The instructions are in German and I do not understand a bit!!!, Can anyone who has this fan tell me what should be the location to glue the stator to the shroud?? What should be the distance from the front lip where the mounting ring should be glued? What glue should be used? Epoxy, JB weld, Thick CA??
Help Please!!!
Old Aug 13, 2005, 06:55 PM
Joined Aug 2002
CA is gonna work best. epoxy doesnt stick very well to epoxy. As for assembly I would say mock up the motor and rotor and push the fan far enough back on the shroud that the back of the stators are even with the back of the housing. I like this method best cause you can lay the tube and the stators on there back on a flat table to aid a straight fit. And on 609's I glue the ring just behind what would be the midle of the rotor. This is the place where you need crush support and will still allow you to slide the fan into a inlet tube far enough.
Barry
Old Nov 12, 2005, 09:30 PM
Joined Mar 2004
Progress
Finally after 3 months I was able to find some time to do some building on the Interceptor, foam cores are sheeted, formers and retracts are installed, still pending is cutting off the flying surfaces, glassing, installing the duct and finishing, then it's to the design of the TF 4000 installation. Here's how it's today;
Old Nov 12, 2005, 10:04 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
That looks great Alexis! Looks like it'll be a good flyer.
Chris True is offline Find More Posts by Chris True
Discussion Hey Hey!!! I finally got my Aero Ace Sport! tiguy99 Micro Ready-to-Fly 17 Aug 21, 2007 02:34 PM
Has anyone built an Aero-naut Canadair? pierluigi demontis Scale Kit/Scratch Built 11 Feb 11, 2005 07:52 PM
robbe, aero-naut, graupner folding prop combination oded mazor Electric Sailplanes 2 Sep 19, 2001 02:47 PM
Finally got my Jas-Cam running off one flight pack jas_Qfix Power Systems 7 Jul 23, 2001 07:25 PM
I finally flew my first heli, my Eco 8 Eco8gator Electric Heli Talk 4 Jun 25, 2001 10:54 PM
