Old Aug 09, 2005, 11:54 AM
neuroblade is offline
Find More Posts by neuroblade
neuroblade's Avatar
Naples, FL
Joined Jul 2005
Gain setting up high for tail control?
Has anyone messed with their 4-in-1 gain trimmer pot on the HB2 or Blade? Does the gain setting as high as it goes keep the tail somewhat solid during flight (hovering strictly). As opposed to the setting low, making the tail twitch more quickly?
neuroblade is offline Find More Posts by neuroblade
Old Aug 09, 2005, 11:57 AM
VACaver is offline
Find More Posts by VACaver
VACaver's Avatar
Usually underground in Virginia
The Blade manual says to set it all the way up if you're only gonna do hovering. I did, and developed a tail twitch. I turned the gain back down a bit and it settled down.
VACaver is offline Find More Posts by VACaver
Old Aug 09, 2005, 12:06 PM
beemer is offline
Find More Posts by beemer
Seemed like a good idea!
beemer's Avatar
Bolton, Ontario, Canada
Joined Jun 2005
I've set my gain all the way up and had slight twitching issues.
Then I set it all the way down and quickly discovered that I shouldn't do that! (you'll have a real fight on your hands if you do that!)
Set it all the way up, then back it off about 1/4 turn. That seems like a good starting point when trimming mine.
Make sure to trim the heli in a steady hover out of ground effect. Get the proportional set FIRST so you aren't struggling with rudder all the time.
beemer is offline Find More Posts by beemer
Old Aug 09, 2005, 12:09 PM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
VACaver,
When you say a bit, are you talking about decreasing it about one hour (eg: from 10 to 9 o'clock)?
Old Aug 09, 2005, 12:11 PM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
Appreciate that beemer.
Old Aug 09, 2005, 01:11 PM
neuroblade's Avatar
Naples, FL
Joined Jul 2005
beemer,
So, my gain setting cannot be determined with the heli on the ground? Reason I ask, won't the heli still react to the setting with almost enough throttle to lift off (light on the skids)?
Old Aug 09, 2005, 02:05 PM
beemer is offline
beemer's Avatar
Joined Jun 2005
Yes and no. It will react, but the heli will have so much vibration caused from it sitting on the ground, turbulence from downwash etc. It really needs to be off it's feet and out of ground effect. Also, in rotor wash you'll have swirling air which can try and push the tail to the side. Once you're up about 3 or 4 feet you'll have relatively clean air to trim in.
You "can" adjust the proportional on the ground, but it will only be "close". Just as it get's light on it's feet you should be able to tell how much, and in what direction, you have to use rudder to keep things from turning. Adjust the proportional until you can almost lift off with no rudder inputs. THEN you can adjust the gain.
With the gain turned all the way down you better watch out, 'cause that tail will be whipping around like a loose fire-hose!
I agree with VACaver. I have my gain turned up pretty high. I like it that way because it keep the tail pretty tame. I tried flying it outside in a bit of a breeze with very bad results...with the gain turned up the heli is very slow to react ends up doing some spectacular weed-wacking!
setting up eco for 3D 3dben Electric Heli Talk 2 Jul 10, 2004 12:24 PM
Setting up full-span camber control on Sky Sergio w/Eclipse 7 radio jshelton Electric Sailplanes 16 Apr 20, 2004 07:32 PM
Question Need help setting up controls for Carbon Falcon kadet123 Parkflyers 2 Dec 30, 2003 06:21 PM
Setting up to DL for a newbie like me The Don Hand Launch 8 Feb 27, 2003 09:18 PM
setting up FMS for heli sen Electric Heli Talk 4 Jan 16, 2002 04:04 PM
