Old Aug 26, 2005, 03:50 PM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
i took my charger to work the other day and hooked it up to a power supply (it is a pretty nice one). with this power supply you can dial in volts and amps. it told me that my charger is only drawing .88 amps while charging a 2S 1350 mah lipo. as the battery charges the amps drop. i can almost guess when the battery is charged.
with this ifo, i'll only need to buy a power supply that draws 13 amps.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Aug 27, 2005, 03:23 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
i'm covering the SQuiRT with solorfilm and i'm noticing that it takes A LOT of heat to get this stuff to work. the instructions say to use 100 C to tac and 150 C to shrink. i've got my iron set at 200 Degrees (i checked it with a thermometer), and it is working good. i don't want to melt it, but how hot can i go?
as a silkspan and tissue user, i am unfamilure with this kind of covering.
has anyone else ran into this or is this just normal behavior for polyester covering.
Old Aug 27, 2005, 03:55 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Wish I could help, I just bought a roll of Ultracoat today at Hobbytown USA in Mentor, they have doubled in size and now have a full rack of Ultracote! Yippeee. I will never use monokote again, It needs LOTS of heat. If the solarfilm film is not melting then I think you will be OK. Are you sure the 200 you measured was in Celsius? 100C is 212 F which may be why it is attaching OK.
Don
The Don is offline Find More Posts by The Don
Old Aug 27, 2005, 04:22 PM
beanoman is offline
Find More Posts by beanoman
beanoman's Avatar
Akron/Canton, Ohio, United States
Joined Aug 2004
maybe use a test piece to see how hot it can go? just throwin out suggestions..
heres another 'bit plane'. i should stop being cheap and get some real equiptment at some time . non proportional throtle and rudder do make for relaxing/easy fight though. not really on the workbench any more, but it dosnt deserve its own thread
anyways, this one is still a bit on the ugly side of things, but not a total ugly mug like the other one. i did manage to get my hands on some nice epp-ish packaging foam- about a 1 inch thick block, 12 by 8 or something, so i carved out the fuse from that. it uses the same equiptment as the other one, except it uses yer standard old magnetic actuator for the rudder. auw is just a touch over an ounce.
beano
beanoman is offline Find More Posts by beanoman
Old Aug 27, 2005, 04:32 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
Originally Posted by dslusarc
... If the solarfilm film is not melting then I think you will be OK. Are you sure the 200 you measured was in Celsius? 100C is 212 F which may be why it is attaching OK.
Don
MELTING!!! no not yet.
one of the reasons for the temp question is, when i used coverlite, i could crank my iron all the way to 350 degrees and it didn't melt the covering. it did make it easier to shrink and push around.
also, is it better to use the iron for shrinking or hot air gun?
here's what i use for temp reading.
Old Aug 27, 2005, 04:45 PM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
When I use nelsons lite film or solite I just use the iron, no heat gun and it shrinks just fine.
Jim
BrunswickOH is offline Find More Posts by BrunswickOH
Old Aug 27, 2005, 09:39 PM
PerfectStranger is offline
Find More Posts by PerfectStranger
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
I put a new round in the chamber for this weekend....
matt
PerfectStranger is offline Find More Posts by PerfectStranger
Old Aug 27, 2005, 09:47 PM
NanoSio2 is offline
Find More Posts by NanoSio2
Remember the 131st TFW MO ANG
NanoSio2's Avatar
USA, MN, Apple Valley
Joined May 2005
Dang Matt that thing is sweet! I look forward to seeing it tomorrow.
NanoSio2 is offline Find More Posts by NanoSio2
Old Aug 27, 2005, 09:54 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
ha ha! i got first see tonight!
the P51 flew spectacular. looks really sweet buzzing at low altitude.
matt's got one cool plane!
i would post pics but it would do no justice. i guess you all will have to wait until sun. morning.
Old Aug 28, 2005, 02:30 PM
OhioPete is offline
Find More Posts by OhioPete
Lazy dog
OhioPete's Avatar
Lakewood, Ohio
Joined May 2005
That 'Stang was a beautiful flyer!
Thanks to Don I now have another kit to start working on, a GWS "Zero".
OhioPete is offline Find More Posts by OhioPete
Old Aug 28, 2005, 06:00 PM
one game away...
Willoughby, Ohio
Joined Apr 2004
Well, we'll be able to chase each other around when you get her done. Toss in Don's Spitfire or P-51 and it will be a party.
matt
Old Aug 28, 2005, 06:16 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Matt which AXI was in yours 2208?
The spitfire is on its way. I am digging my way to the mustang now.
Don
Old Aug 28, 2005, 06:53 PM
one game away...
Willoughby, Ohio
Joined Apr 2004
i used an axi 2212/20, 8*6 apc E prop, 3s 1500, phx25, berg4 rx. roughly 16 amps. i haven't graphed it with the 8*6 E prop yet but the 8*6 sloflyer prop was around 15 amps.
matt
Old Aug 28, 2005, 08:15 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
what's on my workbench???
the littlest stick!!
maiden it tonight and VROOM....SPLAT (X3)!!
first attempt the prop flew off before it left my hand. second and third attemps it took every bit of full throttle and up elev. to just keep it in the air for thirty feet. this thing is a brick. i even cut off the landing gear. after third attemp, it hit a little hard on the bottom of the nose and ripped the firewall off. a prop saver would have been very helpful in this situation.
oh, well. could have been a lot worse.
i am pleased it did fly...sorta. it defenently needs more power. i might toss in the CDrom motor just to see what it'll do. (anyone have a brushless ESC they want to get rid of?)
i do have one question though. i'm using a 6 x 5 prop on a 180 geared 2.9:1 and i'm wondering if i should try another size prop?
Old Aug 29, 2005, 07:57 PM
Tommy632 is offline
Find More Posts by Tommy632
Mayor of Simpleton
Tommy632's Avatar
Cleveland, OH, USA
Joined Oct 2002
Getting there............
Got a little more done. I thought this was only suppose to take 3 hours??? Me.... Only 3 weeks so far.
Tommy632 is offline Find More Posts by Tommy632
What's on your workbench? Mars Flyer Alabama's Rocket City Renegades 2620 Aug 10, 2015 07:12 AM
Discussion What's on your workbench? himszy Submarines 21 Jan 01, 2006 12:25 PM
what controls do what on your Tx. I think mine are wrong. Fragster2001 Micro Helis 7 Jul 01, 2004 06:31 AM
Yippee! What is on your building table? Arrow Parkflyers 45 Nov 22, 2003 01:37 AM
What's the rpm on your x-250? temacc Electric Plane Talk 5 Jun 11, 2001 10:24 AM
