Old Apr 30, 2002, 04:06 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Are there ESC`s out there that can handle 4 servo`s?
will a 20 or 25 AMP esc do then trick? Maybe a pixie 20 or a 25 from castle creations (Yes i know a pixie is from them too)
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Apr 30, 2002, 04:32 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Some of the Shultze escs have a BEC stated as being capable of handling four servos, rather than the two or three of some other speed controllers. They have a neat little table which lists the typical current draw of some servo types and which of their ESCs are suitable for how many servos.
http://www.schulze-elektronik.com/index_uk.htm
I don't know who supplies Shultze in the USA, but in the UK you can get them from Gordon Tarling.
Hope this is of interest.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Apr 30, 2002, 07:46 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Hi kushal_2,
I believe you'll be ok with a Pixie 20. I ran one for a brief time with 4 HS-50s. Supposedly the smaller servos draw more amps than larger ones. They rate it at 1.25 A. I measured two HS-50s at 0.24 A for both. I had one each on the elevator and rudder and wiggled both sticks at the same time.
Basket case has flown the same setup longer than I have. I haven't heard him complain of problems.
From what I can see most ESC makers are VERY conservative in rating them for servos.
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Apr 30, 2002, 02:18 PM
Inferno is offline
Find More Posts by Inferno
Inferno's Avatar
Surrey B.C. Canada
Joined Apr 2002
Typically the servo will draw more under load such as wind load on the control surface.....I wonder what those servos draw under flight conditions ?
Inferno is offline Find More Posts by Inferno
Old Apr 30, 2002, 04:54 PM
Newark, DE USA
Joined May 2001
Surprisingly enough when I held the control surfaces firmly, almost to the point of stalling the current draw was the same. I measured them with a Mini Whatt meter. This was discussed some months ago and another person who measured his reported the same anomaly.
Old Apr 30, 2002, 08:22 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
http://www.mikrodesigns.com/
DNA is offline Find More Posts by DNA
Old May 01, 2002, 01:45 PM
sam2000pres is offline
Find More Posts by sam2000pres
Nevada City CA
Joined Nov 2001
GWS 400 ESC
Have been using a GWS 400 ESC with heat sink, 15-20 amp rating in a GWS Zero, 3 nano and 1 HS-81 on retracts, on 8 cell nicads, no problems. An optional heat sink is included with the ESC, all for $30.
Aeromicro has them.
http://www.aeromicro.com/Catalog/gws...r__1004698.htm
TK
sam2000pres is offline Find More Posts by sam2000pres
Old May 01, 2002, 03:15 PM
astroboy is offline
Find More Posts by astroboy
Superhero, Third Class
astroboy's Avatar
Carson City, NV
Joined Nov 2000
I believe all of the Kontronic Sun series have a 2amp BEC, and are rated for 4 servos on up to 10 cells.
Jeff
astroboy is offline Find More Posts by astroboy
Question any cheap 60+ amp /7s lipo ESC's out there? txfly Power Systems 2 Mar 22, 2007 09:52 PM
Question Are there Nicad chargers that can handle 50+ cells in series ? Protocooler Batteries and Chargers 4 Nov 09, 2005 08:54 PM
you power system /esc pro's out there fig8 Parkflyers 3 Oct 03, 2002 09:11 PM
any micro heli esc's out there with governor? petn7 Electric Heli Talk 0 Jun 24, 2002 08:52 PM
Are there any A-6's out there? Sal C Electric Ducted Fan Jet Talk 1 Nov 09, 2001 09:06 PM
