Old Aug 09, 2005, 03:05 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Working MAV's (Micro Air Vehicles)
John (Fly...Please) has recently increased the interest in MAV's on the forum. He and I have talked about maybe starting some threads for MAV's. I'll start them and let John and others contribute the content. And, I'll clean up certain threads, like this one, which are intended to be resource threads.
I'll also be starting two other threads.
"MAV (Micro Air Vehicles) Resources and Links"
"MAV (Micro Air Vehicle) Discussion.
This thread is intended for people to post pictures and details of their [/b]SUCCESSFUL[/b] MAV's so others can peruse them and get ideas. It is similar to the "Working Pager Plane" thread in this respect.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Aug 18, 2005, 11:25 PM
FLY...Please is offline
Find More Posts by FLY...Please
FLY...Please's Avatar
Dayton, Ohio
Joined Jun 2005
My Newest MAV
I thought that I would share a MAV that I completed yesterday. Basically it is a 5.5" max dimension MAV just like most of my others. I have test-flown it with good results (about 1 min duration). I just need to get it trimmed out better in order to lengthen the durations. I should be able to get 15 minutes out of it fairly easy if I prop it less aggressively.
It is an extremely durable design. In fact, I just crashed the MAV in a full speed dive (probably 25-30 MPH) into a parking lot by accident. I saw something go flying off of the airframe. On closer inspection I found that it was only the prop!
Here are the specs:
Geometry:
Wingspan: 5.5"
Wing Area: 22.4"
Static Margin: 8.5%
C.G.: 1.18"
MAC: 3.6"
Airfoil: "0-thickness" defined by 3rd order polynomial.
Reflex: 3%
Planform: Zimmerman
V. Stab area: 22% Wing Area
Rudder area: 5.8% V. Stab area
Rudder AR: 1:1
Thrustline: 1" below airfoil centerline
Wingloading: Allot
Components
Airframe: CF and Kevlar
Servos: (2) Cirrus 4.4
Motor: Feigao 10.5g
Prop: U-80 cropped to 60mm
Receiver: Penta 5P W/10ft antenna
ESC: Phoenix-10
Camera: MicroCameras 3.3g
Tx: RF Links 25 mW 2.4 Ghz
Rx Antanna: 14 dBi gain Patch
Surveillance Range; ~700m
Primary Batteries: (2S) 250 mAh
Secondary (camera/Tx) batteries: (2) 90 mAh
Weight Breakdown
Airframe (including camera): 15g
Motor: 10.5g
Receiver: 2.0g
Servo: 6.7g
ESC: 3.0g
Battery: 12.6g
Prop Weight: 0.6g
Subtotal: 49.8g
Miscellaneous: 5g
Total: 54.8g
Attached are some pictures.
-John
FLY...Please is offline Find More Posts by FLY...Please
Old Aug 19, 2005, 01:25 AM
mharms is offline
Find More Posts by mharms
Realtired User
mharms's Avatar
San Jose, California
Very nice John!
The camera is in the "pod" at the bottom of the v-stab? Kind of a scary place, but I guess you would get "prop lines" in the video if its behind the prop. The rudder area seems so small, but it sounds like it works OK for you. Is the airfoil one that you derived yourself, or does it have a name or a more specific description? I've played with gliders using "sideways S" airfoils made from plastic sheet cut from plastic binders you can get at the stationery store) and had good results (Zimmerman and Inv Zimmerman planforms). However, they did not hold their shape well (not a problem with your CF, I assume).
Although it would probably be just be a little dot in the sky, I'd love to see a video of it flying once you get it trimmed. A video from the MAV POV would be neat too.
Glad to hear its durable. How do you (normally) land? Look for thick grass?
Mark
mharms is offline Find More Posts by mharms
Old Aug 19, 2005, 02:39 AM
Uttam1 is offline
Find More Posts by Uttam1
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Looks great! I'm pretty sure the wingspan isn't 29" though
-Happy landings,
Uttam
Uttam1 is offline Find More Posts by Uttam1
Old Aug 19, 2005, 04:07 AM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
Wow, what a craftmanship....
This is the first time I read of a DD use of the short Feigao, I'm very interested what propchoice will prove to be best,
Peter
Pjotrrr is offline Find More Posts by Pjotrrr
Micro Air Vehicles link bipeflyer Scratchbuilt Indoor and Micro Models 4 Oct 02, 2003 08:30 AM
Aerogel. MAV's and Micro RC structures? Mike Waters Scratchbuilt Indoor and Micro Models 0 Jul 07, 2003 06:10 AM
DARPA's Micro Air Vehicle has batteries for wings.... Steve McBride Batteries and Chargers 0 Dec 31, 2002 01:17 PM
