Old Apr 30, 2002, 02:45 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Has anyone ever heard of a HS-80 servo?
I have 2 of them and they look exactly like a HS-81 in fact thats what i thought they were until i saw the writing where a HS-81 says HS-81 these say HS-80. I have never seen these up until now or ever heard of them. Anyone Know anything about them?
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Apr 30, 2002, 02:55 AM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
The HS-81 replaced the HS-80. Not major change, no worries.
Comatose is offline Find More Posts by Comatose
Old Apr 30, 2002, 02:56 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Taken from:
http://www.srbatteries.com/radservo.htm
Compliments of google.com search engine.
Hitec HS-80
The HS-80 has been replaced by the HS-81, but we still have a small number in stock. We've used the HS-80 for years as our standard servo for most soaring and electric flight applications and it has been flawless. Frankly, we don't know why Hitec replaced it. The HS-80 measures about 1.1" x .5" x 1.1" and weighs only .62oz. At 4.8V its power output is 31 inch/ounces of torque with a speed of .15 seconds for 60 degrees of rotation. It is available with your choice of JR/Hitec, Futaba J, and both old and new Airtronics connectors.
Hitec HS-80, Specify connector type. While supplies last.
$19.95
Hitec HS-81
The HS-81 is the replacement for the HS-80. It's specifications are very similar and it's only slightly more expensive. We recommend it for any application where you need a little more power and can live with a little more size and weight compared to the HS-55 or HS-60. The HS-81  measures about 1.2" x .5" x 1.27" and weighs only .6oz. At 4.8V its power output is 38 inch/ounces of torque with a speed of .10 seconds for 60 degrees of rotation. It is available with your choice of JR/Hitec, Futaba J, and both old and new Airtronics connectors.
Hitec HS-81, Specify connector type
$22.95
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Apr 30, 2002, 03:09 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Thanks for the reply. This is what i thought had happend. The HS-80`s i have are great except that i have stripped the gears. I gather they take the same gears as the 81`s?
Old Apr 30, 2002, 09:19 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Yup.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Apr 30, 2002, 09:33 AM
Grasshopper is offline
Find More Posts by Grasshopper
Anaheim, Ca USA
Joined Sep 2000
No, I have HS-80 and stripped the gears. I thought that the HS-80 using same gear replacement part but a guy at Hobbypeople said to use different one, HS- 101 gear replacement part something like that. That worked. So when you buy one ask them and get right one.
GH
Grasshopper is offline Find More Posts by Grasshopper
Old Apr 30, 2002, 11:51 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
HS80 and HS101 use the same gearset, the HS81 use a different set and is therefore not interchangeable with the HS80/101.
Haldor is offline Find More Posts by Haldor
Old Apr 30, 2002, 11:53 AM
carterfx is offline
Find More Posts by carterfx
carterfx's Avatar
SF Bay Area
Joined Jan 2002
I have some of these servos too, as well as the HS-101's. The best place I've found to get new sets is Servo City FREE Priority Shipping and they're only $3.15 each set.
The direct link to the parts page is: http://www.servocity.com/Products/Se..._gearsets.html
- Jake
carterfx is offline Find More Posts by carterfx
Old Apr 30, 2002, 12:29 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Thanks for letting me know Guy`s
Has anyone ever heard of this kit? 525cj Fuel Plane Talk 2 May 14, 2008 09:55 PM
Anyone ever heard of a motor manufacturer named Air Supply, Inc.?y RobZ Power Systems 17 Dec 24, 2002 07:49 AM
has anyone ever had or seen a convert ex thriller Micro Helis 6 Sep 07, 2002 08:53 AM
Has Anyone Ever Built One of These? Acer Electric Sailplanes 4 Dec 02, 2001 04:38 AM
Has anyone ever owned a Worlds Model Corsair? campbell Scale Kit/Scratch Built 0 Apr 23, 2001 11:33 PM
