Old Aug 04, 2005, 10:24 PM
QuazBotch is offline
Find More Posts by QuazBotch
User Person
Toronto-Ish, Ontario, Canada
Joined Jun 2005
Does this sound right? Beeping ESC, rumbling motor
This is my first electric plane.
E-Flite Park 400 Outrunner motor (Similar specs to Axi 2212/34)
Castle Creations Pheonix 25 ESC
Thunder Power 3 cell 1320maH battery
10x4.7 prop, don't remember what brand
The ESC beeps 3 times when I plug the battery in. I make sure the throttle stick and trim are at their lowest setting. I thought it was supposed to beep once.
The motor has a deep rumbly sound, it reminds me of my glow engines. I thought it would be smoother sounding, just the wwhhhhhrrrrrrrrr without the other noise. In the attached video I run the motor at idle, and then half throttle, then shut it off. I'm pretty sure the prop is balanced.
If more videos or photos will help, let me know.
QuazBotch is offline Find More Posts by QuazBotch
Old Aug 04, 2005, 11:51 PM
Jimbo45cn is offline
Find More Posts by Jimbo45cn
Jimbo45cn's Avatar
Southwest Florida
Joined Mar 2004
The speed control sounds exactly right, that's the sound it makes when all is working properly and the motor arms.
the motor does sound kind of funky, should'nt be that noisy, but really need to hear it wot to tell for sure. Jim
Jimbo45cn is offline Find More Posts by Jimbo45cn
Old Aug 05, 2005, 11:21 AM
User Person
Joined Jun 2005
I found a better microphone. The rumbling seems to get drowned out at WOT.
This video is audio only. Idle, half throttle, full throttle, half throttle, idle, off.
Old Aug 05, 2005, 11:36 AM
jgorski is offline
Find More Posts by jgorski
jgorski's Avatar
Hopkinton, MA
Joined Mar 2004
The speed control is probably set to auto count the lipo cells. It should give the start beep and then the number of beeps equal to the number of lipo cells. Mine beeps four times.
Joe
jgorski is offline Find More Posts by jgorski
Old Aug 05, 2005, 11:52 AM
th535is is offline
Find More Posts by th535is
Birmingham, AL
Joined Dec 2004
My rimfire brushless made that same sound and it turned out that one of the motor mount screws had come out and was allowing the motor to vibrate. Check the screws that attach the motor to the motor mount.
-Ty
th535is is offline Find More Posts by th535is
Old Aug 05, 2005, 12:59 PM
User Person
Joined Jun 2005
Thanks Jimbo45cn and jgorski for the speed control info.
Thanks for the idea th535is. The motor was mounted to the firewall tight. I took it off the plane and ran the motor, holding it by the x mount in my hand. It sounded great, at half throttle all I could really hear was air wooshing by.
I suspect the motor noise is being amplified by the plywood firewall and the balsa behind it. I'm going to look for some o-rings or fat rubber bands to put between the x screws and firewall.
Old Aug 05, 2005, 01:03 PM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
Thanks for the idea th535is. The motor was mounted to the firewall tight. I took it off the plane and ran the motor, holding it by the plastic-x mount in my hand. It sounded great, at half throttle all I could really hear was air wooshing by.
I suspect the motor noise is being amplified by the plywood firewall and the balsa behind it. I'm going to look for some o-rings or fat rubber bands to put between the plastic x screws and firewall.
yep that is what it sounds like to me, resonation of a normal motor sound to the airframe or wings. Make sure it doesnt heat up under no load (if it does, indicates some friction of rubbing). If it doesnt, go fly!!
ImaBiggles is offline Find More Posts by ImaBiggles
Does this sound right to you? louisd Batteries and Chargers 1 Mar 25, 2005 02:55 PM
Question does this sound right? stirlingnut Power Systems 0 Mar 12, 2005 12:50 PM
Does this sound right? irate 850 iflych52 Batteries and Chargers 3 Mar 19, 2004 02:27 AM
GWS Spitfire - does this sound right? mattski Parkflyers 10 Sep 07, 2003 07:17 PM
Does This Sound Right? Scomis Parkflyers 4 Mar 01, 2002 10:46 AM
