Old Aug 11, 2005, 09:43 PM
Angry_Monk is offline
Find More Posts by Angry_Monk
Your ruler, in part...
Angry_Monk's Avatar
Albany, NY
Joined Mar 2005
Omni-directional antenna for bit-tx?
has anyone made a Omni-directional antenna for use on a bit-tx? i had the idea, because i think the increase in range would be great, but i have very little knowledge to go on if i were to build one. i just wanted to know if this has been done before as it would save me some time and frustration. thanks
Angry_Monk is offline Find More Posts by Angry_Monk
Old Aug 11, 2005, 10:07 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
holding the antenna upwards/vertical will give you an omni-directional transmission.
If you imagine the antenna is up the middle of a doughnut - that is the radiation pattern outputted. (the shape of the solid doughnut ) Hence - when you point the antenna at the model it is actually reducing the signal as at that angle there is very little output coming out of the top of the antenna.
NitroCharged is offline Find More Posts by NitroCharged
Old Aug 12, 2005, 09:38 AM
Angry_Monk's Avatar
Albany, NY
Joined Mar 2005
ok, i think i may have gotten my definitions wrong again, which means the web site i was reading had misinformation. what i mean to say is a directional antenna that would project the signal directly at the model. i'v seen it done for wi-fi and it was used to boost the singal to 1000+ft.
Old Aug 12, 2005, 03:38 PM
peter frostick is offline
Find More Posts by peter frostick
peter frostick's Avatar
south shields. England
Joined May 2004
"Furious Thelonius"
Nitro's info is correct --- IME the best way of increasing Tx radiated power is still the one in the bitcharger thread index by "Mr Rc cam" which involves a simple 9v conversion of the Tx output circuitry, and using a cheapo regulator to run the (5v) chip.
I must however admit that in practical flying terms the orientation of the antenna length never seems to make a scrap of difference once the aicraft is at altitude: at a guess this might be because the RF signal bounces around metal framed indoor spaces so much anyway?
Peter
peter frostick is offline Find More Posts by peter frostick
Old Aug 12, 2005, 04:05 PM
Angry_Monk's Avatar
Albany, NY
Joined Mar 2005
i'm just looking for a way to dramatically increase range, or at least get 150ft out of my tx. funny thing is that i did have that kind or range but all the sudden its more like 50ft. maybe its the cheap bit-electronics.
anyway, i was reading one of the bit-plane topics (86 pages long) and one of the last posts said something about this car http://shop4.outpost.com/product/385...H:MAIN_RSLT_PG having 400ft of range after the 9v mod and longer antenna. i was just wondering if this is true and if anyone has anymore info on this car.
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Directional Antenna for Cobra Walkie-Talkie uscra112 DIY Electronics 11 May 25, 2005 05:13 PM
Pirating a Big TX for Bit TX output Pete P. Scratchbuilt Indoor and Micro Models 2 Jan 18, 2005 09:52 PM
Question How Should You Hold TX Antenna for Best Range? RCSMITH Radios 9 May 26, 2004 10:52 AM
