Old Aug 11, 2005, 09:16 AM
Moore, Oklahoma
EDF 64mm fan Cox/Estes fan unit.
Hello all, I am agian searching for awnsers. I have a 64mm fan unit that I need to power and fly by monday. I am looking for the best low weight high power setup that can and will be used wtih a 850 mah 15c 3 cell Lithium. I am hoping that it will pull in the range of 10-14amps. Can anybody direct me to a good motor for this application. Agian I need max thrust output. thanks in advance. Take Care Chris
airmcn_3 is offline Find More Posts by airmcn_3
Old Aug 11, 2005, 09:53 AM
Moore, Oklahoma
Would this be a good choice?? Feigao 1308422S Brushless Motor 22 Turn, 2.0mm
Old Aug 11, 2005, 10:03 AM
scratchandbash's Avatar
Grove City PA basement/park
Joined Feb 2005
As far as the battery is concerned, you probably do not want to run it at that high a C value, even if the spec rates it. I haven't used that Feigo, so you may want to post specs, so guys here can compare it to motors they know of. Again, the Himax 2015-4100 seems to be a popular motor for setups that are to run 10A or less continuous. May want to compare your Feigo's specs to it.
scratchandbash is offline Find More Posts by scratchandbash
Old Aug 11, 2005, 10:06 AM
Moore, Oklahoma
Groovy!! thanks for the info. here are the specs. Take Care Chris
Rpm/Volt: 4255
Ohms: 0.0960
Max Current Limitation: 10A
Dimensions (diameter x length): 20 x 35 mm / 0.79 x 1.38 in.
Weight: 44.7g / 1.57 oz.
Feigao Thrust Data For Different Gear Ratios. Additional gear ratio information available.
1308422S at 6.63-1 ratio, 4255 Rpm/V, 0.960 Ohms, 10 Amps
Propeller Volts Amps Thrust/oz
9047 7.2 3.2 7.1
8.4 3.7 9.2
9.6 4.5 11.4
11.1 5.8 15.1
9070 7.2 4.4 8.6
8.4 5.2 10.4
9.6 6.2 13.7
11.1 8.5 16.9
1047 7.2 4.6 10.9
8.4 5.4 13.3
9.6 6.7 18
11.1 8.8 22.4
1080 7.2 5.7 11.6
8.4 6.9 14.3
9.6 8.7 18.4
11.1 10.8 22.7
1147 7.2 5.6 13.3
8.4 6.3 16
9.6 8.7 21.4
11.1 10.6 27.1
1180 7.2 7.1 14.1
8.4 8.5 17.2
9.6
11.1
1280 7.2 7.8 17.3
8.4
9.6
11.1
1365 7.2 8.8 18.9
8.4
9.6
11.1
EDF55 7.2 7.8 6.6
8.4 8.8 7.8
9.6
11.1
EDF64 7.2 7.9 8.1
8.4 9.3 9.7
9.6
11.1
EDF75 7.2 10.8 6.7
8.4
9.6
Old Aug 11, 2005, 10:16 AM
Moore, Oklahoma
The himax has too big of a diameter can. no good to me..... thanks agian for the info. Chris
Old Aug 11, 2005, 11:07 AM
igo
Joined Apr 2004
try razor. it fits inside the cox estes fan shroud.
igo is offline Find More Posts by igo
Old Aug 11, 2005, 01:11 PM
Moore, Oklahoma
thanks IGO. How about the Razor RZ-Heli?? that is the only motor I have found that they can ship and have to me by tomarrow.
The Razor Micro-Heli v.2 Brushless Motor is designed for the small helicopters such as the CP Hornet. Calculations show that its efficiency is 80% at 2.2A @ 11.1 V and 87% at 7.7A @11.1 V. Use 10 tooth pinion for CP Hornet Micro Helicopter.
Kv: 4300 rpm/v
Io: 0.45 A
Rm: 0.120 Ohm
Weight: 26.0 g (0.92 oz)
Length: 26.8 mm w/o shaft
Diameter: 19.5 mm
Output Shaft: 2.0 mm dia., 12.0 mm from faceplate
Bolt Pattern: 2.5 mm mounting holes on 1 16.0 mm bolt circle/ 2.0 mm mounting holes for the 19.0 mm Maxon Gearbox
Old Aug 11, 2005, 02:10 PM
Moore, Oklahoma
Thanks guys I ordered the Micro Heli motor. Later Chris
Discussion 37" long F-18E Superhornet EDF 64mm fan RCCastle.com Ed Waldrep Foamy EDFs 289 Feb 12, 2008 02:55 AM
What's the best way to balance a edf fan blade? Wattage fan... Sal C Electric Ducted Fan Jet Talk 10 Oct 08, 2005 10:59 AM
Whoops! Estes Air Force 1 Foamy Fan Unit Usage John_R_C Foamies (Kits) 0 Jan 23, 2005 02:15 PM
SuperFlea Twin EDF....Yea, it's got a Ducted FAN! DrDHalko Foamies (Kits) 69 Aug 19, 2004 05:09 PM
Cox Estes EDF modification gerico Electric Ducted Fan Jet Talk 0 Mar 16, 2002 04:49 PM
