Old Aug 06, 2005, 04:24 PM
D-Man is offline
Find More Posts by D-Man
Joined May 2004
Alert
Brushless motor sounds strange, please help!
Hi!
I have just bought a Nippy 1210/103 brushless motor, with a Align 20A esc and a 3 cells, 700mah LiPoly battery pack. The prop I have on is a gws 10x4,7. The problem is that when I pull the throttle more than half the way, the motor starts to sounds strange. It's sounds like something rattles, or braking or something like that, and the motor loses it's effect. What is that!? Can somebody help me and tell me what to do!?
//Daniel
D-Man is offline Find More Posts by D-Man
Old Aug 06, 2005, 04:31 PM
shakysticks is offline
Find More Posts by shakysticks
clumsy thumbs
shakysticks's Avatar
Lincoln, NE
Joined Dec 2003
Is that ESC programmable? Maybe you need to advance/retard the timing.
shakysticks is offline Find More Posts by shakysticks
Old Aug 06, 2005, 04:55 PM
D-Man is offline
Joined May 2004
Yes, the ESC is programmable. You can set the timing in three steps. But I don't if I have set the timing right. The motor I have is a 12 pole outrunner, and in the ESC setup paper it says this;
1.Low timing - (apply to 2 pole inrunner motors)
2.Mid timing - (apply to 6 pole in/outrunner motors)
3.High timing - (apply to high power output)
Which one should I have? Right now I have the setup on step 3, High timing. And the motor sounds the way it does.
//Daniel
Old Aug 08, 2005, 01:06 PM
mike50 is offline
Find More Posts by mike50
mike50's Avatar
Rochester, MN
Joined Jul 2003
I had a motor that acted like that, it was due to a loose magnet. I glued the magnet back in place and no more rattle.
mike50 is offline Find More Posts by mike50
Question Brushless motor sounds strange...again D-Man Electric Plane Talk 0 Aug 07, 2005 07:42 AM
Alert Strange Noise coming from Main motor/main gear?!?!? Please Help!!! Minimole Micro Helis 26 Apr 09, 2005 05:01 PM
brushless motor/esc setup..please help.. rumme Power Systems 10 Jan 06, 2005 07:36 PM
Astro motor timing problems - (please help) harryo Power Systems 9 Feb 19, 2003 07:46 AM
FS F-16 Motor mount instalation?..please help Vincent Electric Ducted Fan Jet Talk 2 Nov 03, 2001 05:15 PM
