Old Jan 03, 2006, 12:51 AM
troyboy162 is offline
Find More Posts by troyboy162
Joined Dec 2005
Originally Posted by rotortiller
You can use EPP foam.
It is very crash resistant. It is what the wings and fuse of the AeroAce is made from.
You can get it in sheets from slofly:
http://slofly.com/cart/index.php?cPa...22673ab2b43ad8
the stuff some of these guys are using isnt depron sheets right? it looks like it comes from a solid block. like this one
http://www.rcgroups.com/forums/showthread.php?t=459904
edit:
got my own answer. yup this guy uses depron and heat molds it or something. not quite clear from his web page
im going to try and wrestle up some meat trays tommrow though and see what can happen
troyboy162 is offline Find More Posts by troyboy162
Old Jan 03, 2006, 01:31 PM
wrapperworm is offline
Find More Posts by wrapperworm
Joined Dec 2005
LED mod
hiya,
im kinda stuck on the led mod, i aint sure shud i attach them to the motors or put on a serparate power supply? any1 got any ideas??
thanks
wrapperworm is offline Find More Posts by wrapperworm
Old Jan 03, 2006, 01:55 PM
Joined Dec 2005
other mods:
add LEDs in parallel with motors - night flying:
post #134-148 http://www.rcgroups.com/forums/showt...&page=10&pp=15
post #432 http://www.rcgroups.com/forums/showt...&page=29&pp=15
post #582 http://www.rcgroups.com/forums/showt...39#post4492173
the easy one seems to just have the led in parellel with the motors. seems like a lot of voltage on the led but there cheap
Old Jan 03, 2006, 02:38 PM
Joined Dec 2005
thanks alot troy,
i'm lucky i'm still in school so i get LEDs and electronic parts for free!! YAY and i'm gd at that kinda thing, cheers again.
Old Jan 03, 2006, 02:46 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Just a new one in the rows...
Harpye is offline Find More Posts by Harpye
Old Jan 03, 2006, 04:04 PM
StephanB is offline
Find More Posts by StephanB
Restricted User
StephanB's Avatar
Frankfurt-region, Germany
Joined Mar 2003
Hansjoerg,
that's beautifull.
And it's not fair; some guys have all the skills
Good luck for the maiden.
Stephan
StephanB is offline Find More Posts by StephanB
Old Jan 03, 2006, 04:20 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I have read of some guys cutting the bottom wing off at the strut outwards.. Is anyone finding this to help? Seems like a nice simple mod..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 03, 2006, 08:42 PM
Dastrooper is offline
Find More Posts by Dastrooper
Dastrooper's Avatar
Joined Oct 2005
Tram: alot of people remove the entire bottom wing it seems to climb and fly faster. The wings are just glued on so you can pull them off and stick them back on as you like.
Dastrooper is offline Find More Posts by Dastrooper
Old Jan 04, 2006, 03:44 AM
hklam is offline
Find More Posts by hklam
hklam's Avatar
Joined Jul 2005
Here's my latest creation conjured up last evening for my x-twin electronics:
X-twin powered pusher "Fighter Jet"
Material: 3mm Foam (Foam Plates)
14" wing span with built-in Dihedrals and curved aerofoil
Weight without electronics is a hefty 12.5g!
Maybe a bit too hefty but I shall fit the electronics today and hope for a maiden as well. I have built in an extra large wing chord with dihedrals and large stabilizers to achieve slow and controllable flight for the simple pusher system. Imagine a reasonably slowflying jet plane.
Let's just hope everything goes well.
hklam
hklam is offline Find More Posts by hklam
Old Jan 04, 2006, 11:31 AM
Joined Dec 2005
broken xtwin
damm damm its not fair !!! some string got caught round my motor so i try and take it off but in stead i pulled of my motor and ripped the wires!!! so no more xtwin plane!
does any one no where i can get a new motor and lipo ???
and wot voltage lipo i can use at max??
thanks
Old Jan 04, 2006, 02:14 PM
Joined Dec 2005
welp i picked up a broken christmas return one today. i figured it was busted but thought id have a try at fixing it. the rx is completely toast. it was broken before but now i let some of the smoke out of it while trying to fix it. the motors work fine and the tx seems fine(no way to really test it). im gonna return it tomorrow unless someone it desperate for parts.
its a red biplane channel b
Old Jan 04, 2006, 02:58 PM
Harpye is offline
Harpye's Avatar
Germany
thanks
As me - but you can fix it! Carefully scratch off some of the plastic material around the contact with a welder and then weld the cords ( in the right position ) to the tiny sheets of metal coming out out of the plastic!!!
Old Jan 04, 2006, 05:00 PM
ronmar1 is offline
Find More Posts by ronmar1
FREEDOM IS NOT FREE!!
ronmar1's Avatar
Knoxville Tyson, Tennesse, United States
Joined Feb 2004
Anyone found a way to charge the Lipo in the AA with conventional Lipo charger? I took the plug form the tranmitter and tried it with my KC-100 Lithium Charger from DWE and it wouldnot charge.
Ron
ronmar1 is offline Find More Posts by ronmar1
Old Jan 04, 2006, 05:51 PM
Vifo is offline
Find More Posts by Vifo
Singapore
Joined Jan 2005
Moded Charging connector
Hi,
I have been very frustrated with the direct charging of the Tx, as it is loose and do not charged fully, so decided to cut out and fitted with connectors to be charged by independant lithium charger. I set to minimum 1 cell at 110mah and it works. I get a reading of 4.3volt on full charge for the lithium,
Here is the pic
Vifo is offline Find More Posts by Vifo
Old Jan 04, 2006, 05:57 PM
ronmar1 is offline
ronmar1's Avatar
Joined Feb 2004
Thanks for the input. So you're going directly to the connectors on the battery?
I didn't want to cut onto the plane yet, if possible. My charger shows charged when trying to charge through the built in charge connector, even though the battery is discharged.
Ron
Discussion X-Twin, Aeroace - post your mods - part 3 osmium_192 Micro Ready-to-Fly 4345 Dec 22, 2014 09:41 AM
Discussion Homebuilt X-Twin/AeroAce Powered Micro Jets hklam Micro Ready-to-Fly 1867 Dec 06, 2010 02:07 PM
Post Your X-Twin Aeroace pics & vids here Darkdevil_725 Scratchbuilt Indoor and Micro Models 2 Nov 16, 2009 07:45 AM
Discussion X-Twin, Aeroace - post your mods - part 2 micro_builder Micro Ready-to-Fly 2344 Dec 05, 2006 12:19 PM
Alert About To Buy A X-Twin/AeroAce, Anything I Need To Be Aware Of? Minimole Scratchbuilt Indoor and Micro Models 9 Dec 21, 2005 02:33 AM
