Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old Apr 29, 2002, 08:23 PM   #1
Crazy Max 3D
I've noticed a lot of you fellas have the Crazy Max. I want to learn some 3D manuvers and thought this would be a good plane to learn on. It's cheap! Is this plane capable of some harriers and parachutes? If not, what is a relatively cheap plane that I can learn with?
Parkflyer is offline Find More Posts by Parkflyer   Reply With Quote
Old Apr 29, 2002, 08:45 PM   #2
an earth bound misfit, I
Silver Member
Basketcase's Avatar
I'm using the CrazyMax as an aileron trainer and aerobatic trainer. Not really sure what a harrier or parachute is so not sure if it is capable. It'll take everything I can throw at it.
Here's a couple of new foamies, that might be even closer to what you're looking for. I already have a CrazyMax and a SwitchBack Sport and am planning to buy one of the Katana's as the next step after the CM. The CM is for training and practice and the SB for flying. I crash the CM all the time from going too far and trying things I wouldn't dream of risking the SB with.
http://www.verticalrc.com/
Talked to Tim at Vertical today and he told me they would have online ordering up and running today or tomorrow.
http://www.rcgroups.com/forums/show...hlight=vertical
BC
Basketcase is offline Find More Posts by Basketcase   Reply With Quote
Old Apr 30, 2002, 08:20 PM   #3
Hobby Hopper
johnhlong's Avatar
Send a message via Yahoo to johnhlong
CM as a trainer ?
I've just been sitting back reading all the threads trying to decide which plane to get.
The TM seems to simple. I have a couple of 2ch gliders now.
I have a helicopter that I can hover.
Now I would like to get something that is a slowflyer but would be a good 4ch trainer.
Basketcase, you seem to make a good case for the CM as a trainer.
If that is the case, what else do I need to set it up correctly?
John
johnhlong is offline Find More Posts by johnhlong   Reply With Quote
Old Apr 30, 2002, 10:50 PM   #4
Silver Member
Basketcase's Avatar
Hi John, I don't know if I'd call the CrazyMax a slowflyer or a trainer. It's really more of a parkflyer, especially when training. I need about a soccer field to fly it.
After the 'moth I got a HL Stearman and added ailerons. After flying it a couple of times and finding out how fragile it was. I decided I needed something more 'crashable' to learn with.
The CM was a BIG step up. But I wanted to try aerobatics and it looked like the best choice. Plus it's very durable.
It depends what kind of flying you want to do and if you plan to crash it a lot.
A Switchback Sport would be a lot better aileron trainer, and you can get a 3D wing for it when your ready. But I'd only recommend it if your flying style does not include frequent crashing.
My Switchback flies nicer than the CM but I'd be heartbroken if I crashed it so try not to do anything too risky with it. With the CM I'll try anything.
As far as setting it up, you'd need a 15 amp speed control, 4 channel rx and 3 or 4 sub-micro servos. There's not much battery room. About the largest that will fit is 8 cells 5/4AAA or 8 cells 2/3A. I've tried both and prefer the recommended 5/4's. AAA's would work too but have slightly less duration.
The good part is all the gear will also fit in a Switchback.
Hope this isn't too rambling.
BC
Old May 01, 2002, 01:09 AM   #5
Hobby Hopper
johnhlong's Avatar
What me crash?
I don't think anybody plans to crash their airplane but I am ould enough to accept reality
This will be my first 4ch.
I want to try the basics. I have the FMS simulator and can practice on it also.
If I understand you, the switchback is a better trainer but not much joy if you crash it.
The CM is not as forgiving but is easy to repair.
I don't plan on crashing but reality is I will a bit as I learn 4ch.
I think the idea of getting the plane back in the air quickly looks like the better choice.
Have I missed something????
John
Old May 01, 2002, 08:50 AM   #6
Silver Member
Basketcase's Avatar
Hi John, I think you got it.
It's worked very well for me, and I think with your experience and outlook you shouldn't have any problems either.
Some Probond will fix almost anything that breaks on the CM. The front of the fuse and the firewall have taken some serious crashes and usually it's ready to go again as soon as the glue dries.
Best of luck,
BC
Old May 01, 2002, 10:08 AM   #7
Mountain Models Wannabe
CoClimber's Avatar
I'd like to add that I've seen a few Switchbacks dorked in without damage. I've been known to be on the sticks some of the time.
I've also rammed a Switchback 3D into the ground at full power in high wind that resulted in my son building me a new fuselage. It probably could have been fixed but my son wanted to try building one.
Doug
CoClimber is offline Find More Posts by CoClimber   Reply With Quote
Old May 01, 2002, 11:40 AM   #8
Silver Member
Basketcase's Avatar
Hi Doug, I dodn't mean to imply that the Switchback was a fragile plane. It's just that I like it so much that I try not to do anything too insane with it. Although I've had a couple of close calls, so far I haven't done any damage to it.
The CrazyMax, on the other hand, has been subjected to some flying and some crashing that you wouldn't want to see done to a Switchback. It would be like entering a nice brand new sports car in a demo derby. It just wouldn't be 'right'.
I guess what I'm trying to say is, for normal flying where crashing is only a possiblity the SB is perfect. For learning/practicing extreme flying where crashing is almost guaranteed the CM makes a far better sacrificial victim.
But I think my landings are finally shaping up enough to make some retracts feasible. The only dilemma is which wing to mount them in. I want to get a 3D wing but should I put retracts in it or in the sport wing? My thought is to put retracts in the sport wing and use fixed with the 3D to save weight for better aerobatics.
I'm ready whenever the retracts are.
BC
Old May 01, 2002, 12:07 PM   #9
CoClimber's Avatar
BC, go ahead and crash. I've got more kits on the shelf. I'M KIDDING!!!
I will be mounting my new retract design into a sport wing shortly and will let you know how it works.
I like the idea of putting the retracts in the sport wing vs the 3D wing for the same reason you have - save weight in the higher performance wing. When I'm satisfied with my retract design, I will kit it first for the Sport wing.
Doug
Old May 01, 2002, 02:44 PM   #10
Hobby Hopper
johnhlong's Avatar
Switchback
Doug,
I'll be buying a switchback latter (both wings).
First I need something that will give me more time in the air in the begining untill I feel I can fly 4ch as good as I can fly my gliders.
Then the switchbacks for sure.
John
Old May 01, 2002, 03:38 PM   #11
We got planes to build
Silver Member
dmiller's Avatar
I have been flying my Crazy Max for a month or so, and this being my first 4 ch I find it to be quite a handfull. I have about 20 flights on it now, and while I have not crashed it yet, I am still nervous everytime I fly it. I would like to get a Switchback, but I agree with Basketcase- It just seems like to nice a plane to crash. Maybe in a couple more months.
dmiller is offline Find More Posts by dmiller   Reply With Quote
Old May 01, 2002, 04:48 PM   #12
Send a message via AIM to Greg Covey
The Crazy Max is a good plane to learn both basic and advanced aerobatics on. It is inexpensive and easy to repair.
For the "harriers and parachutes" mentioned by Parkflyer in the original post you'll need another power system.
I would have fun with it initially in stock form since it does come with the geared Speed 370 motor and then determine what power system you want to upgrade to.
Mine is still stock and I feel it is a great flyer with good power and duration! If you remove the stock wing incidence and beef up the plastic wing mount with a piece of balsa, you can do some amazing aerobatics with it even on only 3 servos. The 4 servo option would allow for even more advanced maneuvers.
My review should be out shortly.
Regards all.
Greg Covey is offline Find More Posts by Greg Covey   Reply With Quote
Old May 01, 2002, 07:56 PM   #13
Greg,
Thanks for the response. I'm certainly no expert but I can do most aerobatic manuvers, inside-outside loops, inverted flight, immelman (sp) split-S but after seeing a video of a parachute and harriers I thought it was the coolest thing.
What type of power system would I need? Would a 480 do it or do I need to go to a brushless motor. I guess you need about 14 oz of thrust huh?
Look forward to your review
Parkflyer
Old May 01, 2002, 08:07 PM   #14
Greg,
Parkflyer
Old May 01, 2002, 09:05 PM   #15
Silver Member
Basketcase's Avatar
Parkflyer, I recently tried installing a S400 in my CM. It did not work out for me and I currently have a GWS EPS 300-C mounted on it. Going to try a lower gear ratio and bigger props.
The main problem with a bigger motor is delivering the amps. The CM can fit about 8 600AE's or 800mah NiMH's maximum, but is happier with smaller packs.
The extra weight of the motor and batteries seems to just about cancel out the extra thrust.
My testing was skewed by not having (or being willing to buy some new packs for the test) the appropriate nicad packs. And a limited selection of props. My 2/3A 800mah Nimh's are not up to it.
On the other hand, whatever batteries you can't fit on the inside could probably be strapped to the outside.
Here's the thread about my experiment:
http://www.rcgroups.com/forums/showt...threadid=38469
Please keep us informed if you try it.
BC
btw: the www.verticalrc.com site has online ordering working. I just ordered a Katana! Probably will retire the CM for the flight gear. Check out their movies!
Question Who flies the Crazy Max 3D? witstick Parkflyers 3 Feb 07, 2002 05:03 PM
Wattage Crazy Max 3D PunkerTFC Electric Plane Talk 20 Jan 29, 2002 06:44 PM
Crazy Max 3D is a winner! Andreas Parkflyers 9 Jan 02, 2002 09:55 PM
WattAge Crazy Max 3D Gene Bond Parkflyers 31 Dec 18, 2001 12:57 PM
Crazy Max 3D ROCKS!!! ls77 Parkflyers 4 Dec 13, 2001 01:27 AM
Bored? Want to fight?
Join the RCGroups clan!
