Old Aug 04, 2005, 08:29 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
massive wire versus multistranded wire
David Theunissen did some calculations:
http://www.flyelectric.ukgateway.net/winding.htm
Colin Dedman's analysis:
http://groups.yahoo.com/group/lrk-to...x/message/8764
Peter Rother:
http://www.torcman.de/peterslrk/Skin-Effekt.html
Vriendelijke groeten Ron van Sommeren
diy motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, August 28th, Nijmegen, the Netherlands
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 04, 2005, 10:24 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Its been used in higher performance RC Car motors for quite a while:
http://www2.towerhobbies.com/cgi-bin...nd&FVPROFIL=++
jrb is offline Find More Posts by jrb
Old Aug 04, 2005, 10:29 AM
latrans is offline
Find More Posts by latrans
Joined Aug 2004
WOW, someone has way way too much time on their hands. Very well done though.
latrans is offline Find More Posts by latrans
Old Aug 04, 2005, 11:36 AM
fwilly is offline
Find More Posts by fwilly
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
very cool stuff!!
fwilly is offline Find More Posts by fwilly
Old Aug 04, 2005, 12:07 PM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
My part started as I prepare to wind the world's best electric motor (the CROCODILE project, of course) and kept getting more complex. Still a little more work needed I fear to consider the options. I welcome suggestions.
David.
David T is offline Find More Posts by David T
Old Aug 04, 2005, 01:22 PM
Joined Feb 2001
Crocodile project, including turned parts, shafts, magnets, stator:
http://www.rcgroups.com/forums/showthread.php?t=392627
Old Aug 04, 2005, 01:24 PM
Joined Feb 2001
Holger Lambertus' results, using massive wire and litze wire, nice pictures too
http://www.rclineforum.de/forum/thre...610#post826610
Old Aug 04, 2005, 04:00 PM
David T is offline
UK
Joined Aug 2000
I think we have to be a member to see the photos. Holger's results also show that 'thick is beautiful'!
I must be very sad because I spent another evening on this! I have added a section looking at how the wire 'bows' away from the side of the stator. This appears to be one of the major constraints to density. I really want thinner wire to be better than thick but just can't do it yet!!!
Old Aug 04, 2005, 04:28 PM
Joined Feb 2001
Old Aug 04, 2005, 10:51 PM
fwilly is offline
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
What about winding with a single strand of thin wire and connecting the teeth in paralell. I saw pics of a Shogun motor wound this way. Unless my line of thinking is off, it would be the same resistance as a triple strand. It would be easier to wind a single strand neatly, but it would be a lot of turns.
Old Aug 05, 2005, 03:54 PM
David T is offline
UK
Joined Aug 2000
I'd like to see that Shogun design. Ron, I managed to register and have now seen the rcline photos; nice and neat but some empty space!
When I draw a GB 22.7 stator in CAD I can fit 70 strands of 0.45mm between two teeth. The most dense motor I have ever made has been 48 strands of 0.45mm (24 turns x2 = 3.82mm2) which I thought was quite good. By improving my technique I can get up to 50 strands but this is still way short of 70. So a little test revealed that I could fit 64 separate strands if I did not do any winding (=5.09mm2). The wire is slightly curved so I know I won't ever get to 70.
I am still looking for a techniques that will achieve greater winding density. The big issue for me has become the fact that the windings are 'oval' and waste space. So I have tried flattening the wire against the inside of the tooth with a wooden skewer/plastic wedge after each layer. This has helped a great deal and I have been able to fit 28T of 0.45mm (=56 strands) into two successive teeth so a complete motor should be feasible. This is 4.46mm2, over 16% better than what I could achieve before starting this research.
The second photo below shows 28x0.45mm on the left and 40x0.375mm (4.42mm2) on the right. The latter should make a nice 20T motor if I wind it with two successive strands although rotor clearance may be a problem. I will post more details of the technique in the first link in this thread.
Old Aug 05, 2005, 05:54 PM
flybike is offline
Find More Posts by flybike
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Absolutely amazing work.
flybike is offline Find More Posts by flybike
Old Aug 05, 2005, 05:58 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
One way to achive better density that may work is to wind always in one direction, and then come back up to the beginning with a diagonal wire outside the inter-stator gaps (where space is less an issue). Then the next layer can lie in the gaps in the first layer, and follow it down...
Old Aug 05, 2005, 08:59 PM
flybike is offline
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
In the first link you'll see a good picture of what Vintage is saying.
Best Wire for Hot Wire Foam Cutter andyg Foamies (Kits) 22 Apr 04, 2016 11:10 AM
Wire gauge versus amps ? djgorman23 Batteries and Chargers 27 Jan 23, 2016 04:45 PM
litze/multistranded wire has no advantage Ron van Sommeren Power Systems 2 Jun 11, 2005 06:17 AM
steel versus copper wire? astroboy Modeling Science 7 Nov 13, 2002 05:39 PM
foam cutter wire (picture frame wire) info finallyaheli Foamies (Kits) 21 May 31, 2002 07:55 PM
