Aug 05, 2005, 10:11 AM
Cliffside Park, NJ
Joined May 2003
Trex doesn't maintain steady altitude at hover
Hey guys...been having this weird problem with my Trex. All linkages seem to be setup right, main blade pitch and paddles are all setup, etc..but for some reason while I hover the heli wants to either quickly drift up or drift down at any moments notice.... I can never maintain a steady altitude for a good amount of time. At first I thought maybe my governor was not operating correctly, was using a CC35 and just recently swapped it out for a jazz but still experiencing the same issue. At hover my blades are tracking perfectly. My last flight i noticed that two of my ccpm servos were not tightly mounted on my CCPM frame (heliworkz). They had a lot of play...so I'm going to make sure these are all tightened up for the next flight. But what about anything else? The only other thing i can think of is that maybe my pitch servos are glitching a bit...causing this sudden change in altitude with no input. Any other thoughts or suggestions on things I should look at?
I'm running an Align 400LF with Jazz 40/16/8 ESC, TP2100 , HS-55's, 13T pinion,
Thanks for any help or input on this...
