Old Aug 08, 2005, 05:58 AM
PunyV is offline
Find More Posts by PunyV
Vestby, Akershus, Norway
Joined Mar 2005
"the Flyer"
This is the first pictures of my build, "the Flyer", it's a scale modell of a 1930's 135 cu. in. hydroplane. This is my first real scale boat.
PunyV is offline Find More Posts by PunyV
Old Aug 08, 2005, 06:45 AM
arilsa is offline
Find More Posts by arilsa
Joined Aug 2005
How Big is it?
What Scale?
arilsa is offline Find More Posts by arilsa
Old Aug 08, 2005, 09:54 AM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Beautiful woodwork!!
From the leaves, it appears to be about 1 meter long.
Kmot is online now Find More Posts by Kmot
Old Aug 08, 2005, 10:10 AM
PunyV is offline
Joined Mar 2005
I got a bit carried away when I reprinted the plans from Here (thanks for the link ernest2) . So I'm makeing the boat in scale 1:3, and it's 1,57m, a bit bigger than I intended in the first place!
I found a picture in a post about the thunderbolt (here )This made me even more sure it was the right boat for me!
Old Aug 08, 2005, 11:19 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Fantastic job framing.
Where are you going to find a scale motor for that?
Ok, maybe a plastic motor cover that looks scale.
I love how little things can inspire great work.
Keep us updated here.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Aug 18, 2005, 03:47 AM
PunyV is offline
Joined Mar 2005
Progress! I am finished gluing the bottom of the boat. The material I used is like pine, but drier and not so heavy (I don't know the right word in english). Next is the sides, need to get some more 2" x 6" of the same timber as the bottom, and cut and plane it to planks. I'm going to get some mahogny to put on top of the boat.
The engine is going to be a petrol-engine from a grasscutter-thingy, 24ccm.
I need some advise, shuld i use a flex propshaft or solid steel propshaft? The original drawing show a straight shaft. I think I need to install the propshaft before I glue the side and top planks.
Old Aug 18, 2005, 09:41 AM
cop56 is offline
Find More Posts by cop56
Shawnee KS
Joined Sep 2004
Very nice! Thanks for sharing your progress.
Fred
cop56 is offline Find More Posts by cop56
Old Aug 18, 2005, 10:06 AM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I would install a "stuffing tube" in place. Then later, you can decide whether you want to use a flex cable or a solid shaft. Either will go inside the stuffing tube, so your propshaft angle will already be set when you build the stuffing tube into the hull.
http://www.finedesignrc.com/pipshovelsetup.asp
http://www.offshoreelectrics.com/how...ffing_tube.htm
Old Aug 19, 2005, 02:20 AM
ernest2 is offline
Find More Posts by ernest2
all my boats are broken
ernest2's Avatar
manila
Joined Aug 2004
wow!! that is absolutely beautiful!! and big. keep posting pics.
ernest2 is offline Find More Posts by ernest2
Old Aug 19, 2005, 10:04 PM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
The available plans at Svensen's makes it look as though the original was a tunnel hull. However there are many inconsistancies in the original drawings.
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Aug 19, 2005, 11:57 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
That front coaming looks just right for the centre of gravity and looks like it will mean installing your petrol engine quite far back.
martin richards is offline Find More Posts by martin richards
Old Aug 25, 2005, 02:32 AM
PunyV is offline
Joined Mar 2005
More work done!
Constructed the hatch door. I need to find some hinges I can use to open the hatch all the way!? Suggestions anyone?
Also the engine is on the workbench, ready to be cut in bits to fit into the enginehatch.
Old Aug 25, 2005, 10:07 AM
wingnut163 is offline
Find More Posts by wingnut163
wingnut163's Avatar
Newburgh New York
Joined May 2005
hinges, look at a doll house store. there hinges are quite nice.
its looking good
wingnut163 is offline Find More Posts by wingnut163
Old Aug 25, 2005, 10:18 AM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
There is a 15 1/2 miniature piano hinge for boat hatches that is consistently on ebay for $9.50. Here is a link to the current offering.
http://cgi.ebay.com/HATCH-HINGES-FOR...QQcmdZViewItem
Pete G
P_J_Glor is offline Find More Posts by P_J_Glor
Old Aug 25, 2005, 11:22 AM
Old 8140 is offline
Find More Posts by Old 8140
"Old 8140"
Old 8140's Avatar
Arizona Via NH
Joined Mar 2005
Have you thought of making the hatch one piece and useing magnet cabnet catches?
Jim
PS --- Beatiful job, looking foward to seeing it on the water!
Old 8140 is offline Find More Posts by Old 8140
