Old Aug 03, 2005, 06:14 PM
himszy is offline
Find More Posts by himszy
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
Big or small prop?
Hi,
Is it best to have a small prop at high speed, or a large prop at low speed?
Michael
himszy is offline Find More Posts by himszy
Old Aug 03, 2005, 08:51 PM
petn7 is offline
Find More Posts by petn7
Joined Apr 2000
Well, in real subs, you want the screw to move slow enough to reduce cavitation and noise. As for model subs, I'd imagine it depended on the motor and ESC you were using.
petn7 is offline Find More Posts by petn7
Old Aug 04, 2005, 06:06 AM
himszy is offline
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
But in models, if you have to choose a motor and esc and prop, and your building a custom sub (not scale), is it best to use a large prop, at low speed, or a small one at high speed?
Old Aug 04, 2005, 09:31 AM
CaptainNemo12 is offline
Find More Posts by CaptainNemo12
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Well, assuming that you have a non-proportional radio and a sub with a fixed speed, a large prop will stir a larger amount of water as it is spinning than a smaller prop, which may slow down the motor a little and making it harder to run. If you're using an ESC, which causes the motors speed to alter when you wish, this theory still applies and it depends again on the motor type (you can't couple a 4" diameter prop to a small 3 volt motor, stick it in water and expect it to run at full capacity with little friction can you? ). My suggestion, don't go too big or too small, choose a size that you feel most comfortable with. Remember, there are always other factors that go with your choice, sub's size, ESC, battery run time, prop's pitch angle, only to name a few...
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old Aug 04, 2005, 10:26 AM
petn7 is offline
Joined Apr 2000
that's some good advice. just find a prop that looks good, then adjust your motor, esc, and gearing choice accordingly
Old Aug 04, 2005, 11:36 AM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Couple of things to bear in mind.
1. Speed you want the boat to travel.
2. Metacentric height of sub.
A large prop will provide large amounts of thrust at fairly low RPM. However as the boat travels faster, the large prop will create drag, so if you want a very fast sub, a smaller prop rotating at a higher speed is a better option.
Most subs have a fairly low metacentric height. A large single propped sub is going to give torque roll problems, unless corrected by a stator or some other kind of vanes.
Andy
Sub culture is offline Find More Posts by Sub culture
Old Aug 04, 2005, 10:22 PM
RC sub dude
Joined Nov 2004
For another way to counter torque, you could always use counter-rotating props, they're a bit complex to install, but it's a neat system to consider.
Discussion Discussion Big prop or small prop. Fishmasterdan 3D Flying 12 Mar 05, 2007 11:00 PM
Discussion New Helicopter Pilot Big or Small? rthorne Electric Heli Talk 25 Jan 28, 2007 08:32 AM
Big or small time events in the U.K. post here ! coaxial-gyro Electric Flight Events 0 Jan 07, 2005 02:31 PM
Kadets, Big or Small? Mr. Wiz Sport Planes 58 Nov 12, 2002 07:53 PM
Big prop-low rpm or small prop-high rpm Ninjak2k Power Systems 10 Feb 13, 2002 04:28 PM
